HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree119Likes
Old 06-08-2019, 08:26 PM
  #12946
Trader Rating: 30 (100%+)
Originally Posted by SouthFloridaApp View Post
The specs state that one can use this ESC with an 8.5T motor. Has anyone used this ESC for mod touring car racing with a 8.5T motor for medium size asphalt tracks.
when I first got into rc I used the justock with a 8.5t motor just for bashing and it was fine.
riceball777 is offline
Old 06-09-2019, 12:55 PM
  #12947
What is the best way to remove rear bearing on XERUN-4268SD-1900KV-G2?
artur72 is offline
Old 06-09-2019, 03:05 PM
  #12948
BRSracing's Avatar
Trader Rating: 66 (100%+)
team trinity makes a tool to remove bearings. it should work
BRSracing is offline
Old 06-10-2019, 11:19 AM
  #12949
There is no hole on the opposite side,
I think that must to pull off with something.
artur72 is offline
Old 06-12-2019, 09:40 AM
  #12950
Trader Rating: 20 (100%+)
What size bearings do I need for a Xerun 3660sd ?
kyleman7 is offline
Old 06-13-2019, 10:14 PM
  #12951
Default Xr8 power issue
My Xr8 plus does not beep or power the motor when the switch is turned on. The esc responds to throttle input as evident by the red led indicator but the motor does not work and neither is there a beep. If I try to turn the motor shaft by hand whilst applying throttle/reverse, there is very slight resistance for a small period of time(less than 1 second) . I've also noticed that the 5v capacitor has leaked. Could the capacitors be causing the issue?
Sugsoh14 is offline
Old 06-17-2019, 01:34 PM
  #12952
Lonestar's Avatar
Hi guys,
I plugged my back backwards on my xr160... it went poof. Silly me. Moreover, my program card #1 started with a blank screen (like all pixels lighted up...) when I plugged it in. Program card #2 still works (yes, I have two, one always in the pit bag, one at home).
How (if?) do you suggest I revive the card? I cannot seem to be able update it with the HW link, it just doesn't "see" the card as a device... again, all is good with card #2...
thanks in advance for your help
Paul
Lonestar is offline
Old 06-18-2019, 03:27 PM
  #12953
Slotmachine's Avatar
Originally Posted by dogbone418 View Post
Going to give 13.5 racing a try in my 4wd buggy. Never ran 13.5 before. For this esc what mode/settings would you recommend? Iím an experienced racer but starting new here on this thx
Blinky mode no drag brake adjust your punch setting for the traction you have....
Slotmachine is offline
Old 06-19-2019, 11:22 AM
  #12954
Tech Legend
Cain's Avatar
Trader Rating: 268 (100%+)
the new esc is supposed to have reverse polarity protection, that right? Is this a feature that will make it into other ESCs?
For the xr10 pro stock, does that have high voltage BEC?
Cain is offline
Old 06-25-2019, 12:33 AM
  #12955
Hang_TiMe's Avatar
Is it possible to reverse the motor rotation with the xr10? I know there's no esc option for it but will abc to cba wiring work?
Hang_TiMe is offline
Old 06-25-2019, 01:19 AM
  #12956
gigaplex's Avatar
Swapping ABC to CBA will not work in sensored mode. You might even damage the ESC or motor trying it.
However, it might work in sensorless mode. Make sure the sensor wire is disconnected.
gigaplex is offline
Old 06-25-2019, 01:20 AM
  #12957
gigaplex's Avatar
I see the new XR10 Pro G2 will supposedly support some enhanced data logging graphing functionality with a future firmware update. Will this be backported to the current XR10 ESC family firmwares (eg XR10 Stock Spec)?
gigaplex is offline
Old 06-25-2019, 03:02 AM
  #12958
uDi_MP7.5's Avatar
Where did you purchase the XR8+?
Can you post a photo of the supposed capacitor leakage? It could definitely be causing the issue.
Unsure what you mean by 5V capacitor though, the capacitors in the XR8+ should be 35V rated, they are Rubycon branded parts (with high temp and high ripple ratings, generally reliable unless ESC is counterfeit).
They can be replaced if needed.
uDi_MP7.5 is offline
Old 06-25-2019, 08:33 PM
  #12959
Most cars built today allow you to flip the diffs in the case if the motor is not running the right direction. See if you can flip the diffs in your car...
You cannot reverse the wires on the speedo...
Old 06-27-2019, 03:42 AM
  #12960
Trader Rating: 8 (90%+)
Hi everyone I got an Ezrun 3656 4 poles motor, the shaft is broken (3mm shaft)... does exist some replacement rotor for this motor? Or a way to change the shaft?
manuelargentina is offline
