HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 01-04-2017, 09:37 PM
  #11341
Trader Rating: 24 (100%+)
rcuser67898578 is offline
Old 01-05-2017, 09:15 AM
  #11342
Today did some more testing to see how much voltage drops under the load - as some of you noted that battery voltage under load should be lower - which is true - but question is HOW MUCH.
Here's the outcome:
1. battery idle voltage: 7.50V
2. trigger pulled gently (wheels barely rotate): 7.49V
3. trigger at full throttle: 7.38V
As you can see, in my case idle vs. full throttle is only 0.1V
Why I'm saying this? As I still think that ESC is misreading the voltage as in my case it was: 7.48V (multimeter) vs. 6.9V (measured by ESC).
Having said that I think that there's a bug in ESC firmware.
astianseb is offline
Old 01-05-2017, 09:24 AM
  #11343
howardcano's Avatar
Trader Rating: 37 (100%+)
Here's the outcome:
If you have the wheels off the ground, then you still don't have a load on the battery. Try measuring under full throttle from a standstill with the vehicle on the track. With the motors you mentioned in your first post, the load will be well over 100A under this condition, assuming no wheelspin.
howardcano is offline
Old 01-05-2017, 10:10 AM
  #11344
In my case it does not matter as in order to have reliable results you need to measure voltage in the same conditions - and in my case it was model standing on a pod (wheels off track).
I think that we pretty much exhausted this topic as to me results are quite apparent: ESC is misreading voltage on a battery. What would really help is if you can try to measure voltage on your ESC and compare multimeter read vs. ESC logger read.
Old 01-05-2017, 10:59 AM
  #11345
boner's Avatar
Does LVC kicks in when you are free wheeling on the bench? or is the esc's data giving a 6v reading during free wheeling on the bench while voltmeter is giving 7v?
If LVC kicks in during free wheeling or ESC's data voltage reading is 6v during free wheeling, there is high possibility ESC's LVC or voltage reading is malfunction.
If you are you looking for ESC to have LVC setting based on idle voltage(free wheeling voltage) there is a very high chance lipo will be damaged from over discharge if LVC setting is set at 3.2v/cell.
boner is offline
Old 01-05-2017, 11:12 AM
  #11346
YES
This is what I'm trying to prove for the last few days
Old 01-05-2017, 11:56 AM
  #11347
Can anyone tell me if Firmware XR-4.1.02 is the most current version for the XR10 Stock Spec ESC. Thanks
Whiskey63 is offline
Old 01-05-2017, 12:01 PM
  #11348
It looks that way. This link shows the current versions being used as well as archived past versions.
http://www.hobbywingdirect.com/pages/download
flamingtire is offline
Old 01-05-2017, 01:51 PM
  #11349
DJEckart's Avatar
Originally Posted by Slotmachine
The sct pro works best at 3.0 lvc, Ive run them for years and Have never destroyed a battery with this setting.
Upgraded and hooked up new HW Program Box, changed to 3.0 on LVC and also switched from Practice to Racing mode. Will see what happens tomorrow night
DJEckart is offline
Old 01-05-2017, 01:55 PM
  #11350
jbrook's Avatar
Trader Rating: 29 (100%+)
Hey Guys
Where do I find setups for the Xerun XR10 Pro? I checked Hobbywing USA and found two speedo setups but it was for astro turf 4wd and touring car. Looking for a 2wd and 4wd offroad sheet for a good starting point.
jbrook is offline
Old 01-05-2017, 02:21 PM
  #11351
Derry's Avatar
Trader Rating: 27 (100%+)
If you can connect up to the pc hobbywing software you can try to do a factory reset. I have rescued a few this way.
Well it was worth a shot. Didn't work, but hey the old 2.1 lasted for a good 4 years of abuse. Just ordered a 3.1 stock spec to replace it from Falcon. 99.00 nice!
Derry is offline
Old 01-06-2017, 01:41 AM
  #11352
Super Moderator
Grizzbob's Avatar
Precisely, trying to measure pack voltage with the car on a stand simply will NOT put the proper load on it, so you won't notice much voltage drop. Honestly, the best way to measure that in ACTUAL running conditions & loads is to use data logging, like systems sold by Eagle Tree or some old Novak Sentry systems. I had a Sentry myself in the early days of our racing-wide switch to LiPo's(about 8-9 years ago), & I used it to chart the real differences between the older NiMh's we used to LiPo's, & with it I could see how much the voltage dropped under load of actual running(its software even let me see it & other measurements in real time in a playback mode). It's really the only proper way to measure it in the car.
Grizzbob is offline
Old 01-06-2017, 01:45 AM
  #11353
Super Moderator
Grizzbob's Avatar
YES
And are you testing with a fully charged battery every time? Did you ever get around to adjusting the LVC to a more normal setting(like 6.4V)?
Grizzbob is offline
Old 01-06-2017, 08:34 AM
  #11354
Originally Posted by jbrook
Hey Guys
I don't think there are many floating around yet. However, if you post this question on the HWNA Facebook page, you may get some assistance:
https://www.facebook.com/Hobbywing.NA
  #11355
Yes, the V3.1 Stock Spec will not disappoint
