HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 05-23-2019, 06:45 AM
  #12931
Nils Ssx8r's Avatar
Default hw xr8 plus stops working after a few moths old,only flashes green led
Hello i have a question about the HW esc xr8 plus?
I have bin tru 3 xr8 plus esc in one year,everitime after a few months the xr8 plus stops working and go in the thermal esc protective mode by flashing the green led,and wont do anything any more,even a factory default resset wont work and the esc controle box cant connect ,the esc doing nothing but only flashes green .
Anyone wone have an idea what will cause this problem after the esc is a few moths old?
Nils Ssx8r is offline
Old 05-25-2019, 01:45 AM
  #12932
kiwi_tim's Avatar
Trader Rating: 17 (100%+)
Hi guys
quick one for some advice
xr10 pro with a 6.5t trinity horsepower monster, When moving it's fine, but when on the grid for race start, I pull the trigger and it doesn't move, need to pump the throttle 3 times to get it going, has a new sensor cable, can't see any solder cross overs between the phases, and soldering seems fine, initially assumed a dry join on on of the phases, but now kinda stumped... Suck when you have a front row start and end up p6 by t1
kiwi_tim is offline
Old 05-26-2019, 09:04 PM
  #12933
I have a xr8 SCT and 1900kv hw 1900kv g2 motor in buggy, but in the data record it reckons its doing 62,000rpm, which cant be correct its not moving that fast any reason why this might be?
swork hw is offline
Old 05-27-2019, 12:36 PM
  #12934
hi, my HW xr8 sct 1900kv combo in buggy says its been doing 62,000rpm in the data, surely this cant be right?
swork hw is offline
Old 05-28-2019, 11:33 AM
  #12935
Please help...I have a hobbywing xr10 pro 160a esc that’s been giving me problems. It was working and then all of sudden started glitching. I looked into it and saw the plug was loose in the receiver. When I pulled the plug out 2 of the wires came out of the plug. No big deal crimped new terminals and all seemed well. Took it out and it started glitching again. I’ve switched receivers, rebound rx to tx, tried to set neutral/full throttle/brake points and it won’t go into that mode. I hold the power button it flashes orange but no beeping, press it again while tx is in neutral and then the light goes out. I pull full throttle and press the power button and it flashes green a couple of times. It does the same when I set brake point. The light flashes correct when I pull throttle and brake but there’s no power to the wheels or motor. Hopefully someone can help. Sorry for the long post.
compactdan is offline
Old 05-28-2019, 05:57 PM
  #12936
5th wheel's Avatar
If itís new send it back.or get a RMA from HW some HW ESC they been having trouble with
5th wheel is offline
Old 05-29-2019, 06:40 AM
  #12937
According to the WiFi Express, my XR8 is reaching temps of 167F. Is that too hot? If so, what can I do?
Mallowpuff is offline
Old 06-02-2019, 02:53 PM
  #12938
Trader Rating: 24 (100%+)
Default Stock Spec v3.1 13.5 racing
Going to give 13.5 racing a try in my 4wd buggy. Never ran 13.5 before. For this esc what mode/settings would you recommend? Iím an experienced racer but starting new here on this thx
dogbone418 is offline
Old 06-02-2019, 10:49 PM
  #12939
Trader Rating: 36 (100%+)
When is the new xr10 pro gen 2 coming out?
riceball777 is offline
Old 06-03-2019, 02:42 PM
  #12940
Does anybody know if the old 2n1 LCD programmer will work with the XR8 SCT ESC? The info I'm finding isn't clear on that, it just says it uses an LCD programmer. I know there is a newer one but if my old one works I don't want to bother buying the newer one (don't have the ESC yet).
Overtorqued is offline
Old 06-03-2019, 05:48 PM
  #12941
5th wheel's Avatar
Has anyone ever had a HW V3.1 just Quiet on them for no reason? Was not even hot it just run one battery and on the next run it came on and just went off by itself after that won’t do anything?
Old 06-03-2019, 06:15 PM
  #12942
uDi_MP7.5's Avatar
Yes that is incorrect, this is an error in the software code as it doesn't account for the 4-pole motor.
Someone actually documented the issue earlier in this thread.
You can get the correct number if you divide by two, I believe.
Not too hot at all, 167F = 75C = quite safe.
The ESC will self-cutout if the thermal maximum is exceeded.
uDi_MP7.5 is offline
Old 06-06-2019, 09:01 PM
  #12943
I appreciate the response. Since then the max has been 148F and the max on the motor has been 123F. I think I'm good temps wise and may try a gear up.
Thanks!
Old 06-07-2019, 08:40 AM
  #12944
Mark98SS's Avatar
Hello, I have a new XR8 PLUS. In calibrating it will accept the neutral & high throttle settings but will not accept the brake. Tx trims are zero. red light is flashing rapidly, any ideas?
ETA: ABS was enabled, turned it off & all is good
Mark98SS is offline
Old 06-08-2019, 08:00 PM
  #12945
Default Justock XR10 60 ESC
The specs state that one can use this ESC with an 8.5T motor. Has anyone used this ESC for mod touring car racing with a 8.5T motor for medium size asphalt tracks.
SouthFloridaApp is offline
