HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 11-08-2016, 06:20 AM
  #11086
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
It says dustproof on fiercercsolutions so figured that would be a tad better than not anything on the xr10 and still offers some timing capability.
I may give that a look once I decide what way to go.
Cain is offline
Old 11-09-2016, 01:13 PM
  #11087
chris c's Avatar
Trader Rating: 60 (100%+)
I have a good one...
I have a 120a v3.1 non stock spec that is acting up...
When i plug in the led program box it works and sends and receives info..
The esc is getting hot while hooked up to it ??? I soldered up with new wires, sensor wire and it wont turn the tires at all...Just coggs/wires get hot and so does esc...tried a different motor...same thing.. Doubt its the sensor wire..
Does anyone know what the average cost of repairs from HW
Bought it off a buddy who said worked fine (30.00)...looks to be in perfect shape..
Any ideas?
Chris
chris c is offline
Old 11-09-2016, 02:00 PM
  #11088
Tech Legend
Cain's Avatar
you pull the sensor wire (no wire at all, sensorless) and see if the esc works fine?
Cain is offline
Old 11-09-2016, 02:22 PM
  #11089
Slotmachine's Avatar
You can also hook it up to your p.c Hobbywing program and reset the speedo to factory, I recovered 2 speed controls this way and did not have to send them in.
Slotmachine is offline
Old 11-09-2016, 02:31 PM
  #11090
chris c's Avatar
Tried that same issue
chris c is offline
Old 11-09-2016, 02:32 PM
  #11091
chris c's Avatar
Ya did that also...didn't help...
chris c is offline
Old 11-09-2016, 04:04 PM
  #11092
Tech Legend
Cain's Avatar
yeah it getting hot to me means something is shot.
don't know how they do out of the warranty repairs, if at all.
Cain is offline
Old 11-09-2016, 08:46 PM
  #11093
Yes it sounds like you need to start the repair process.Falcon Sekido will take care of you.....
Old 11-10-2016, 09:08 AM
  #11094
Any ideas?
Chris
It does sound like something is damaged, but here are some things to try before working with a service repair:
1. Make sure the motor is wired up properly (A, B, C wires are all in the correct orientation).
2. Make sure there aren't isn't any solder "jumping" between any of the joints where they meet the ESC and motor.
3. Smell the ESC (yes, smell it). Does it have a "burnt" or "foul" smell? Most electronics have a unique smell when they are new versus when they are burnt up.
Personally I it sounds like there is a short in the ESC.
flamingtire is offline
Old 11-10-2016, 09:21 AM
  #11095
chris c's Avatar
Ya its all wired up correct..no burnt smell..just not sure if it is worth fixing if they charge a arm and leg..
Thanks all
chris c is offline
Old 11-10-2016, 10:39 AM
  #11096
Tech Legend
Cain's Avatar
if its out of warranty, heck i'd probably open it up and see what there is to see, post a pic.
Cain is offline
Old 11-10-2016, 12:01 PM
  #11097
chris c's Avatar
chris c is offline
Old 11-10-2016, 12:23 PM
  #11098
Default Rerun XR10 Pro
My Xerun xr10 Pro ESC turns back on every time I turn it off. Any ideas? Thanks!
lim202 is offline
Old 11-11-2016, 06:01 AM
  #11099
Thanks all
I had a friend racer have the same problem Wed. night.......try taking the sensor wire off completely and see if it works. His was heating up and when he pulled the trigger the motor wires moved.
Old 11-11-2016, 08:17 AM
  #11100
ta_man's Avatar
Trader Rating: 168 (100%+)
I recently had the exact same thing happen (motor wires moved when pull the trigger) and tracked it to an incorrectly wired sensor cable (one which I had never used before). The only reason I could tell for sure the sensor cable was incorrectly wired is that it was one of those flat ribbon cables and I could see that two of the pins were switched in position at one end. If you have a cable of all separate wires it could be difficult to tell incorrect wiring.
ta_man is offline
