HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree174Likes
Old 12-23-2019, 01:27 PM
  #13111
Trader Rating: 33 (97%+)
Originally Posted by stvnmccc View Post
Hi everyone, quick question. I'm setting up my electronics and am using the XR10 Pro. Do I have to use the removable power button or can I eliminate this? Thanks
You can disconnect it, totally optional
billdelong is offline
Old 12-23-2019, 02:29 PM
  #13112
stvnmccc's Avatar
stvnmccc is offline
Old 12-23-2019, 04:50 PM
  #13113
Originally Posted by raypa View Post
I go one of this combos as well you should gear up a couple teeth and check temperature after3-5 minutes of use.
i accedentally cut the red wire right before the on off switch and then over heated the switch trying to connect it to the esc. so
cityra is offline
Old 12-24-2019, 10:07 AM
  #13114
Slotmachine's Avatar
Originally Posted by rrb1399 View Post
Canít get my stock spec esc to calibrate all it will do is blink red fast any tips ?
Sounds like you have no signal making it to the receiver if it wont even set neutral.
I sure you can buy a new external switch if it had one already. If you need help ask someone locally to help you attach it.
Slotmachine is offline
Old 12-24-2019, 12:20 PM
  #13115
For those who might not be aware of this nifty feature, you can turn off the ESC by holding the brake for 6 seconds
Bsthetech likes this.
Old 12-24-2019, 01:27 PM
  #13116
https://www.youtube.com/watch?v=O1TXhYelCRM
It works great at the start of a main if the grid happens to be on an incline!
gigaplex and Bsthetech like this.
Losiracer12 is offline
Old 12-24-2019, 01:47 PM
  #13117
an astute racer will prop a small pebble as a chock block to prevent a car from rolling before the start
Old 12-24-2019, 07:10 PM
  #13118
It is cool and convenient but a good reason why pros never use it
Old 12-24-2019, 07:31 PM
  #13119
DBM
G3R 21.5 comes with 30820411 rotor. Roar states that 30820406 is a legal option rotor. They have the same 12.5x7x25.2 dimensions. Which has a higher gauss rating?
DBM is offline
Old 12-25-2019, 07:52 AM
  #13120
LLOL... you realize the irony in that this feature is made available with the "Pro" version of the XR10 series right?
Old 12-25-2019, 11:07 AM
  #13121
I am absolutely aware of marketing gimmicks and things not necessary for a racing esc. Feel free to check any of the pros setup sheets that run Hobbywing and you will find the same results.
No pros use this feature and can care less about the reverse polarity protection that apparently the escís still get damaged
Old 12-25-2019, 11:34 AM
  #13122
This feature saves time for club racers who need to turn off their equipment and get into marshal position. By not having to remove the body to turn off your ESC can save upwards of 10-30 seconds instead of stressing out the RD looking for marshals... but if a pro driver already has an entourage to marshal for them, then yeah I can see how this feature is targeted more for a club racer
Old 12-25-2019, 01:49 PM
  #13123
slakr's Avatar
Trader Rating: 36 (100%+)
Meh... I have the Hobbywing XR10 Pro Stock Spec V4 in most of my 1/10 vehicles and have the feature enabled. Never caused a problem. To each their own I guess.
slakr is offline
Old 01-01-2020, 01:32 PM
  #13124
BRSracing's Avatar
Trader Rating: 67 (100%+)
Recently my phone updated to Android 10.... I can no longer access the data logs. The screen has no data? Anyone else have this issue?
BRSracing is offline
Old 01-02-2020, 05:38 AM
  #13125
Hang_TiMe's Avatar
Care to share stories about that?
Hang_TiMe is offline
