HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 03-02-2017, 06:07 PM
  #11536
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
ESC came today and started up fine. Looking forward to trying it out this weekend. No hassle from hobbywing just serviced and returned. Very nice change versus what happened before!
Cain is offline
Old 03-02-2017, 06:08 PM
  #11537
Tech Legend
Cain's Avatar
Originally Posted by Desert Assassin
Having a little issue with an xr10 justock that I hooked up. Motor will not turn unless I give the rear wheels a little push then it operates as normal until I lock the wheels up by braking or stopping completely. I have to push it again for it to get power. When it sits I hit the throttle and the spur moves a tiny bit, but not enough to get it going. What's up?
Try the following:
- Unplug the sensor wire and see if it acts close to normal (it may cog a bit however thats normal as its sensorless at that point)
- Try a different known-to-work sensor wire if the above works fine
Cain is offline
Old 03-02-2017, 06:43 PM
  #11538
Originally Posted by Cain
Try the following:
Thanks for the suggestion. Took the sensor wire off and it worked and cogged like you said. Swapped wire with known working wire from my other car and no go same issue. Even took both wires to my other car and they worked fine.
Desert Assassin is offline
Old 03-03-2017, 06:14 AM
  #11539
Tech Legend
Cain's Avatar
Its possible it could be a sensor issue internal to the ESC itself. If thats the case, you will probably need to send it in.
Cain is offline
Old 03-03-2017, 09:01 AM
  #11540
Slotmachine's Avatar
It could be a hall sensor in the motor, try another motor before sending the speedo in.
You can also hook into your p.c and do a factory reset on the speedo, I have saved a few like that before.
Slotmachine is offline
Old 03-03-2017, 09:08 AM
  #11541
Copy that. I'll give that a whirl today. Thanks
Old 03-03-2017, 09:49 AM
  #11542
update:
Fresh motor in and no change, factory reset on unit as well with no change. Bummer....
Old 03-03-2017, 04:24 PM
  #11543
update:
Well sorry to hear that.....do you know how to get the RMA started?
Old 03-03-2017, 06:41 PM
  #11544
I do, but the problem is I bought it from a member on here. Last time I buy used electronics. Already ordered a new one. Not worth my time to have this one fixed at this point.
Old 03-04-2017, 07:04 AM
  #11545
Trader Rating: 24 (100%+)
Questions?? XR8 SCT
dogbone418 is offline
Old 03-04-2017, 03:10 PM
  #11546
Default XR8 SCT vs. XR8 Plus for 1/8 Buggy
I'm really happy with my XR10, so I'm looking at the XR8 for a new ebuggy. Is there a compelling reason to prefer the Plus over the SCT? Space is at a premium, so I'm leaning toward the SCT simply because of the smaller footprint. But reliability is paramount... a small ESC doesn't matter if it eventually sets my rig on fire.
Jason B is offline
Old 03-05-2017, 10:21 AM
  #11547
Is the footprint for the juststock the same as the stockspec?
Bubonic-X is offline
Old 03-05-2017, 03:49 PM
  #11548
rcuser67898578 is offline
Old 03-07-2017, 12:21 AM
  #11549
rgrg2's Avatar
Trader Rating: 48 (100%+)
Default XR10 Stock Spec
I had an issue with my XR10 Stock Spec. While on the track, it ran good for about a 1/4 of the track at a time, then it would lose throttle control, then throttle would kick in again. The light on the on/off button was flashing red, then when the throttle would work, it went green, but I had no brakes. Also, after pressing the on/off button, it wouldn't turn off until the throttle would catch, then using the on/off button it turned off.
Any suggestions on what's wrong and how to fix it?
rgrg2 is offline
Old 03-07-2017, 08:29 PM
  #11550
Hey there, I'm having and issue with my Justock (not the XR10, the previous version). I have an SCX10 and the ESC is making the truck drive in reverse. I've downloaded and installed the latest firmwares on both the ESC and the LCD programming box. The PC software has the option, but it is greyed out? How do I get this ESC to change the motor rotation? I tried to do this on the transmitter (Futaba 4PL) and then reclaibrate, but it doesn't matter, it still just goes in reverse I really want this thing to work!
DLE RC is offline
