HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree193Likes
Old 10-04-2012, 06:26 PM
  #1096
SavageSpawn's Avatar
Its it possible to use the techno mechanical break with the Hobbywing 150A esc? I looked at the manual and one option is forward and break. Could you dial the break to zero and configure the mechanical break some how?
SavageSpawn is offline
Old 10-04-2012, 06:59 PM
  #1097
Trader Rating: 48 (100%+)
I have a hobbywing 120amp on my losi 22 buggy..I was wondering if there was a way to add more brakes. I don't have any and I've tried maxxed out settings via the program card. still not enough
NitroLuver is offline
Old 10-04-2012, 07:28 PM
  #1098
megasaxon's Avatar
Trader Rating: 25 (88%+)
Originally Posted by FlyinRazorback
Getting back into the "hobby" after a 6 year hiatus and I'm pretty clueless to brushless tech (use to race nitro.) Anyways, I'm putting together a RC8.2e and looking at the different HW combos. Can anyone give me a little insight on the differences between these combos / motors?
M5A with the 4168SD motor
M6A with the 4274SD 2000kv motor
M6B with the 4274SD 2200kv motor
M7A with the 4274SD 1800kv motor
Thanks in advance.
i dont see a 4168 motor, you must mean 4068
here is a breakdown of the sensored motors they make for 1/8:
details tab... http://www.hobbywing.com/product_show.asp?id=240
the higher the KV value, the faster the motor is. A very common setup for 1/8 electric buggies is a Tekin 1900kv motor, gives plenty of speed but is tame enough for most to drive. Depending on your skill level and track size you may be able to safely run the 2200kv motor. If running a smaller track, like indoor or something like that i would recommend the 1800kv
megasaxon is offline
Old 10-05-2012, 03:56 AM
  #1099
FlyinRazorback's Avatar
Thank you.
FlyinRazorback is offline
Old 10-05-2012, 08:23 AM
  #1100
The xerun 120a v1 can handle brushless and brushed motor so can the xerun 120a v2.1 handle brushed motors too?
Tim-t is offline
Old 10-05-2012, 01:37 PM
  #1101
Gpeters66's Avatar
I have 150a hobbywing esc with a Tekin 1900. Out of nowhere it started cogging. All electrical connections look fine. I have no clue what else to look for. Anyone have any ideas?
Gpeters66 is offline
Old 10-05-2012, 02:07 PM
  #1102
Precision1's Avatar
Trader Rating: 51 (100%+)
If you run the nitro style Tekno clutch/clutchbell you can run mechanical brakes.
Don't know if you could make it work w/ direct drive & pinion.
Precision1 is offline
Old 10-11-2012, 04:34 AM
  #1103
nanoverse's Avatar
Blew a front bearing from my HW Xerun SD3656 motor and found the reason. The motor has these fins and the SCTEs plastic lip under the motor has to be dremeled so that the motor slips easily on the motor mount without force. I just thought the tolerances are tight!
Well got to change the bearings to ceramics from Avid at the same time.
nanoverse is offline
Old 10-11-2012, 04:29 PM
  #1104
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Try a different sensor wire and go from there.
Blitzrockey is offline
Old 10-12-2012, 01:08 AM
  #1105
Trader Rating: 20 (100%+)
Right on!
sbrewer is offline
Old 10-12-2012, 01:19 AM
  #1106
You should be able to set your break force to 0 on the esc, and then be able to use then techno kit
sbrewer is offline
Old 10-12-2012, 09:50 AM
  #1107
BigPar's Avatar
could you post a picture of the plastic part that you dremeled?
BigPar is offline
Old 10-12-2012, 02:37 PM
  #1108
Found my answer I installed V3_508_NO timing and the esc appears to be in the correct mode or blinky mode
Old 10-12-2012, 05:11 PM
  #1109
justpoet's Avatar
Trader Rating: 16 (100%+)
We had a Castle SCT kit with the 1410 3800kv 4 pole and the Sidewinder ESC.
The ESC went up like they tend to do, so I replaced it with a HW SC10.
It seems to run well, except that it doesn't always like to notice that it gets to neutral all the time. This has caused both a lack of ability to reverse at times and the concept of push control such that if it flips the wheels will keep spinning forward.
Ironically, the best way to make it seem to center more often is to set some forward trim after the esc is calibrated. I've tried a different controller too, and both work fine with my Castle, Tekin, and other HW ESC's. Any thoughts? I personally just work around it, but this is being set up for somebody brand new to the hobby.
justpoet is offline
Old 10-13-2012, 06:50 PM
  #1110
Kevin_M's Avatar
SCTPro and the 4700Kv motor was great today. I ran an ok race baring my bobbles. I ended up finishing 3rd in B main today. This combo has plenty of power and when I temped the motor after the run I was about 125-127.
Kevin_M is offline
