HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree193Likes
Old 06-18-2016, 05:12 PM
  #10621
MeasuresMicrons's Avatar
Awesome, thank you!
Originally Posted by Johnny-RC
The USB Link software is an all inclusive PC app that supports many different Hobbywing ESC's. When your ESC is properly connected to your PC trough the programing box, the USB Link software will recognize which ESC you have and give you a list of appropriate firmware's that can be flashed to the connected ESC.
Download the latest version of the USB Link software here...
http://www.hobbywing.com/article.php?id=162
MeasuresMicrons is offline
Old 06-18-2016, 07:39 PM
  #10622
Kremzeek's Avatar
Does anyone know if Hobbywing sells replacement sensor modules for the Xerun 3656 4700kV?
Kremzeek is offline
Old 06-19-2016, 11:03 AM
  #10623
Slotmachine's Avatar
Originally Posted by jrz93
Yes, I have servo but esc doesn't work. All it does is flash green 3 times over n over
Any ideas? If not I'll send it in
Try plugging your speedo into the steering slot of your receiver , maybe you're not getting a radio signal to your throttle side. Another thing that might do it is create a new model in your radio.
Slotmachine is offline
Old 06-19-2016, 12:04 PM
  #10624
Multifunction Box stays at "Connecting ESC" Any thoughts? Latest reads " Connecting PC" Still nothing. I think it may be the box.
Old 06-19-2016, 12:34 PM
  #10625
I really need to pay attention....Thanks for this. More degrees then a dam thermometer and I can't follow directions.....go figure!
Originally Posted by Slotmachine
You do know that you plug the program card into the fan port and not into the receiver wire from the speedo?
Old 06-19-2016, 02:26 PM
  #10626
Well thats what we're here for........Im happy you got it working.
Old 06-19-2016, 02:44 PM
  #10627
I got it work off the program box but can't with my laptop, something isn't hooking up right.....I did receive an error code the first couple times I try to load it but just won't sync....is there anything the PC does that the box can't?
Old 06-19-2016, 02:57 PM
  #10628
I am racing with the Tekno SCT 410.3 and have the Hobbywing Xerun SCT Pro speedo and Hobbywing 3656 4000kv motor with gearing at 16 tooth pinion and 44 spur. Every time I run my truck, I get red and green lights flashing simultaneously after a few minutes. According to the troubleshooting guide in the manual, that is overload protection. I have tried 15 and 17 tooth pinions and still happens. I have put in a new sensor wire and made sure it is fully pushed in. Also had someone else check my soldering job and he said it looks good. What else might I try? Only have 2 races on the speedo and 4 races on the motor.
bigdaddy83 is offline
Old 06-20-2016, 09:25 AM
  #10629
OttoKrosse's Avatar
Trying to reprogram my ESC and a new 3-1 HW program box with the 4.0.1 firm ware / soft ware package. Downloaded the USB link, plugged everything in but can't get the box to read that it's connected to the PC. It connects to the ESC just fine, even after changing to different USB outlets I can't seem to muster up a connection to the PC.
Can someone direct me to some clear instructions on how to do this update with Windows 7?
OttoKrosse is offline
Old 06-20-2016, 09:32 AM
  #10630
I'm having the same issues with Windows 8
Old 06-20-2016, 05:27 PM
  #10631
Try another usb cable........
Old 06-20-2016, 05:30 PM
  #10632
Turn your LVC to 3.0 and take your cell detecti9n off of automatic.
Old 06-20-2016, 05:35 PM
  #10633
I currently have the LVC set to off and have the cell detection on 2s lipo.
Old 06-20-2016, 05:39 PM
  #10634
Thanks, I'll give that a shot when I get home. I had some trouble D/L'ing the USB Link software, kept getting a Unable to Execute fole error, no matter what I tried....even dl'ed at work, same thing
Old 06-20-2016, 08:14 PM
  #10635
Can Hobbywing repair an ESC that has been connected to the battery backwards? If so, what is the estimated cost? StockSpec 3.1. I took off the cover and nothing looks burnt...
40yoCaliRacer is offline
