HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree193Likes
Old 11-01-2016, 06:42 AM
  #11056
hotrod87's Avatar
Trader Rating: 252 (100%+)
Yep. Just like every other one I've had non sensored usually takes a second to catch rotor position but sensored is instant. I personally don't like them set up that way though when running trail it sucks because brake is hard to hit right when coming downhill etc. it's either to much or not enough. I run fwd/rev with brake in my wraith and scx's. Full comp crawler rig is a different story. Gotta go instant and hope you can get enough brake. I think that's where low if high voltage comes in.
hotrod87 is offline
Old 11-01-2016, 07:21 AM
  #11057
Originally Posted by LVNeptune
Program card does in fact work on the justock
You are saying the old style program card works on the new XR10 JuStock?
flamingtire is offline
Old 11-01-2016, 07:37 AM
  #11058
Originally Posted by Scargoes
Is there any built in timing on the G2 motors? Specifically the 17.5? I currently run mine with the end bell at 50*.
I was reading that the Bandit motor comes with 20* built in and the end bell set at 30* for a total of 50*.
Normally what companies mean by "build in timing" is that, from the factory, the end bell when in the normal position, will show 20 degrees of timing and that is what the motor is "set at." The end bell still 100% determines the timing unless you factor in Boost/Timing from the ESC.
Where did you read that there will be a total of 50 degrees of timing from the factory? There may be a typo. I don't see it anywhere on the "Bandit" page of the HWNA website:
http://www.hobbywingdirect.com/produ...run-v10-bandit
Old 11-01-2016, 07:50 AM
  #11059
Yes, I will take a video later if I remember.
LVNeptune is offline
Old 11-01-2016, 09:45 AM
  #11060
Slotmachine's Avatar
Hobbywingdirect.com is up...
Slotmachine is offline
Old 11-01-2016, 10:54 AM
  #11061
I'll have to look when I get home. It'll be a while as I'm on a business trip. But the paperwork that came in the box was not the same as what is posted on the website. It stated that there was 20* built in and the motor was set to 30*. I don't remember the actual verbiage but it appeared to me to imply that there was 50* total on the motor. I could be wrong. But as it sits, the Bandit set at 30* on the end bell is the same speed at the G2 at 50*. So I was wondering if I could safely add more timing to the Bandit. I know 54* on the end bell of my Team Powers was the max, any more and you risked melting the motor.
Scargoes is offline
Old 11-01-2016, 11:03 AM
  #11062
Do you have a motor analyzer? Easiest way to confirm. I never trust anything anyone says. :P
Old 11-01-2016, 09:49 PM
  #11063
https://www.youtube.com/watch?v=8RsACkxBQTU
Old 11-01-2016, 10:03 PM
  #11064
gigaplex's Avatar
Built in timing usually means that the timing written on the end bell isn't the true timing. For example, two different manufacturers might ship motors at 20 degrees timing. But Manufacturer A might have the endbell label tuned to read 20 degrees at a true 20 timing, and Manufacturer B might have the label read 0 degrees at a true 20 timing. This offset is often referred to as the 'built in' timing.
gigaplex is offline
Old 11-01-2016, 10:06 PM
  #11065
Not sure why this is hard for people to understand. If you have 20* of built-in timing add 20 to whatever you bell is set to.
Old 11-02-2016, 06:19 AM
  #11066
JatoTheRipper's Avatar
Thank you.
Yes, but hobbywing.com is not and hasn't been for at least the past two days. It's odd for a major manufacturer's site to be down that long.
JatoTheRipper is offline
Old 11-02-2016, 08:09 AM
  #11067
Wow, this is awesome. I stand corrected, this is good news!
Old 11-02-2016, 08:14 AM
  #11068
Because that's not always true... lol
Old 11-02-2016, 03:09 PM
  #11069
gigaplex's Avatar
So if you have 20 degrees of built in timing there are occasions where you're not supposed to add 20? What did you mean by that?
gigaplex is offline
Old 11-02-2016, 10:49 PM
  #11070
Super Moderator
Grizzbob's Avatar
Originally Posted by JatoTheRipper
Thank you.
I don't know what the deal is with their original site, but this one is all we need in the US: http://www.hobbywingdirect.com/?gcli...FYIlgQodgY0Fow , & it's working just fine....
Grizzbob is offline
