HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 03-08-2017, 01:19 PM
  #11551
Slotmachine's Avatar
Originally Posted by DLE RC
Hey there, I'm having and issue with my Justock (not the XR10, the previous version). I have an SCX10 and the ESC is making the truck drive in reverse. I've downloaded and installed the latest firmwares on both the ESC and the LCD programming box. The PC software has the option, but it is greyed out? How do I get this ESC to change the motor rotation? I tried to do this on the transmitter (Futaba 4PL) and then reclaibrate, but it doesn't matter, it still just goes in reverse I really want this thing to work!
You cant change rotation on the speedo. If this is a 4wd you have it in you have to flip the diffs to rotate in another direction.
Slotmachine is offline
Old 03-08-2017, 01:30 PM
  #11552
chris c's Avatar
Trader Rating: 60 (100%+)
Isn't the futuba radio is one you have to reverse the throttle on the radio when programming...thought I read that somewhere...
Not HW only ...all esc's
chris c is offline
Old 03-08-2017, 01:57 PM
  #11553
Trader Rating: 24 (100%+)
yeah i have the Futaba 4PLS/SR304 receivers + HW ESCs and yes everytime i have to recalibrate/sync the throttle needs reversed on the transmitter. then it goes back to forward
dogbone418 is offline
Old 03-08-2017, 02:55 PM
  #11554
gigaplex's Avatar
I don't think you can flip the diffs in the SCX10.
gigaplex is offline
Old 03-09-2017, 06:01 PM
  #11555
Default Xerun sct pro
Hello all I have a Xerun sct pro I am wondering why this thing two stages. When I hit the throttle it goes than after a second it hits like a power band. I have messed with punch setting doesn't really change anything. Can anyone help.
Thanks Garrett
Pecker31 is offline
Old 03-09-2017, 07:29 PM
  #11556
Joel Lagace's Avatar
Same for the 4PX its a futaba thing
Joel Lagace is offline
Old 03-10-2017, 08:32 AM
  #11557
traumajunkie's Avatar
I am needing a new ESC for a b5m I bought. I do not have the car yet but have a race this weekend. I am running a Hobbywing v2.1 in my other 2 cars. Will a HW v2.1 fit in the b5m or do I need to use something like a HW XR10 Justock. I will be running a 13.5 mod motor Thanks
traumajunkie is offline
Old 03-10-2017, 09:56 AM
  #11558
Default Coasting function for XR8 SCT
hi,
will coasting function work with any brand motor, or only with HW motors?
hardijs is offline
Old 03-10-2017, 03:57 PM
  #11559
V2.1
Size: 43mm(L) * 36mm(W) * 33mm(H)
XR10
Size: 37.5x30.9x31.6mm (w/Fan & Fan Shroud)
XR10 will give you more room to work with.. That said if you have a small receiver the V2.1 should still squeez in
Old 03-10-2017, 04:07 PM
  #11560
goehm's Avatar
Trader Rating: 45 (100%+)
What's the trick to get an XERUN to run reverse rotation? Pull the sensor wire and run in sensorless? Or is there an option I can unlock in the PC interface (I currently only use the programming box).
goehm is offline
Old 03-11-2017, 01:32 AM
  #11561
Default Wifi Express with Android
Just got Wifi Express for XR10 Pro. I use Android 6.0.1. Im not able to select parameter values. Those that are selected with dot, like "Remote Off"->on or off, do work. But parameters that are selected scrolling up/down, like drag brake value, i can not select? I can scroll, but how to select the value?
Pushead is offline
Old 03-11-2017, 10:53 PM
  #11562
XR10 PRO (HELP)
Hey.
Today my XR10 Pro started cogging and them immediately I lost all throttle. I replaced sensor wire. I replaced the motor and still not responding. If I unplug the sensor wire it works but as soon as I plug it back in I have no throttle.
Any suggestions before I replace it.
It is only a few months old
ChrisUU is offline
Old 03-12-2017, 10:51 AM
  #11563
I would try the following:
-1 re calibrate the ESC to the radio. (initial startup procedure)
-2 check with wifi module or black LCD box that the sensor mode is set to FULL SENSORED. Maybe switch to hybrid and back so that you can resave that setting
-3 Perform FACTORY RESET And repeat step 1
Old 03-13-2017, 03:47 AM
  #11564
Originally Posted by ChrisUU
XR10 PRO (HELP)
Hey.
Did you try resetting to gactory on your pc using the Hobbywing program?
Old 03-14-2017, 06:57 AM
  #11565
Thanks Garrett
Are you running a sensored motor?
flamingtire is offline
