HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 01-06-2017, 08:47 AM
  #11356
Default XR8 SCT
Hi
I have purchased the XR8 SCT version from Amain and am wondering if the "2 in 1 Professional Program Box" hooked up to a PC.
I only need to change 1 or 2 settings and happy to do it over the PC if possible.
I have upgraded to the Latest November 2016 version: V1.13_131106
Thanks for your help
zzztech is offline
Old 01-06-2017, 12:54 PM
  #11357
chris c's Avatar
Trader Rating: 60 (100%+)
Anyone know if you can use the Wi-Fi link plugged into programming port while the esc receiver wire is plugged in without using the y harness?
chris c is offline
Old 01-06-2017, 01:33 PM
  #11358
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Got another XR8 SCT Pro installed and ready to go with a Tekin 4000Kv 540 4 pole motor in a Tekno SCT410.3 .
Anyone have any tips they recommend when using a hobbywing ESC with a tekin motor? Seems to run well and will be sufficient for my daughter (6) turned down.
Cain is offline
Old 01-06-2017, 01:34 PM
  #11359
Really interested in picking up a 81040250 combo I'm new to this so was that discontinued or something it's hard to find that combo for sale
Bad6as is offline
Old 01-06-2017, 01:50 PM
  #11360
Trader Rating: 39 (100%+)
Yes, I use the wifi module by plugging into the program port on my XR10s. No unplugging the ESC from the receiver or Y-Harness needed if your ESC has the programming/fan port.
AMessy is offline
Old 01-06-2017, 02:00 PM
  #11361
Tech Legend
Cain's Avatar
I am thinking it was discontinued as they have the new ESC and new motors out. For racing I probably would go with a 4000Kv combo myself. The 4700kv is stupid fast but I heard is also a pig on battery life. The 4000kv had excellent speed and power and was easier on the batteries.
Cain is offline
Old 01-06-2017, 02:12 PM
  #11362
Which combo would you suggest
We are limited to 2s
Bad6as is offline
Old 01-06-2017, 02:20 PM
  #11363
The ezrun max 10 sct combo
Bad6as is offline
Old 01-06-2017, 02:31 PM
  #11364
Trader Rating: 43 (100%+)
Originally Posted by flamingtire
I don't think there are many floating around yet. However, if you post this question on the HWNA Facebook page, you may get some assistance:
https://www.facebook.com/Hobbywing.NA
Same here. Keep us posted
Phillip F is offline
Old 01-06-2017, 03:44 PM
  #11365
chris c's Avatar
chris c is offline
Old 01-06-2017, 04:22 PM
  #11366
gigaplex's Avatar
Originally Posted by Grizzbob
Precisely, trying to measure pack voltage with the car on a stand simply will NOT put the proper load on it, so you won't notice much voltage drop. Honestly, the best way to measure that in ACTUAL running conditions & loads is to use data logging, like systems sold by Eagle Tree or some old Novak Sentry systems. I had a Sentry myself in the early days of our racing-wide switch to LiPo's(about 8-9 years ago), & I used it to chart the real differences between the older NiMh's we used to LiPo's, & with it I could see how much the voltage dropped under load of actual running(its software even let me see it & other measurements in real time in a playback mode). It's really the only proper way to measure it in the car.
He's not trying to test under full load, he's trying to test at minimal load to show that the ESC is giving vastly different voltage readings than the multimeter.
gigaplex is online now
Old 01-06-2017, 08:13 PM
  #11367
Default Hobbywing esc programming
Wifi module or program box and why?
Fbodykiller is offline
Old 01-07-2017, 11:29 AM
  #11368
Originally Posted by ashxxx
dual punch im usually mid 20 s each maybe a touch higher on the 2nd and if stock its 30 30 now the switch rate 50 is great for mod if im running stock i turn it all the way down to 1 makes me feel like i have more punch down low.
So if running stock... you have both 1st and 2nd punch at 30 (default) then on your switch rate, you go way down to 1 (default 50)
Old 01-07-2017, 11:51 AM
  #11369
Default Hardwire ESC switch
I have a hobbywing SCT pro. The switch it bad. Has red, black, and white wires. If I leave the white attached, and cut and connect the red and black. Will it be hard wired?
At the track now.....
Deton8er is offline
Old 01-07-2017, 04:26 PM
  #11370
rgrg2's Avatar
Trader Rating: 48 (100%+)
Default V3.1 and V4
Can someone please explain the differences in the Hobbywing V3.1 and the V4 esc's?
rgrg2 is offline
