HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree79Likes
Old 05-10-2019, 08:29 PM
  #12916
Slotmachine's Avatar
Originally Posted by Hang_TiMe View Post
Is there any way to access the bearing in the end bell of the bandit motors? Mine's destroyed.
Edit: Welp. Seems like I can't replace the bearing. Can't get bearing out of the hole and there doesn't seem to be any end bell replacements.
Try heating up the endbell. or find someone with a bearing tool
Slotmachine is offline
Old 05-11-2019, 06:02 AM
  #12917
Trader Rating: 99 (100%+)
My xr8 plus lost its fan on first outing. Anyone using a better replacement than stock?
dan-o is offline
Old 05-11-2019, 03:56 PM
  #12918
Default Capacitors
Using hw xr10 stock spec 80amp esc 2wd buggy in 17.5t blinky racing (with a single capacitor). I am fairly happy with the acceleration provided by the esc but it seems that the breaks are a bit weak. Would having 2 or 4 capacitors help in breaking? Or in general when and where would you use more capacitors? Thank you!
chajnik is offline
Old 05-11-2019, 06:11 PM
  #12919
Hey Hobbywing people..
I am having an issue with cogging in reverse. Tekno SCT 410.3, New Hobbywing XR8 SCT Pro ESC, LRP dynamic 4700 kv motor, 16t pinion. Zero Cogging going forward, but when going in reverse, it sounds like a hammer drill, GRRRRRRR, for a second or two, then it will take off. I am wondering if there is something in the settings that I need to address? I have other motors I can try if this doesn't start working properly. Thanks!
MaxxAction is offline
Old 05-13-2019, 04:29 PM
  #12920
Default XR8 SCT ESC / 3652SD G2 4300KV
Hi guys, I switched recently to HW in my SCT... was happy at the beginning, BUT..
I'm having the problem that after a regular jump (or hard landing), the car turns OFF. I turn it on again and it goes back to normal but the problem repeats again and again.
Sometimes, after a big jump (right after landing) I just lost TH for a few seconds (4-5 sec) while ST seems normal.
I'm kind of confused as where to start digging... I'm looking for possible answers (and similar experiences / solutions)
I don't think is a matter of temp, battery or bad soldering..... but honestly, I'm open to all suggestions.
refsiul22 is offline
Old 05-13-2019, 05:38 PM
  #12921
Just start ticking things off,
resolder it.
Sensor lead
Borrow a motor to test.
Borrow a esc to test
All that kind of stuff... once you find if its esc or motor or soldering, isolate it and test differnt things to do with that item.
iplaygames is offline
Old 05-13-2019, 06:20 PM
  #12922
Joel Lagace's Avatar
https://cdn.shopify.com/s/files/1/01...130624.pdf?747
breakdown of the motor
you could dry a heat gun on the bearing if its stuck..
Joel Lagace is offline
Old 05-13-2019, 11:25 PM
  #12923
Hang_TiMe's Avatar
Unfortunately, don't have a heat gun on me and burned the traces on the sensor board trying to get it off. My solder sucker decided to crap out on me and only had a diy wick to get the solder off. Fortunately found a used v10 g2 and a bandit g2 without a rotor bundled and used the bandit's end bell instead.
Hang_TiMe is offline
Old 05-14-2019, 11:10 AM
  #12924
Dan
Dan's Avatar
Trader Rating: 57 (100%+)
Any word on the successor to the XR10 Pro ESC?
1/8 IC Fan likes this.
Dan is offline
Old 05-17-2019, 09:00 AM
  #12925
First make sure the sensor wire is good and plugged in well, then go into settings and adjust the PVC to a lower setting maybe try a test and turn it off temporarily. I would also make sure the speedo and switch are mounted on a few layers of mounting tape to cushion the landings a bit.
Old 05-17-2019, 09:06 AM
  #12926
yeah racing metal fan
Old 05-17-2019, 07:57 PM
  #12927
Anyone know if you can use the Xr8 Sct ESC with a normal 540 2 pole motor? Like a HW G3 6.5t or something? Cheers
Hasselhoff is offline
Old 05-21-2019, 06:45 PM
  #12928
I gotta tell you guys...
I am getting really really frustrated with the HW ESC. I have a brand new xerun xr8 SCT in my Tekno SCT 410.3 the first motor I tried in it was a 4800 KV LRP dynamic 4 pole with maybe two hours of run time on it. When I would try to reverse, it would cog like a Jackhammer, GRRRRRRR. I tried hybrid, and full sensored. I tried setting the reverse force to 100%, re-soldered all the joints, still cogging in reverse.
So just for kicks I installed a Flash Racing (NitroRCX) 4800 kv motor two pole motor, and everything worked fine, it just didn't seem as quick as I thought it should be.
So I changed to a new Team Power Products 4300 kv 4 pole motor, and with the LVC at 7.0 volts, I can get about two minutes of run time before the LVC kicks in. I have changed sensor wires, re-soldered all of my joints, all nice and shiny. Furthermore, with this new motor, I have no reverse. I know the TX/RX are working because the display on the ESC goes red when I hit reverse. I tried a different sensor wire, and running in hybrid, same results.
WTF is going on with this ESC?
Old Today, 04:33 AM
  #12929
Trader Rating: 47 (98%+)
Hey everyone.
I just got a 2nd hand ESC from someone and when i opened it up everything worked but i noticed that one of the soldering posts were gone. The OCD in me needs to get a new one to put in there. is there somewhere i can buy some?
Thanks!
LETSDRIVE!! is offline
Old Today, 05:23 AM
  #12930
Trader Rating: 31 (97%+)
Originally Posted by LETSDRIVE!! View Post
Hey everyone.
Thanks!
I would submit an RMA, in the past I have successfully ordered replacement cases that were cracked and I would imagine you can do the same to get replacement soldering posts.... I think they are different size posts depending on the ESC too.
billdelong is offline
