HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree79Likes
Old 04-13-2019, 01:55 PM
  #12886
Originally Posted by S.A. View Post
Sooooo, I currently have a quicrun bl 120, and I run it in my t5m for practice racing, not proper racing, but I run 2s lipo on it with a 10.5 sensored motor. Anyways, I got a new 4x4 sct and its pretty heavy compared to the t5m, but looking at the specs of the max 10(designed for 4x4 sct's), which has 80a max , but the quicrun is 120a max but is meant for 2wd buggies and trucks, what's the difference? They both can do 2-3s lipos, they have a fan, and both can run sensorless (the quicrun can run sensored also) motors, but one has higher constant amp draw. show me your opinions or comments because im very confused on what to use, I mean i have the quicrun, but should I use it or not?
Been running the Quickrun 120BL with a 10.5 Bandit in a short course 2wd dirt late model for about a year. No problem.
motohead9 is offline
Old 04-20-2019, 10:27 AM
  #12887
DPowers's Avatar
Trader Rating: 83 (100%+)
Bought a used xr8 plus can anyone tell me how to program it to my radio i have tried looking it up on youtube but there all on how to program with the box i just to set it with my radio and then program it with the box.
DPowers is offline
Old 04-20-2019, 11:13 AM
  #12888
Tracy B's Avatar
You can download a pdf of the manual off of hobbywing's website.
Tracy B is offline
Old 04-20-2019, 11:51 AM
  #12889
DPowers's Avatar
tried but cant read it even when i try to blow it up it just becomes blurry.
DPowers is offline
Old 04-20-2019, 12:46 PM
  #12890
Tracy B's Avatar
1) start with radio on and esc off, but booked up to battery
2) hold the set button on the esc while pressing the on/off button. Release the button once the led flashes.
3) set neutral point, press set button (green led flashes and motor beeps once)
4) set throttle (pull trigger), press set button (green led flashes and motor beeps twice)
5) set brake (push trigger), press set button (green led flashes and motor beeps 3 times).
Those are the directions for calibrating your radio to the esc.
DPowers likes this.
Tracy B is offline
Old 04-20-2019, 12:59 PM
  #12891
DPowers's Avatar
Thank you!
DPowers is offline
Old 04-20-2019, 02:25 PM
  #12892
Tracy B's Avatar
Thank you!
Not a problem.
I can be found on Facebook at www.facebook.com/broeckerracing
DPowers likes this.
Tracy B is offline
Old 04-22-2019, 05:05 AM
  #12893
hyperfuxx's Avatar
Trader Rating: 28 (97%+)
Is there anywhere I can find setup sheets? I google search and they come up but I can't blow them up or print em out. I'm running on an extremely loose track with high speed small jumps. Have the XR8 plus w/ 2100 reedy in my MBX8. It's a turn and burn backyard track. Nothing crazy just wheel time
hyperfuxx is offline
Old 04-22-2019, 05:15 AM
  #12894
Tracy B's Avatar
I don't know about setup sheets, but you can download the pdf of manual at
www.hobbywingdirect.com
Tracy B is offline
Old 04-22-2019, 07:37 AM
  #12895
hyperfuxx's Avatar
Don’t need the manual
Old 04-22-2019, 08:21 AM
  #12896
Tracy B's Avatar
Originally Posted by hyperfuxx View Post
Donít need the manual
If you don't need the manual, then what are you looking for?
I have not seen any setup sheets since everything is user specific. The esc is setup pretty decent right from the factory. If you have a program box or wifi module, then you can program the settings to your chassis or track conditions.
Tracy B is offline
Old 04-22-2019, 10:45 AM
  #12897
hyperfuxx's Avatar
Maybe I'm missing something here. Looking for setup help OR setup sheets referring to crazy dusty track with high speed small jumps.
Old 04-22-2019, 11:00 AM
  #12898
hairymuffin's Avatar
Trader Rating: 99 (100%+)
mainly want to adjust your throttle/punch control. Lower the percentage from where you are now. Hard to say where you should be, you just have to see what feel,good to you and your track
hyperfuxx likes this.
hairymuffin is offline
Old 04-22-2019, 07:09 PM
  #12899
Hi folks, wondering if I can find the answer here. Is the 2:1 Program card supported on QuicRun 1080 WP ? Been trying and it is stuck at Connecting ESC.
ongbenghui is offline
Old 04-22-2019, 08:31 PM
  #12900
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 89 (100%+)
not sure if it does, but have you depressed the item button to see if the menu changes?
1/8 IC Fan is offline
