HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 03-02-2018, 10:30 AM
  #12286
Originally Posted by djiewie
@RC Gamer
You have 3 settings in the esc which sets your throttle sensitivity at idle/zero.
set it wider.
- Neutral Range6% (Narrow)9% (Normal)12% (Wide)
Have fun.
Thanks for the tip, but it seems the sensor board in the motor is damaged, or works incorrectly. It is also possible that this sky RC motor doesn't really compatible with the XR8 SCT ESC...
I don't really want to purchase into a HW G2 motor. I think I will use the system in sensorless mode during the season...
RC_Gamer is offline
Old 03-02-2018, 12:27 PM
  #12287
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Originally Posted by Cain
got a new hobbywing 35A speed control here, its the one that comes with the brushless LC Racing vehicles. When setting it up, it will not drop into setup mode, it just sit there and blinks, no sound. Other ESCs I have, same model, start up fine with the same electronics.
Is there something I can do that will "wake up" this ESC? Maybe a rest of firmware or something?
For this issue I reported, is it possible the switch itself is bad, at least the button that allows you to drop into setup mode?
The ESC is sealed with resin since it is waterproof so nothing I can really get to there to see, but maybe the switch is bad as other features like powering up and responding to the program card work fine.
Is there a way to validate this?
Cain is offline
Old 03-03-2018, 04:16 AM
  #12288
I've got a Hobbywing max 8 that I blew the capacitors, brown stuff is oozing out from 2/3 capacitors. Could I change them out? or use a Castle Creations CC Pack?
Jelle318 is offline
Old 03-04-2018, 07:45 AM
  #12289
idbdoug's Avatar
Trader Rating: 41 (100%+)
This is on-road related but since this thread is more active I'm hoping that someone here will have some info for me:::::
I'm going to be using 1/8 Hobbywing esc's and motors in 1/8GT8e class this season but have a question. In HW's 4268 series manual it says the following, "The motor timing is 30 degrees by default . The motor timing should be with in 30 to 40 degrees if you want to activate the Turbo timing. And the timing can be within 20 to 40 degrees if you have no intention to activate the Turbo timing." If I'm reading this correctly, if I set 25* of motor timing any turbo that I try to use with esc will have no effect???
thanks for any further info
idbdoug
idbdoug is offline
Old 03-04-2018, 05:50 PM
  #12290
RoyB's Avatar
Trader Rating: 19 (100%+)
With the XR10 justock, do you need to unplug esc from receiver to program it or is it like the XR10 pro?
RoyB is offline
Old 03-04-2018, 08:27 PM
  #12291
idbdoug's Avatar
unfortunately , you have to unplug the XR10 Justock from receiver
idbdoug
idbdoug is offline
Old 03-05-2018, 05:09 PM
  #12292
olds45512's Avatar
I have an XR8 SCT in my sc5m and I've been running a Hobbywing 7.5 motor on it since it was new. This past weekend i went to a different track and switched out the motor for a trinity d3 17.5 and i have no punch at all. From a dead stop i can go full throttle and the truck will slowly roll about 6ft and then it takes off. I tried re-calibrating the esc and i have the punch turned up all the way, I also tried another 17.5 motor with the same results. I changed out the sensor wire and it still does it. Everything is wired ABC and all radio/esc settings have been triple checked. Any ideas would be appreciated.
olds45512 is offline
Old 03-06-2018, 06:35 AM
  #12293
Hello!
I also have the XR8 SCT ESC. I have had a similar problem with it. I use it with a skyrc 2150Kv motor. When I tried to use it with a sensor wire, the sytem had a huge cogging effect. The car couldn't start from stop when I hit the full throttle.
I tried everything too, but there was no difference. I ended up using the motor without sensor wire. In this way It works flawlessly, and It is very smooth.
Have you tried it with no sensor cabel? Does it work good with the hobbywing motor?
RC_Gamer is offline
Old 03-06-2018, 06:57 AM
  #12294
olds45512's Avatar
Originally Posted by RC_Gamer
Hello!
I tried it without the sensor cable and it made no difference. I'm going to put the 7.5 back in it tonight and see if if works or if I still have the same issue. Both 17.5 motors I tried worked about 3 weeks ago with a different esc.
Old 03-07-2018, 03:28 PM
  #12295
dtr
dtr's Avatar
Did you run it in full sensored mode? They are supposed to work only with howwbywing motors that way, you should switch to hybrid mode for other motors.
dtr is offline
Old 03-07-2018, 04:37 PM
  #12296
olds45512's Avatar
It is in hybrid mode. I tried full sensored mode but it didn't make a difference.
Old 03-09-2018, 08:11 AM
  #12297
olds45512's Avatar
I put the hobbywing 7.5 back on the xr8 sct and it works fine. I also put the Trinity 17.5 on a different brand of esc and it works fine. Can I just assume that the xr8 sct doesn't get along with other brands of motor?
Old 03-09-2018, 08:22 AM
  #12298
i assume that's the case, reminding me that my old blue xerun had similar problems with skyrc/toro/trackstar 4p motors, this is why i went for original HW-motor this time.
Get a HW-motor or a proven working one or just use the motor sensorless
cerberoz is offline
Old 03-09-2018, 08:37 AM
  #12299
olds45512's Avatar
The 17.5 didn't work sensorless either.
Old 03-09-2018, 01:12 PM
  #12300
Anyone could help??
Jelle318 is offline
