HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree193Likes
Old 03-20-2017, 03:39 PM
  #11581
Originally Posted by Bad6as
Thasks, I was watching Temps and it was in the 120s with the big pinion. Gearing to a smaller pinion increased my motor temps
What car/ESC are you running? 120F isn't hot. Gear for 140 - 160 (some might even recommend 160 - 180).
Jason B is offline
Old 03-20-2017, 04:18 PM
  #11582
Losi scte 3.0 xr8 sct pro esc 3652 3800kv
Bad6as is offline
Old 03-21-2017, 01:52 PM
  #11583
Originally Posted by OriginalDonk
I grabbed and XR10 Pro Stock and am pretty pleased with it aside from what I see as a redundant power switch/button. I can access the power on the ESC itself and the 5 inches of wire and a secondary power switch/button are cluttering my relatively tight setup.
Anybody get creative and remove that secondary power button/switch? I understand that this would adversely impact my warranty.
Do you mean the XR10 Stock Spec? If so, the second power switch can be disconnected right from the ESC...
flamingtire is offline
Old 03-21-2017, 01:57 PM
  #11584
Originally Posted by freezeframe007
I use HW esc's in all my off-road track cars. I have a mixture of XR8, sct pro, v3.1, 150a blue and justock. Someone at my track was talking to me about adjusting the frequency setting to get a smoother powerband. I am trying to find out more about this setting. Also, would this be available on all these esc's?
Ron Schuur did a solid segment on this in a recent video posted by JConcepts. That particular setting is only offered on the XR10 line of ESC's at this time. Basically, if my understanding is correct, lowering the frequency increases the punch in the lower RPM range, but it makes the power output less consistent and smooth throughout the usable range. The motor will also run hotter. Increasing the frequency smooths out the punch by pulling some torque away which may give you some additional RPM. Make sense?
Old 03-21-2017, 02:00 PM
  #11585
I went from 2k to 4K on my throttle freq this past weekend in my B6D, and it was crazy how much difference it made. I did notice a little less punch, but it definitely made the throttle response smoother and a little more forgiving (less wheel spin). I'm not sure if I'll keep it there, but it was definitely interesting and it's certainly nice to have those options.
Jason B is offline
Old 03-21-2017, 03:21 PM
  #11586
I just finished looked at all the current lineup of HW esc on their site and discovered that this was only available on the xr10's. So, my next question is would adjusting the curve in either the esc or my MT4 radio give me a similar affect? I am not even sure if all my esc's allow for custom throttle curve or not. I know some of them do. But, if the curve adjustment on the radio will accomplish a similar result, I can obviously make those adjustments to each car.
freezeframe007 is offline
Old 03-22-2017, 08:50 AM
  #11587
Trader Rating: 16 (100%+)
Anyone know how to be able to reverse motor direction on a Justock XR10 zero timing?? I have the programming card(both styles). Purchased this for my SCX10.2 kit at my LHS, not realizing that it will not allow me to run it in reverse, unless running in unsensored mode. Thanks for any help!
Lanky is offline
Old 03-22-2017, 11:45 AM
  #11588
Trader Rating: 28 (100%+)
I recently bought a used V3.1 120amp esc to run in my T5m. Before I ran it I reset the settings to default and I'm running the Blinky profile.
I've run it for 2 race days at a very small indoor clay track and I've burned my motor out in both mains. The first one was a 13.5t that I also got used so I dont know the history on it so it might have already been junk. The second one was a 8.5t that I bought new so I know it was never over heated and worked fine up until last night. I can't recall the gearing i'm running but its not over geared and since the track is so small I'm never close to full throttle either.
I'm looking for ideas what to look at.
The one weird thing was when I've got the esc hooked to the computer some of the settings dont show normal numbers, they are kind of werid looking symbols or something. I can post a picture later if need be. Is there a way to hard reset the esc to wipe it clean and start over?
bobf24 is offline
Old 03-22-2017, 11:52 AM
  #11589
the rc guy's Avatar
what side is your motor mount on right or left? motor rotation? cc/ccw? that will matter.. id have motor mounted on drivers side try that gearing sounds like it also might be issue...
the rc guy is offline
Old 03-22-2017, 12:04 PM
  #11590
I should have added that for the last qualifier it came off at a fine temp, didn't use a gun for an actual number but it was barely warm to the touch, and then for the main it burned up with the exact same gearing, I'm 95% sure gearing is not the issue.
bobf24 is offline
Old 03-22-2017, 12:47 PM
  #11591
Andy63's Avatar
An video about the latest Hobbywing XR8 SCT version. The new and better version of XR8!
https://youtu.be/dSqn3EOvyNw
cheers// www.andrefossto.wordpress.com
Andy63 is offline
Old 03-22-2017, 01:43 PM
  #11592
Rasheed's Avatar
I just bought the Xerun XR8 SCT speed control and 4300kv motor to run in 4x4 SC. I also bought the program box. Initially I could not figure out how to connect the program box to the ESC. I tried to plug the ESC output (that usually goes in the receiver) directly into the program box but this did not work despite me trying several different things.
After some frustration I finally realized that you have to remove the fan power and use those pins with the jumper cable that came with the program box to connect the ESC to the program box. Then everything worked fine. I looked online and on the instructions and I did not see anywhere that it was made clear that you had to unplug the fan power to connect to the program box, so I thought I would post here in case anyone else was having the same problem.
Derry likes this.
Rasheed is offline
Old 03-22-2017, 10:56 PM
  #11593
Trader Rating: 24 (100%+)
rcuser67898578 is offline
Old 03-22-2017, 11:38 PM
  #11594
wothrottle's Avatar
Hi, I have a question regarding my esc/motor buy decision.
In a 8th scale buggy, 4s on racetrack. which combo will give a cooler motor?
xr8plus+ 1900kv motor
xr8plus+ 2100kv motor
assuming gearing is adjusted for same end speed.
Are the Pro and Cons why to choose this particular combo?
thanks
wothrottle is offline
Old 03-23-2017, 07:49 AM
  #11595
Roadburn's Avatar
How do you open the can of a XERUN 1/8 scale motor to clean it? I have a 2250KV, no outer screws.
Roadburn is offline
