HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree90Likes
Old 09-07-2019, 06:04 PM
  #13021
5th wheel's Avatar
Originally Posted by Knockoffracer View Post
Need some advice, or tech help with the XR10 PRO 160a esc running a 10.5 G3 motor.
It will not work with the sensor cable installed. I need to push the car to get it to go, or yank the throttle back and forth until the car generates enough movement. I have replaced the sensor cable at least three times, replaced the Hall sensor, and replaced the capacitor pack after noticing damage to it. After all of this I still experience the same issue. Am I missing something?
Thanks in advance for any info. I've already been in contact with HW, they have been no help at all.
try tuning down your punch on start up
Cain and Knockoffracer like this.
5th wheel is offline
Old 09-07-2019, 11:41 PM
  #13022
Knockoffracer's Avatar
I don't see a punch setting on the program box. There is a quite a bit to adjust, but I have changed nothing aside from cut-off, and running mode. Is it called something else in this box? It's the one with the lipo check function.
Knockoffracer is online now
Old 09-10-2019, 04:13 AM
  #13023
Slotmachine's Avatar
can you post your settings so we can see if there is anything wrong with your adjustments? You said you noticed damage to the capacitor, did it get plugged in backwards? Have you tried another motor?
paul R.
Knockoffracer likes this.
Slotmachine is offline
Old 09-10-2019, 06:30 AM
  #13024
paul R.
I did reverse the polarity once. The capacitor pack was damaged in a wreck. I have used a different motor, some no-name one a friend loaned me just to try. It still displays the same issue. I'm pretty sure I nuked something in the ESC.
Old 09-10-2019, 06:33 PM
  #13025
Yes...even if they still work they are never the same after you plug them in wrong. When you send it in see about an upgrade to the new G3 speedo that has reverse polarity protection.
Old 09-15-2019, 09:38 PM
  #13026
Default XR8 plus
Hey guys my ESC won't let me do anything on it it blinks 4 green light fast what does this mean??? Thanks in advance???
Bigv is offline
Old 09-16-2019, 06:33 AM
  #13027
Ran the car again this weekend after making some adjustments with the program card. I definitely cooked one of the stages in this thing. Which is fine for now. I'll see if HW will service the thing or just pick up a G3.
Old 09-17-2019, 09:39 AM
  #13028
it sounds like its counting the number of cells, you are running 4 cell right? If it wont do anything else try to do a recalibration to your radio.
