HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 01-08-2012, 02:44 PM
  #121
cemery's Avatar
Hi, I bought a new Mugen Mbx6 Eco, I have Ace ds 1015 servo, Zippy 4S 5000 mah 40 c lippo, Which Xerun combos do you offer me? and do I need external BEC?
cemery is offline
Old 01-08-2012, 06:23 PM
  #122
IROC-AR15's Avatar
Trader Rating: 29 (94%+)
Hear you can look for yourself and decide what's best for you.
http://www.hobbypartz.com/xerun150acar.html
IROC-AR15 is offline
Old 01-08-2012, 08:41 PM
  #123
I am not with hobbywing or anything. However I would get the xerun 150a ESC. I would ask on the Mbx6 eco thread which motor to get. It will matter how many cells you want to run. I would consider the tenshock X802 but you will need to decide how many KV to get.
wracing is offline
Old 01-29-2012, 05:34 AM
  #124
Peff's Avatar
Default Glitch buster
Hey guys,
More and more I am reading about guys recommending glitch busters or bec. What's is this? The cap on the esc? I use a spectrum radio and just ordered a 60A xerun and 17.5T for my 22T. Do I need one of these? I had my 150 A xerun for over a year, same radio and no problems...
Peff is offline
Old 01-29-2012, 06:13 AM
  #125
Suspended
Trader Rating: 2 (75%+)
hey guys what the best combo to run in a 1/8 rc8te truggy
Zangetsu is offline
Old 01-29-2012, 10:25 AM
  #126
IROC-AR15's Avatar
Xerun 150a esc/2000kv motor 4s lipo
Old 01-30-2012, 09:57 PM
  #127
speedy G's Avatar
Originally Posted by Peff
Hey guys,
Its not a cap, its more of a power regulator for your receiver. You bypass the internal bec of your speedo, and attach an external bec. Reason being is the external is better than the internal on most ESC. Some people are running them on 1/10 ESC to get more power to their servos, most internal bec's put out 5v, this external you can program to get the most power to your servos, 6v+ or whatever the servo can handle. It mainly depends on what servos you are running, if the servos are drawing more power than your internal bec can handle, you will get glitching of your system. If you are not having any glitching, dont worry about it, if it comes up, this will most likely fix it.
http://www.amainhobbies.com/product_...Adjustable-BEC
speedy G is offline
Old 01-30-2012, 10:28 PM
  #128
bigemike's Avatar
Trader Rating: 36 (100%+)
subscribed
bigemike is offline
Old 02-02-2012, 11:12 AM
  #129
Peff's Avatar
Thanks speedy
Peff is offline
Old 02-02-2012, 12:32 PM
  #130
jurquhart's Avatar
Trader Rating: 22 (100%+)
Is the description of the combo listed here good for buggy and what is the kv of the motor? New to hobbywing and thinking about getting this combo
HobbyWing 1:8 M6A Brushless Combo w/ XERUN 17T 4274SD Sensored Motor & XERUN 150A-SD Brushless ESC + LCD Program Box for 1/8 RC Buggy/Truggy
jurquhart is offline
Old 02-02-2012, 12:34 PM
  #131
IROC-AR15's Avatar
Yes it's cool for a buggy may have too much torque for it....a 4274 is a 2000kv motor you may want to look at the combo with a 4168SD 2250kv motor!
Old 02-02-2012, 12:38 PM
  #132
jurquhart's Avatar
Cool thanks
Old 02-02-2012, 01:46 PM
  #133
rcgod's Avatar
Trader Rating: 33 (100%+)
Is there any way to change the firmware on sct pro to ramp timing?
rcgod is offline
Old 02-06-2012, 11:40 AM
  #134
Trader Rating: 67 (100%+)
hey Guys,
I'm running a HW XERUN SCT Pro with a Tekin 5.5 4x4 550 Motor in my SC10 4x4. with a 2S lipo.
my issue is that it is very "soft" it doesn't seems to have any punch off the line and top end speed is very slow. I used to have a the XERUN 120A in this truck before and that ESC was way punchier and faster with the same gearing. I have maxed out all of the settings on the SCT Pro could this be the difference in software? Should i flash it with the V3 software? After a 6 min qualifier my motor is only 98-105 degrees. So i know i'm not over geared.
thx in advance for the help
Maxxican is offline
Old 02-06-2012, 12:05 PM
  #135
IROC-AR15's Avatar
My Xerun 150a esc should be here today or so and I was wondering can I absolutely set the esc to 5s cell count? I run a Tekin 1550kv x 5s setup.
