HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 06-20-2016, 09:58 PM
  #10636
Default Quicrun 10bl60 reverse to sudden
Is there any way to make my esc go into reverse more smoothly? When going from forward to reverse in a crawler setup it always has a burst. This only happens on the first input. Going from reverse to neutral to reverse gives me a smooth porportional reverse. I have tried all the programming options and I think this may be a feature that can't be fixed It really sucks when I want to make a small backup on a hill and my crawler jumps backwards. Even with massive expo on the transmitter it still happens.
jtthebiggafigga is offline
Old 06-20-2016, 11:32 PM
  #10637
MeasuresMicrons's Avatar
Default Error Code
Heres the error code I received when I tried to D/L the software for the USB Link from the HW site. Anyone have or see this and know the solution Please?
Thanks.
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-error.jpg
MeasuresMicrons is offline
Old 06-21-2016, 12:56 PM
  #10638
Kremzeek's Avatar
Thanks.
Run it as administrator?
Kremzeek is offline
Old 06-21-2016, 01:00 PM
  #10639
Yea I have, I also tried a new USB plug and won't connect to the PC. I'm thinking maybe the USB port on the card is defective. It appears as though it wants to load but just won't connect.
Old 06-21-2016, 10:45 PM
  #10640
SpidarX's Avatar
Thanks.
I have run into this same problem trying to install the usb link software.
SpidarX is offline
Old 06-22-2016, 07:29 AM
  #10641
You definitely have to run it as an administrator in order to get it to work. I got mine straightened out with the help of DriveItLikeYSIT (thanks man) But my issues lie within the LCD Box, I really have to mess around with the USB port on the box to get a tight fit and load. I'm going to contact HW and see if they'll replace or repair, this is a BN unit I purchased from Amain.
Old 06-22-2016, 12:32 PM
  #10642
You would have a better chance and quicker response via Amain than through HW for a replacement.
brew99 is offline
Old 06-25-2016, 12:15 PM
  #10643
dtr
dtr's Avatar
Will we ever see an improved SCT pro with a HV BEC? The XR8 is just too big and overkill in most aspects for a light e-buggy.
dtr is offline
Old 06-27-2016, 08:34 PM
  #10644
Trader Rating: 24 (100%+)
rcuser67898578 is offline
Old 06-27-2016, 11:17 PM
  #10645
Suspended
Does any one know if we will see a Mac compatible software download?
Cmgreen is offline
Old 06-28-2016, 03:34 PM
  #10646
figured my problem out nevermind
topdog11ttc is offline
Old 06-28-2016, 04:58 PM
  #10647
Default XR8 not calibrating with 4PLS
I have an XR8 combo I'm trying to get working with a Futaba 4PLS radio. I have updated ESC firmware to the latest version. When I try to calibrate ESC for throttle/brake, I get to step one where neutral flashes once then I get stuck. ESC light goes off (ESC stays on) and I can't calibrate for throttle or brake. I have followed instructions in manual several times but same thing happens each time. Need help please. Thank you in advance.
comfixco is offline
Old 06-28-2016, 09:06 PM
  #10648
Slotmachine's Avatar
try reversing the throttle switch in the radio then try to calibrate it again.
Slotmachine is offline
Old 06-29-2016, 06:53 PM
  #10649
Default Quicrun 150amp not working
Ran my quicrun for an hour after installing it on 6s and wverything was great. the following day i took it out again and ran it less than ten minutes and it completely died and nothing. Doesnt turn on or anything. Have brand new brushless motor and brand new 35c 5500 mah dual 3s batteries. It appears the capacitors went and eventually took the esc out. Although i never heard a pop or seen any type of smoke at all. Temps of esc and motor didnt exceed 95 degrees when immediately checked to example how short a run i had. Is this esc not truly capable of 6s? Does it need an added cap pack ahead of it? Ripple effect? Battery wires and esc wires are all factory length. Running 2000kv and 18/46 on 1/8 buggy weighing 8lbs loaded. Or did i just get a defective one out of the box?
Uguessedit is offline
Old 06-30-2016, 06:47 AM
  #10650
Set up help for the SCT Pro Please. This thing is a beast, running an SMC 4500 on 16T stock spur. in an Tekno SCT410.3 7/7/3 oils. I've dialed the punch way down and pulled some of the acceleration out of the Tx, looking to see if theres anything else I can do before I tear the diffs down for an oil change.
