HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
How’s HW customer service? Wired up a RX10 PRO 1S and it wouldn’t calibrate to my radio. Could get it to flash and beep red but it never went green. Never got power to my motor. Tried it multiple times and then the leads and capacitor blew off the ESC.
not very good I had a new G2 Elite fail on me and the hoops to jump through for warranty are bad. I ended up switching brands and found something faster now
Yeah I’m starting to get the same results. If this doesn’t get taken care of I’ll be going elsewhere myself
Paul Rush
Hobbywing Team driver
My 6.5t g3 runs really hot as well with no boost or turbo hope someone has some info to solve this a friend has the exact same setup and his doesnt run nearly as hot. Checked driveline for binding tried different gearing nothing works. My motor has alot of endplay but ive seen others that are the same way
No issues with HW here, sofar so good. Keep in mind during the Holidays, that they may be a bit busy, plus managing personnel's holiday vacations etc. They are usually easy to deal with on either FB, or directly.
On another note, is anyone running the New 2600KV open Housing motors in GT?
I got XR10 G2 on Black Friday and drove it for the first time today. Wow, what a big difference compared to the V2.1. The V2.1 is more like an on/off switch compared to the XR10 G2. My car is way easier to handle and my lines are a lot cleaner. Exactly what I was looking for.
So any actual difference other than the external color on the Passion, Rejuvenator, Stealth and Elite XR10 Pro G2 versions?
Only thing I could find is that the Elite comes with 13awg wires instead of 12 and no external switch. I don't understand why they would name it Elite and be $15 cheaper than the others
I don't care for external switches, and always switch out the 12awg for either 13awg or 14awg anyways, so why not save the $15? Unless you don't care for the color of the Elite.
How do you guys like the WiFi box ?
I used it today for the first time. I had trouble connecting to my phone when I plugged in the WiFi adapter and then turned the ESC on, but when I turned the ESC on and then plugged in the WiFi adapter it connected immediately. Worked great after that. Even seemed to show accurate motor temps and rpms even though I'm using Fantom motor (instructions say motor info only works with HW motors).
Ok thanks guys...this thing only works with WiFi ? there no WiFi at my track ?
