HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 04-24-2019, 06:32 AM
  #12901
utieh's Avatar
I bought a while ago a XR10 Justock and it seemed it didn't have any brakes. Bought recently the program box and it didn't change anything.
Is it a common problem? Can it be fixed? The ESC is out of warranty.
Thanks for your help.
utieh is offline
Old 04-24-2019, 06:41 AM
  #12902
Trader Rating: 33 (97%+)
Generally when the brakes go out, it's the first indication that the ESC is about to fail.
The Justock ESC's are notorious for having a weak brake, I have heard some folks having success with increasing the brake strength by upgrading the caps:
https://www.amainhobbies.com/hobbywi...QaAhIdEALw_wcB
After the club in my area switched to a turf track, I found that the brake strength for the Justock was insufficient for my liking and have since upgraded to the ProStock which offers a significantly stronger brake.
It might be worth contacting HobbyWing and asking them for a trade-up offer, they generally provide deep discounts with RMA's outside warranty:
https://www.hobbywingdirect.com/pages/rma
billdelong is offline
Old 04-24-2019, 06:46 AM
  #12903
utieh's Avatar
Thanks Bill, I'll contact HW today!
Cheers!
billdelong likes this.
utieh is offline
Old 04-30-2019, 08:43 AM
  #12904
DPowers's Avatar
Trader Rating: 86 (100%+)
I am going to program my xr8 plus with the black box and was just wondering what would be a good starting point and after I get it all programed does it save it by its self are do I need to do something else thanks in advance im just new to the electric so I wasn't sure.
DPowers is offline
Old 04-30-2019, 04:21 PM
  #12905
Slotmachine's Avatar
Originally Posted by ongbenghui
Hi folks, wondering if I can find the answer here. Is the 2:1 Program card supported on QuicRun 1080 WP ? Been trying and it is stuck at Connecting ESC.
Is your radio on or off? Should be off. Sometimes if you unplug the speedo from the receiver it will help. If your receiver is not putting out a steady neutral setting it wont hook up. That's the reason for unplugging.
Paul .....driver for Hobbywing
Slotmachine is offline
Old 05-02-2019, 02:26 AM
  #12906
Default XR8 blinky
does the XR8 have blinky mode?
Todd Allen is offline
Old 05-02-2019, 07:25 PM
  #12907
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
The XR8 Plus does not. What are you trying to run this in, that you need blinky mode.
1/8 IC Fan is offline
Old 05-04-2019, 10:02 AM
  #12908
ceh329's Avatar
Hello, anyone have issues connecting the 3-1 LCD programming box to a XR8 Plus? When I do it the programming box only says “Connecting ESC”. The box worked fine on my other Juststock esc’s.
ceh329 is offline
Old 05-04-2019, 08:00 PM
  #12909
1/8 IC Fan's Avatar
Have you tried pushing item while it states connecting ESC? not sure, I had an issue similar on my XR8 SCT Pro, and seemed to take a while, but I pushed Item, and it went into the Program Menu. Not sure if this is the case with yours.
Old 05-04-2019, 08:03 PM
  #12910
1/8 IC Fan's Avatar
Originally Posted by 1/8 IC Fan
Awesome.they have great support.
Anyone have any info on the WSline turbofan they are outfitting on their XR8 esc's
Solved, its a Trackstar item. https://hobbyking.com/en_us/tracksta...E&gclsrc=aw.ds
Old 05-05-2019, 07:34 AM
  #12911
did you get this problem rectified, or did you end up getting a new ESC?
MaX-D is offline
Old 05-05-2019, 08:04 AM
  #12912
Have you tried recalibrating the ESC. A few months ago, i ram into that exact same problem with my Traxxas Rustler 4x4 VXL. I don't know if this was the actual cause, but, it seemed as if immediately after replacing the stock Traxxas servo with a Spektrum unit. After going through the complete calibration, breaking was working again. Thankfully, I haven't run into this problem with any of my HW ESCs...but, if it can happen with one brand, it can probably happen with any brand.
Panther6834 is offline
Old 05-07-2019, 05:15 AM
  #12913
try unplugging the speed control from the receiver and then hook it up. Sometimes if the speedo doesnt see neutral as a steady signal it wont hook up. Unplugging can help this.
Old 05-07-2019, 09:12 AM
  #12914
Big Will's Avatar
The XR8 SCT ESC says it has a con. 140A. Is that the limit on battery as well? Or is it ok to run a con. 150A batt.?
Big Will is offline
Old 05-10-2019, 11:10 AM
  #12915
Hang_TiMe's Avatar
Is there any way to access the bearing in the end bell of the bandit motors? Mine's destroyed.
Edit: Welp. Seems like I can't replace the bearing. Can't get bearing out of the hole and there doesn't seem to be any end bell replacements.
Hang_TiMe is offline
