HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 01-28-2018, 04:53 PM
  #12226
Default motor cogging
recent problem with low speed serious cogging with my Hobbywing Trackstar SC120 and Tenshock 4400 motor. Now lose motor and steering after 2 minutes run time. Tried several different batteries and glitch buster. No improvement. Any Idea?
2muchrc2 is offline
Old 01-28-2018, 06:43 PM
  #12227
question about an older esc. I have a justock 45a blue edition. I know or at least think that the motor timing in the esc is set and locked at 0. i am wondering if I can adjust the mechanical timing on the endbell of the motor? will the esc allow this and is it ok to do?
thank you
dynastorm is offline
Old 01-28-2018, 06:51 PM
  #12228
5th wheel's Avatar
thank you
Yes you can.wach your motor and esc temperature
5th wheel is offline
Old 01-28-2018, 07:11 PM
  #12229
ok thanks. I have been trying to adjust the timing to find the motor sweet spot by monitoring the amp draw. the motor is a tekin gen2 17.5t and I can only get the endbell timing to 15-17 before the esc shuts the motor down. the amp draw is only like 3 amps. not sure why the esc would shut down. the motor temp is pretty cool.
Old 01-31-2018, 10:52 AM
  #12230
That's strange. The only time the ESC should kill motor power is if voltage gets to low, the timing is WAY to high, or if there is a temperature issue.
First I would double check all of your wires, solder connections, sensor wire, etc.
Second, try to re-calibrate the ESC to your radio and make sure there isn't a goofy issue with your endpoints (set both to 100%)
If those don't help, I would try disabling your motor overheat protection and see if that fixes the issue. That feature is really only designed to work with HW motors anyway.
flamingtire is offline
Old 02-01-2018, 08:48 AM
  #12231
Trader Rating: 44 (100%+)
My LCD Multifunction program box will not connect to my Stock spec V3.1 ESC. Do I need to update the firmware in the program box? If I do update, will the program box still work with my 120A V2.1 ESC?
I think my current program box firmware is 1.14 (going off memory)
Bartman42 is offline
Old 02-04-2018, 08:43 PM
  #12232
Trader Rating: 30 (100%+)
Xr8 sct speedo is blinking green led 3 times then pause, 3 times then pause continuously while sitting in netrual. Motor will not turn, recalibrating did not work. What is the led telling me??
Brandon Powell is offline
Old 02-05-2018, 01:34 AM
  #12233
gigaplex's Avatar
Did you check the manual? The LED error states should be described there
gigaplex is offline
Old 02-05-2018, 05:20 AM
  #12234
jabroni racing's Avatar
Trader Rating: 45 (100%+)
my program box connects to my v2.1 & v3.1 with no updates to the programmer, i didnt even know there was a update. just go to HW site, download the tool & do it on your computer as well as update the V2 firmware
SORRY-didnt see stock spec, no clue... My bad
jabroni racing is offline
Old 02-05-2018, 01:35 PM
  #12235
Yes sir. Sure did. Did not call out a 3 blink on the green LED sitting in neutral. And motor would not run.
Old 02-05-2018, 03:26 PM
  #12236
gigaplex's Avatar
I just checked the manual and it's in there. Current overload protection. Maybe you've got a short or the ESC is damaged.
gigaplex is offline
Old 02-05-2018, 04:23 PM
  #12237
Thx. I looked with no luck. Sounds like I need to send it in and hope they help with it. Thx again.
Old 02-09-2018, 10:47 AM
  #12238
Sinnin's Avatar
Does anyone know the story on the 120A V3 ESC? This seems to be a short lived ESC before becoming the V3.1.
The reason I ask is that i obtained a used one, and have been running it in one of my less serious race classes. I dont have any problems with it but have been using the V3.1 manual and firmware updates as anything specific to the V3 seems to be non-existant.
Sinnin is offline
Old 02-10-2018, 08:04 AM
  #12239
My Hobbywing 3.1 stock spec is not working right. On Wednesday night racing I was running 9.5 Reedy toward the end of the run the motor got very hot and stopped running. Tried installing a new Orion 6.5 and the motor will not turn over unless you manually spin the wheels first. Tried this with 2 other motors that were working in other cars. Same results. Could the Reedy 9.5 running hot have damaged the ESC so it functions this way?
I tried connecting the ESC to the USB link software to do a factory reset and still the same issue... Any ideas anyone?
charvel74 is offline
Old 02-11-2018, 03:27 AM
  #12240
Peakki's Avatar
Default xr10 blinky with softening?
Might be wrong thread...
Running 6.5 blinky 1S pan car with XR10 1s or 2s.
Now new problem, it is that when using softening (example 10% and 5-30degrees) it doesn't anymore state by blinking in neutral that ESC is in blinky mode.
Only way to have it on blinky, is to forget softening settings and put those to 0.
Is it really true that low end punch is not possible to tune with softening so that ESC is still in blinky?
2s has XR-4.2.0.6 and 1s XR-4.2.0.1-BRCA or XR-4.2.0.2 firmware.
Peakki is offline
