HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
Ok I see.so it transmit through my phone not the Internet .thank you
I just got one to try it out and I see that it has more settings than the program box . Tride it out in demo mode haven’t actually hooked it up yet ...tks
putting together a etruggy. i have limited space for the motor and esc since they are side by side. i was wondering if the xr8 sct with a 4268sd 2200kv motor would be ok? i know the motor is more of a buggy motor but the longer can motors won't fit. lmk what everyone thinks. thanks
not sure who to put this out to, but at one point Hobbywing had a motor mocked up in an LC racing 1/14 scale vehicle that appears to be a sensored mini motor. with the growth being seen in 1/14 mini scale racing, and with the mini nats making a come back, it would be great to see this motor make an appearance for purchase.
For those in the know or have some pull, please pass this along to HW higher ups.
Anybody here tried a bandit rotor with a v10 g3? Love how strong the magnet is with the bandit motor but mine currently has a broken end bell bearing and there's no replacements for it so I'm looking to transition to the v10 g3 seeing as they have end bells for sale for it.
Hey guys i have a xr8 SCT esc and a Tekin 1900kv motor.. will these pair together in full sensored mode? Or will it be a bad pair? Will the HW motor work better? Thanks in advance!
Paul
Tekin doesn't even offer a full-sensored mode, so running your combo in hybrid is hardly going to be "bad" by any means, I'd try it as-is and just pencil in an upgrade to the proper HW motor later when your current motor gets tired.
The one you want when the time comes will be the 4268 G2 1900kV. Good luck!
They will pair together fine but make sure you use the hybrid-sensored mode (not full-sensored), as "full" is only compatible if you have a HW motor.
Can’t get my stock spec esc to calibrate all it will do is blink red fast any tips ?
Hi everyone, quick question. I'm setting up my electronics and am using the XR10 Pro. Do I have to use the removable power button or can I eliminate this? Thanks
