HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree69Likes
Old 12-31-2018, 03:39 PM
  #12706
Slotmachine's Avatar
Originally Posted by JoshuaRC10 View Post
I have a year old v3.1 120A ESC that has been running fine, until yesterday. It was perfectly fine through about 30 combined minutes of practice, and then after my last practice session it stopped powering off properly and started powering on as soon as I connected the battery. It did not go thermal at any point during practice, that much I'm sure of.
As an outline, here's what the ESC is doing:
As soon as I connect the battery, the ESC powers up normally.
If I press the power button, the light on the switch shuts off but the RX still has power and steering is still active, but no throttle control. If I press the power switch again, the ESC turns back on and functions normally.
Any ideas what might be going on with this?
If you have access to a computer try a factory reset.
JoshuaRC10 likes this.
Slotmachine is offline
Old 12-31-2018, 03:40 PM
  #12707
my buddy has a wifi module, i'll give a reset a shot.
thanks!
JoshuaRC10 is offline
Old 01-01-2019, 12:00 AM
  #12708
Can I buy an XR10 PRO (2S) with no wires pre-soldered on?
dmourati is offline
Old 01-02-2019, 01:44 PM
  #12709
No I dont think you can. They are put on at the manfacturing stage. When you try to take them off cut the wires close to the speedo and they will come off easier.
dmourati likes this.
Old 01-07-2019, 02:43 PM
  #12710
Unfortunately a factory reset did not fix the problem.
I'm thinking there's a physical problem with the ESC?
Old 01-08-2019, 09:33 PM
  #12711
I just installed an xerun 120a v3.1 and the lcd program box wont connect to the esc unless i turn on my radio, then it will connect to the esc. Same issue connecting to the pc.
how can i fix this so i donít need to turn on the TX to program the esc.
TX is a spektrum dx4 pro.
thanks
chongo is offline
Old 01-09-2019, 06:18 AM
  #12712
start the RMA process here>https://www.hobbywingdirect.com/pages/rma
Old 01-13-2019, 05:47 AM
  #12713
rraden's Avatar
Trader Rating: 247 (100%+)
Has anyone had a problem with the cooling fan on the X10 2s stock coming apart? I've had problems with both of my esc fans. One has the fan blades constantly popping up slightly stopping the fan from working. I have to push it back into place to get it to work. The second esc had the fan blade assembly jettison out of the fan never to be found. This is happening during normal indoor dirt racing, no bashing!
Are there any 20mm fan guards out there?
rraden is offline
Old 01-13-2019, 10:09 PM
  #12714
Default Remove xerun 4268 bearing
Hi, I got a Xerun 4268 Sd G2. The bearing is getting really bad now. Is there any proper way to remove the bearing? Especially at the sensor end bell.
I did read somewhere (I forget where) someone tried to remove the large bearing in the bell but somehow destroyed the bearing and the outer race stucked inside. So is there any preparation (eg: pre-heat) I should do before push the bearing out?
Skaar_rc is offline
Old 01-14-2019, 01:50 PM
  #12715
Ostach24's Avatar
Trader Rating: 90 (100%+)
Hello, I just purchased 3 Hobbywing XR10 Pros. I installed 1 in my stadium truck and the other two are still in the box. When I power on the esc the rear tires click forward. I ran the truck this past weekend and it seemed to run fine, I am just curious about this little click forward when I turn the esc on.
Can someone tell me whether this is normal or not. The only thing I can compare it to would be when you put a dirt bike into 1st gear from neutral.
Ostach24 is offline
Old 01-14-2019, 02:54 PM
  #12716
Trader Rating: 31 (97%+)
Just to confirm, the transmitter is already turned on first, correct?
It sounds like your receiver needs to have the "fail safe" mode calibrated. I would check the manual for your radio on how to set the fail safe operation. I bet you're getting a dirty signal on the radio going into the ESC causing it to blip. With the car held safely in the air, when you turn the transmitter off (leaving the car on), does it cause the throttle to run away?
billdelong is online now
Old 01-14-2019, 04:50 PM
  #12717
Ostach24's Avatar
haha yes transmitter is already on then I turn the esc on. I am running a M12S rs and 481 receiver.
I have 3 rs pros and 2 rx8 setups same transmitter same receiver and no weird blip/click.
I had a few Novakís in the past that would turn the servos left or right and then center so I was wondering if this was just a weird quark with these escs.
Iíll check anyways though.
Ostach24 is offline
Old 01-14-2019, 05:21 PM
  #12718
Ostach24's Avatar
Just checked... turned the esc on with transmitter off and it did the same thing. Little click forward and that was it. Turned the transmitter on then the esc and same.
Ostach24 is offline
Old 01-14-2019, 05:54 PM
  #12719
how about turning on ESC with the Rx unplugged?
gigaplex likes this.
Old 01-14-2019, 06:02 PM
  #12720
This happens to both my xr8 sct and quicrun 150amp... The beeps indicating how many cell it runs on... In my case it is a 4s lipo, so it beeps 4x and the wheel wiggle forward a little on every beep... However, for xr8 sct, the wheels wiggle depends on my gearing... usually the wheel wiggle at the first beep only.
Skaar_rc is offline
