HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree174Likes
Old 02-05-2019, 01:51 PM
  #12751
gigaplex's Avatar
Originally Posted by revocat1 View Post
have same issue, also went into limp mode in second qualifier with flashing green light????
Over-heat protection. Did you measure the temperatures of the motor and ESC?
gigaplex is offline
Old 02-06-2019, 07:06 AM
  #12752
TommyD2x's Avatar
Is there set up sheets like this for HW? Looking for one for 8th scale buggy and 10th scale 4wd buggy. Last page of the Maclan thread has one posted... Something like that?
TommyD2x is offline
Old 02-06-2019, 08:18 PM
  #12753
Sharky8js's Avatar
just subscribed, as I just bought a HW XR10 justock set up
Sharky8js is offline
Old 02-07-2019, 04:22 AM
  #12754
gazza's Avatar
Here you go-XR10 Pro https://cdn.shopify.com/s/files/1/02...63592632674487
gazza is offline
Old 02-07-2019, 06:54 AM
  #12755
TommyD2x's Avatar
Exactly what i needed. Thank you. Is there any team drivers set-up sheets? New to the electric side... trying to make sure i'm in the ball park!!
TommyD2x is offline
Old 02-08-2019, 01:15 PM
  #12756
Trader Rating: 33 (97%+)
So I had an XR8 Plus that's been in my 2+ year old ET48.3 and I recently discovered that the plastic case was cracked... after contacting HobbyWingDirect, they were able to sell me a new enclosure for about $15 shipped
This included the bottom plastic case, red band, rubber seal, heat sink tape, 4 screws and a new heat sink top plate:
Everything swapped out very easily, I think I spent more time cleaning the years worth of dirt that had collected on all the internal parts, ha!
Now it looks just as good as new again
billdelong is offline
Old 02-10-2019, 12:48 PM
  #12757
mustangkillaz's Avatar
My program box is down. Anyone know if reverses motor on a sensors motor?
mustangkillaz is offline
Old 02-12-2019, 08:53 PM
  #12758
Sharky8js's Avatar
need some programing help... got my new XERUN XR10 justock hooked up
been trying to follow the directions in the manual but cant figure out how to get reverse to work?????
Old 02-12-2019, 08:55 PM
  #12759
Sharky8js's Avatar
Old 02-13-2019, 06:16 AM
  #12760
listening to all the beeps and tones can be VERY challenging, but with A LOT of patience, it is possible to program the ESC, I've done it in a pinch, but if you want to eliminate any frustration, then I would consider using a program card:
https://www.hobbywingdirect.com/prod...ant=1181193952
Old 02-13-2019, 06:44 PM
  #12761
Sharky8js's Avatar
this is where i'm confused about the card = a separate battery is needed for powering this program box when ESC has no built-in/external BEC ????
Whats a BEC?? will I need a separate battery supply?
what about this one? I'm not into the fine tuning, not racing.. https://www.hobbywingdirect.com/prod...iant=172030922
Old 02-13-2019, 07:25 PM
  #12762
nitro_mt_racer's Avatar
Trader Rating: 235 (100%+)
Did you follow the flow chart? It's the first programmable feature. Sounds like you're looking for option #2 which is forward/reverse with brake.
nitro_mt_racer is offline
Old 02-13-2019, 07:36 PM
  #12763
Sharky8js's Avatar
I was trying, it just went into full blast throttle...(without touching the transmitter) I would have to reset it..
Old 02-13-2019, 07:39 PM
  #12764
Shouldn't do that if you're getting it into program mode via the flow chart.
Old 02-13-2019, 07:40 PM
  #12765
I would contact HobbyWing to see if it will work with the XR10, I know I couldn't get the LED card to work with my XR8 and had to upgrade to the LCD card. You can also get a USB adapter and download the free software this will work for ALL of their ESC's for sure:
https://www.hobbywingdirect.com/pages/download
https://hobbyking.com/en_us/usb-prog...a-60a-esc.html
Yes the XR10 includes a BEC = Battery Eliminating Circuit, no need to hook up an extra battery, simply power up the ESC like normal, then unplug the fan on the ESC and plug in the adapter to that port to provide power and program the ESC at the same time simple as that.
Sharky8js likes this.
