HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 12-03-2016, 06:28 PM
  #11191
Slotmachine's Avatar
I had a great day with the Hobbywing powered Losi 22.4 version 2. The 5.5 HW motor in blinky mode was doing wheelies so I loosened the slipper. I qualified 4th and finished in forth. I was as low as 9th and as high as 3rd in the race. I got the car running a fast lap of 17.5 in the main.
I love the Hobbywing equiptment am Im happy to represnt them.
By the way.....dont be afraid to try the coast feature on the XR10, it really helpedthe way my car jumped.
Slotmachine is offline
Old 12-04-2016, 07:14 AM
  #11192
Trader Rating: 14 (100%+)
Just installed two new hobbywing sct pro's the first one is doing great, but the second one cogs really bad, don't know if that is the right term but basically the motor doesn't know which way to turn until you apply about 50% power in either direction then it will run as it should. But as soon as you come to a stop it sets in position and grinds/cogs until you apply more throttle. I changed sensor wires to rule out a bad one but no luck??
barbwire44 is offline
Old 12-04-2016, 07:20 AM
  #11193
And I just disconnected the sensor wire and it runs fine? Did I get a bad esc?
Funny thing or maybe not so funny is I just went through this same thing last week with a tekin rx8 gen2 only difference was it wouldn't do anything unless you gave the car a push start then it would run. But they had me change a motor sensor to rule out the motor as the problem, esc shipped out for repair after.. But this is a new pro4 motor so I doubt it's a bad sensor.
Old 12-04-2016, 09:45 AM
  #11194
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
If you pull the sensor wire and try it out, how does it run?
Got your wires wired up correctly?
Cain is offline
Old 12-04-2016, 01:54 PM
  #11195
turbo2cam's Avatar
Trader Rating: 16 (100%+)
Need a little help please...Running a V3.1 Stock Spec in my 4mod and took a hard hit during practice yesterday and some how broke the plastic case on the ESC. Does anyone know the part number for a new case or know which cases are compatible? TIA.
turbo2cam is offline
Old 12-04-2016, 06:57 PM
  #11196
With no sensor wire it runs fine
Old 12-04-2016, 07:25 PM
  #11197
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
I emailed HWNA to special order a red metal case for my stock spec esc. The part is listed on their primary website, ESC Replacement case kit I would try emailing HWNA directly..
DriveItLikeYSIT is offline
Old 12-04-2016, 09:20 PM
  #11198
gigaplex's Avatar
Are you sure that's right? I don't think any of the listed ones there work with the stock spec.
gigaplex is offline
Old 12-05-2016, 06:29 AM
  #11199
Yes it will work; the hardware specs on the V3.1 and stock spec v3.1 are identical the only difference is the stock spec's case is plastic while the v3.1's is metal.
I don't know if the v2.1's plastic case will work..
Old 12-05-2016, 05:57 PM
  #11200
Trader Rating: 43 (100%+)
I got to test my XR10 pro stock spec 80a speedo thus powering my 13.5 wheeler. Wow! I was really impressed as the power was great, temps through out runs were perfa, servo performed flawlessly at the 6v setting. and brakes were great. I was a tad hesitant even though a fella whom is highly experienced with HW, and electric RC racing advised me that this speedo would perform great pushing my 13.5 wheeler as when I received the speedo I was amazed but worried as I did not exspect it to be super tiny and light. I ran 4 packs through with no issues, again power, braking and servo performance was spot on, temps were perfa throughout and the speedo is really smooth. I will post again after I run it some more.
Norse is offline
Old 12-05-2016, 06:08 PM
  #11201
gigaplex's Avatar
Interesting. The Hobbywing global website gives very different dimensions on their spec sheet. Their US site says they're pretty close, although one is taller.
gigaplex is offline
Old 12-05-2016, 06:25 PM
  #11202
I recently bought a sonic 2 9.5t and I am looking for an esc for it. Could I get away with the justock version or would that be too much motor for that esc to handle. I will be using this in my B5m if that helps.
Thanks Mark
charvel74 is offline
Old 12-05-2016, 06:39 PM
  #11203
Tech Legend
Cain's Avatar
sounds great on the esc in wheeler. Looking forward to hearing more!
Cain is offline
Old 12-05-2016, 07:45 PM
  #11204
bilster44's Avatar
Default Programmer boxes
Does anyone know if an Orion program box will program a Hobbywing ESC? I know a HW will not program an Orion though. Just wondering about the other way around.
bilster44 is offline
Old 12-05-2016, 07:56 PM
  #11205
Thanks Mark
You may be able to get away with it depending in the track surface, gearing, car weight, and driving style. The wires wil probably get warm (they are 14 awg) and the esc will as well. If you are going to try it just keep an eye on the temps. Personally I would just grab the V3.1 stock spec and don't look back
flamingtire is offline
