HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 06-16-2016, 03:08 PM
  #10606
jrz93's Avatar
Default xr8 flashing 3 times
i hope i dont have to send this in as i just got it and used it 2x
I plug it in and it just flashes 3 times over and over and wont connect to lcd box?
i never got a manual as it was and upgrade from Falcon sekido
jrz93 is offline
Old 06-16-2016, 06:36 PM
  #10607
Slotmachine's Avatar
You do know that you plug the program card into the fan port and not into the receiver wire from the speedo?
Slotmachine is offline
Old 06-16-2016, 07:17 PM
  #10608
fat500's Avatar
Trader Rating: 51 (100%+)
is no one using this tuning aid
I will test and post
fat500 is offline
Old 06-17-2016, 01:13 AM
  #10609
Trader Rating: 43 (100%+)
recently got a Hobbywing XERUN XR10 Justock ESC..... how to you get more brake from this thing? I don't want drag brake.... I need more brake.
thanks in advance. Also I have the Multifunctional LCD Program Box.
Phillip F is offline
Old 06-17-2016, 04:50 AM
  #10610
jrz93's Avatar
Yes, I have servo but esc doesn't work. All it does is flash green 3 times over n over
Any ideas? If not I'll send it in
jrz93 is offline
Old 06-17-2016, 08:08 AM
  #10611
If you have the Multifunction Program Box it's very easy..
1. Connect the ESC to the JuStock (use the wire that runs to the receiver).
2. Power up the RC. The box should turn on, state the version, and eventually go to the programmable options.
3. Push the "Return/Item" button until you get to "max brake force."
4. Push the value button to select a higher value.
5. Push the okay button (esc should state that that the changes have been made)
6. Power down the RC.
7. Hook the wire you plugged into the box back up to your receiver and enjoy.
You can also adjust your drag brake via this method. Just select a lower value from the "Drag Brake Force" setting.
flamingtire is offline
Old 06-17-2016, 08:14 AM
  #10612
Here is your manual:
http://www.hobbywing.com/products/en...RunXR8Plus.pdf
And here are what the "LED indicators" signify:
-1. During the Start-up Process
1) The RED LED keeps flashing rapidly indicating the ESC doesn’t detect any throttle signal or the neutral throttle value stored on your ESC may be different from the current value
stored on the transmitter.
2) The GREEN LED flashes “N” times indicating the number of LiPo cells you have connected to the ESC.
-2. In Operation
1) RED & GREEN LEDs die out when the throttle trigger is in the throttle neutral zone.
2) The RED LED turns on solid when your vehicle runs forward. The GREEN LED will also come on when pulling the throttle trigger to the full (100%) throttle endpoint.
3) The RED LED turns on solid when you brake your vehicle, the GREEN LED will also come on when pushing the throttle trigger to the full brake endpoint and setting the “brake
amount/maximum brake force” to 100%.
4) The RED LED turns on solid when you reverse your vehicle.
-3. Some Protection is Activated
1) The RED LED flashes a short, single flash that repeats (☆, ☆, ☆) indicating the low voltage cutoff protection is activated.
2) The GREEN LED flashes a short, single flash that repeats (☆, ☆, ☆) indicating the ESC thermal protection is activated.
3) The GREEN LED flashes a short, double flash that repeats (☆☆, ☆☆, ☆☆) indicating the motor thermal protection is activated.
4) The RED & GREEN LEDs flash a short, single flash that repeats (☆, ☆, ☆) at the same time indicating
Old 06-17-2016, 08:37 AM
  #10613
Thank yiu for the quick response.
I also need to know what should be the latest version software running on the multifunction LCD program box?
Old 06-17-2016, 12:46 PM
  #10614
I'll tell you what I have it set at, but can't really comment on the effectiveness as a tuning aid. I run on carpet, so high bite, and have increased them up around the 20-25 mark (if I remember correctly). My switchover is at 50% also, so no magic there.
I really think that this setting would benefit an individual, if they were switching tracks and levels of bite, but as I said, I stick basically to one consistent surface.
Lower the level down to eliminate wheels spin on a loose surface, raise it up to get more punch when track conditions allow.
brew99 is offline
Old 06-18-2016, 12:13 AM
  #10615
JAE
Trader Rating: 30 (100%+)
Anyone shed some light on the differences in feel of their esc's. Personally, I love them. But, my justock had thre smoothest brakes, but sometimes not quite enough.
My V3.1 stockspec had the strongest brakes. Epa is currently turned down to 40 percent. I love this esc.
V3.1 120 amp is middle of the road. Great too.
In any event, anyone else here notice the difference in the three?
Btw - I'm going to test out a Tekin rsx I have laying around. Anyone have any balanced opinion on what one should expect regarding differences in feel?
JAE is offline
Old 06-18-2016, 09:56 AM
  #10616
Trader Rating: 137 (98%+)
dual punch im usually mid 20 s each maybe a touch higher on the 2nd and if stock its 30 30 now the switch rate 50 is great for mod if im running stock i turn it all the way down to 1 makes me feel like i have more punch down low.
ashxxx is offline
Old 06-18-2016, 10:07 AM
  #10617
OttoKrosse's Avatar
Running Hobbywing V3.1 ESCs and just bought a new 3-1 Hobbywing programming box and after going to their website for updated software...ETC.
I see a huge list of software choices and I'm confused as to which update is designed for the 120a V3.1 ESC. I run 17.5 Touring Car and want the latest software that will work with my V3.1.
Thanks in advance.
OttoKrosse is offline
Old 06-18-2016, 10:56 AM
  #10618
MeasuresMicrons's Avatar
I have the SCT Pro, XR8 Plus and the Stock Spec v3.1 ECS's (all new). I do have the program card but not sure what D/L I need from the HW site in order to check them all out. I know with the Castle Crap theres only one D/L. Is there one I need for these or more then one?
Thanks.
MeasuresMicrons is offline
Old 06-18-2016, 11:03 AM
  #10619
fat500's Avatar
thanks
fat500 is offline
Old 06-18-2016, 01:33 PM
  #10620
Trader Rating: 24 (100%+)
rcuser67898578 is offline
