HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree196Likes
Old 07-18-2019, 08:00 AM
  #12991
Originally Posted by brian mills
The Xr10pro along with most esc’s is only compatible as fast as SHR not SSR. Sanwa’s own esc as well as older LRP esc’s are the only ones that I have seen yet able to work with SSR. I have tested the Xr10pro first hand
Okay, thanks Brian for your reply!
Do you know the benefits of the SHR mode regarding to the normal mode?
Adri13 is offline
Old 07-18-2019, 04:33 PM
  #12992
The benefits are faster resolution and more precise response I always run SHR on throttle channel 2 and the fastest mode capable on steering channel 1 SSR,SUR,SXR
brian mills is offline
Old 08-15-2019, 08:00 PM
  #12993
Trader Rating: 16 (100%+)
zipperfoot is offline
Old 08-16-2019, 03:31 AM
  #12994
gigaplex's Avatar
Originally Posted by zipperfoot
I use the Hobbywing XR10 Stock Spec ESC with the capacitor that came with the ESC. I have read and been told to put a 2 cap or 4 cap capacitor on the ESC.
What is the reason for doing this? Is it really that noticable?
Has anyone tried using the Hobbywing Non polarity capacitor (NPC for XR10 PRO G2 ESC Stock Racing) on the Stock Spec ESC? I like the clean look of the new capacitor but it says it is for the XR10 Pro G2 but I wonder if it would work.
I can't comment on how noticeable the capacitor upgrade will be, I still run the stock capacitor.
That non-polar capacitor will work, but you won't be able to make use of the reverse polarity protection feature without melting your ESC.
gigaplex is offline
Old 08-18-2019, 05:00 PM
  #12995
the wrench's Avatar
does anyone know if you can power a transponder from the fan/programmer port on a xr8 plus esc using a short y harness? would make access for transponder swapping super fast, also leaves a quick connect port for my programmer, dont know what the output or draw limit the fan port has
the wrench is offline
Old 08-18-2019, 06:36 PM
  #12996
Slotmachine's Avatar
The new Cap. only works with the g2.
zipperfoot likes this.
Slotmachine is offline
Old 08-18-2019, 06:37 PM
  #12997
g3.
Yes you can use it for a transponder
Old 08-18-2019, 06:58 PM
  #12998
gigaplex's Avatar
Care to elaborate? It's a capacitor, what prevents it from working with other ESCs? Being non-polar shouldn't affect its operation as a normal capacitor.
Hang_TiMe and zipperfoot like this.
gigaplex is offline
Old 08-18-2019, 07:12 PM
  #12999
the wrench's Avatar
g3.
sweet, thanks, no more receiver box pull on my Eb
Old 08-19-2019, 11:09 PM
  #13000
I use the Hobbywing XR10 Stock Spec ESC with the capacitor that came with the ESC. I have read and been told to port on a xr8 plus esc
Richard Jackman is offline
Old 08-20-2019, 12:41 AM
  #13001
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
What???
1/8 IC Fan is offline
Old 08-20-2019, 03:55 AM
  #13002
Hi all,
Does anyone know whether the old HW program box (from around 2013) can still function with the XR10 pro 160A?
I can connect the ESC to my PC with my program box but when I try to plug the program box directly to te ESC for programming, the program box states that the software must be upgraded.
I upgraded the program box software with the most up to date version available and allowed thanks to my computer before trying to program.
Thanks for the help!
Adri
Adri13 is offline
Old 08-20-2019, 06:54 AM
  #13003
gigaplex's Avatar
Hi all,
Adri
Nope, you need the newer box. Best you can do with the older box is connecting via PC like you already discovered.
gigaplex is offline
Old 08-20-2019, 08:17 AM
  #13004
Pmr290670's Avatar
Default Xr8 plus
Originally Posted by COBRARACING
Hi Guys
This thread will be used for tech support and setups for hobbywing product for off road applications .you can request software etc and talk about anything you like with r/c .
thank you for your time
regards Angelo
Pmr290670 is offline
Old 08-21-2019, 04:20 AM
  #13005
D1360's Avatar
Hi,
I have the LCD program box, and I´m wondering how I use it´s voltmeter on my 2s lipos?
What cables do I need?
D1360 is offline
