HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree193Likes
Old 10-26-2012, 11:13 AM
  #1171
nanoverse's Avatar
Originally Posted by gernaat
dood! if you didn't hit this on the head, you are on to something. i had tried two diff nanotechs. did a quick run this am with a full gforce pack and had no issues for the 5-10 mins i was running. truck felt smooth as butter and plenty of power.
i'm happy, relieved and puzzled all at the same time.
did you ever get it to like the nanotechs?
Never had problems with the nanotechs. Actually they hold up much better than Orion lipos. I charge at 20amps and always storage charge after a day racing.
The a-spec 6.2 is getting more oomph after a while. At first I was disappointed in them but lets see if they get better.
nanoverse is offline
Old 10-26-2012, 12:28 PM
  #1172
What is the correct wiring from an ez run 4300 to a mamba max pro? The ez run has blue yellow red wires..the mamba has red white black wires.. sorry new to the electric stuff.
dizzle4028 is offline
Old 10-26-2012, 01:12 PM
  #1173
justpoet's Avatar
Trader Rating: 16 (100%+)
The EZRun series is generally sensorless. So, wire up all 3 wires, and if the motor turns opposite from what you expect, swap any 2 wires.
If the motor has a listed A B C for the wires, you can use that to wire up in order too so you're less likely to need to swap 2.
justpoet is offline
Old 10-26-2012, 06:32 PM
  #1174
J_Bone's Avatar
Is there a difference between the 'V3_508_NO_timing"to the "V1_508_NO_timing" ?
J_Bone is offline
Old 10-26-2012, 06:34 PM
  #1175
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
my HW software only has the v1. Is there a v3 out?
Wildcat1971 is offline
Old 10-26-2012, 06:57 PM
  #1176
J_Bone's Avatar
yeah. Mine has V3.
J_Bone is offline
Old 10-26-2012, 07:12 PM
  #1177
Hi all,
Just got a Justock 17.5T combo for my SCT. Got it wired up and the motor is not accelerating past about 1/2 throttle. I have calibrated the throttle per instructions, and set the auto cut off to none as I am using a nimh batt. Just wondering if there are any ideas on why it seems to be running at half power. Battery is good, ran it my sons velineon brushless and it works fine. Its the JS5 combo, has the club spec esc, xerun 17.5T sensored motor and digital LED prgramming card.
thanks in advance.
at7driver is offline
Old 10-26-2012, 07:19 PM
  #1178
Gene158's Avatar
I have an SCT pro esc and after a hard landing while racing tonight, I lost throttle response. I turned off the esc and powered it back up but something's definitely wrong. It seems as though the esc is stuck in programming mode or something because when I turn it on, the red light flashes, then the green light starts flashing; first once, then twice, then three times, etc... I tried to recalibrate it but as soon as I hit the setup button, the esc powers up and I can't seem to get it to recalibrate. Is my esc shot? I've had it for less than 2 months.
Gene158 is offline
Old 10-26-2012, 08:34 PM
  #1179
Just realized the 17.5 is a 1900 kv so need to change gearing.. duh.
Gene158, I'm new to hobbywing products but maybe the on/off, setup switch is at fault. Does the small setup button return to its position after you depress it, maybe some dirt/mud got in there and its staying in the depressed position.
good luck
Old 10-26-2012, 08:57 PM
  #1180
spdrac430's Avatar
Trader Rating: 35 (100%+)
I was curious why an esc list an on road motor limit and an off road motor limit
like the just stock hobbywing esc on road 8.5 rated off road 11.5 is it bassed off the ky of the motor just curious
spdrac430 is offline
Old 10-26-2012, 09:10 PM
  #1181
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
You need to update that software! Lol.
http://www.redrc.net/2012/04/hobbywi...mpetition-esc/
ovalracer1m is offline
Old 10-27-2012, 04:49 AM
  #1182
Firewood's Avatar
Trader Rating: 19 (100%+)
I just picked up a second hand Justock esc. Is it worth fixing it?
It puts out enough current to turn the motor only, if I put a pinion on it and place the car on the ground it just stutters and barely moves. ALso It only has reverse in crawler mode. I have the program box for it and tried all different
settings. I see these selling new for 55 bucks - is really worth fixing or can I fix it myself?
Firewood is offline
Old 10-27-2012, 05:51 AM
  #1183
spdrac430's Avatar
im running the just stock with a dualsky 8.5 in my kyosho rt5 and its supper fast
Im tempted to get another for my buggy
Old 10-27-2012, 07:22 AM
  #1184
Gene158's Avatar
good luck
No, unfortunately it's not the switch.
Gene158 is offline
Old 10-30-2012, 07:52 AM
  #1185
Sorry if this has been posted before, but I have the LED programming box, and I can't seem to get it to work. It worked when I first used it, but after attempting to update it with the downloaded software, it always says "Connecting with ESC" and then "Please update software". I hooked up the esc through the programming box to my computer, and I could change settings that way. I updated the ESC to the newest software (or firmware?) and it still doesn't work with just the programming box. Any ideas? I'm using version 3.1 software on my computer, and I tried updating that as well.
TurboNoob is offline
