HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree193Likes
Old 01-24-2017, 09:18 AM
  #11446
leking73's Avatar
I have to replace the fan on my xerun 150A ESC, to take out the fan your suppose to unscrew the 4 screws under the ESC and take the top off. Anybody know what kind of screw it is ? I cant see what kind of srew they are...
leking73 is offline
Old 01-24-2017, 12:58 PM
  #11447
Slotmachine's Avatar
Yes remove the 4 screws on top and unplug the unit, I think the wrench you need is a 2mm.
Originally Posted by hotrod87
Anyone reeplaced a rotor in a 3656 4000kv ? I have one with a bent shaft and I can't find a rotor anywhere?
If you dont end up finding a rotor then try the new motor they have for SC. #3652
https://www.hobbywingdirect.com/coll...sensored-motor
Slotmachine is offline
Old 01-24-2017, 07:24 PM
  #11448
Just bought an XR10 Stock Spec. Is there a reason why this thing has like a turbo boost that kicks in at a certain speed? New to racing and I have a Tekin ESC on my 1/8 scale and it doesn't do this. Also, when I try and set the slipper on my 1/10 scale....the motor just starts clunking and spinning instead of holding and lifting the front end up. Any info is greatly appreciated.
Shecki is offline
Old 01-24-2017, 07:47 PM
  #11449
gigaplex's Avatar
The boost and turbo settings are adjustable for use in stock boosted classes.
gigaplex is offline
Old 01-25-2017, 02:50 AM
  #11450
Thanks for the reply. Yeah, I've got it setup (with the wifi module) on the preset 17.5 settings and it's telling me boost isn't on. But then when I turn the car on, it's still doing it. Strange. Thanks for the input!
Shecki is offline
Old 01-25-2017, 03:04 AM
  #11451
Trader Rating: 43 (100%+)
put it in zero timing mode not the OPEN 17.5 or 17.5 BL mode. If your ESC is blinking red when neutral ...then your are in zero timing (no boost)
Phillip F is offline
Old 01-25-2017, 03:20 AM
  #11452
gigaplex's Avatar
To add to the suggestion to use the no timing preset, boost and turbo are two different settings. Did you check turbo was disabled too?
gigaplex is offline
Old 01-25-2017, 03:41 AM
  #11453
Set
default 17.5 meaning it still have both timing and turbo timing, if you want absolutely none of those choose blinky.
Set is offline
Old 01-25-2017, 04:42 AM
  #11454
Thanks for all of those replies. The ESC came set from the box in zero timing and that turbo or boost seemed like it was even worse when I pulled it right out of the box. That's why I switched it to 17.5 mode, hoping it would get better. Do you guys race with that boost/mode on? Seems like it would surprise you and kick in when you wouldn't want it to. I would think you'd rather just have smooth throttle control? I'll hook the wifi module back up this afternoon and see if I can get it out of there. Thanks again, guys!
Shecki is offline
Old 01-25-2017, 04:54 AM
  #11455
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
It sounds like a sensor issue. I had the same exact symptoms with a brand new Trinity monster 17.5. After changing out the sensor wire and double checking it was seated properly the problem still persisted. I swapped out the motor and the problem went away.
CCristo is offline
Old 01-25-2017, 05:02 AM
  #11456
I do not have a sensor wire hooked up. Could that be the problem? The motor I'm running with the car is Orions new vortex ultimate stock 17.5
Shecki is offline
Old 01-25-2017, 05:14 AM
  #11457
CCristo's Avatar
I think your problem will go away once the sensor wire is connected
CCristo is offline
Old 01-25-2017, 05:15 AM
  #11458
I got this from Orions Page on the manual for the motor....
So maybe it does need a sensor hooked up.
Shecki is offline
Old 01-25-2017, 07:27 PM
  #11459
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
can the juststock xr10s handle 13.5 1/10 4wd buggys?
Cain is offline
Old 01-26-2017, 04:55 AM
  #11460
Just to fill you guys in....sensor wire obtained. It fixed the problem. Thanks for all of your help!
Shecki is offline
