HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 06-12-2016, 06:47 PM
  #10591
Trader Rating: 14 (100%+)
Blew both caps on my 120A esc, they were rounded for some time and they fianlly let go. ESC still operates (havent ran a eace soince the pop though).
Can these be accesses or is it under the sandwich board?
ctrenks is offline
Old 06-13-2016, 07:13 AM
  #10592
Originally Posted by KahrsRacing
Could some tell me what fan (part#) is the replacement for the xr8. I have a fan in my XR8 that must have got a rock in and broke a fan blade or two. I can't seem to find what replacement fan I need to buy and where I can buy it. I appreciate anyone's help. Thanks!
Give me a second, I answered this question back in February. I will dig up the post. I'm 90% sure its the same one that is used in the SCT ESC, but let me confirm.
flamingtire is offline
Old 06-13-2016, 07:19 AM
  #10593
Here you go:
"From my research it looks like part number 86080080 is what you are looking for. Don't hold me to it, but the specs for that one appear to be in line with what the XR8 calls for."
Old 06-13-2016, 12:06 PM
  #10594
allaboutwho02's Avatar
Trader Rating: 45 (98%+)
Anyone had any issues with these servos?
Turnigy TGY-5521MDHV
allaboutwho02 is offline
Old 06-13-2016, 06:25 PM
  #10595
Originally Posted by Madulla
Question about the WiFi adaptor. I tried using it on an older Stockspec and a 3.1 1s. After I change the settings and disconnect using the app the car will still not go. I need to unplug the battery in order to reset the esc to get it to run again. I have not connected up my XR10 yet, but does this happen on the older escs. I hoped to change the settings on the drivers stand and go, but I can't get that to work on the older escs.
I am impressed with the new tech. Easy to use and update/program in a single app. Easier to use than the box, about the same if you use the computer just quicker and less connections
I am having same problem with 3.1 120A. Any fix yet ?
Rick442 is offline
Old 06-13-2016, 07:09 PM
  #10596
fat500's Avatar
Trader Rating: 51 (100%+)
Default Hobbywing v3.1 dual punch settings
Please post what your first and second punch settings are, what class/car you run and what you feel works best for you thanks
trying to get some ideas
fat500 is offline
Old 06-14-2016, 10:15 AM
  #10597
Having a problem with the USB Link software on a Surface Pro 4. I have come to the following conclusion on this. The Surface Pro 4 uses the new UEFI 3 bios that isn't compatible with Int10 devices any more. This causes the LCD Program Box to not be installed with a driver. It's easy enough for me to use a Windows 10 device with an older bios, but moving forward all motherboard BIOS's will be using the new bios technology that will prevent the correct detection and installation of the program boxes. I've been in contact with HW but it's like talking to a wall and they insist it works fine. It does not. So if you plan to use this on a computer with the new bios technology...you're screwed. So much for having a compact and expensive as hell computer at the track to help with programming my HW...sigh.
Carnage9270 is online now
Old 06-14-2016, 11:42 AM
  #10598
Just get the new wifi module. It allows you to upgrade and program your ESC wirelessly. I'll have it a galaxy if you want to check it out. The interface is very similar to the PC interface.
malkiy is offline
Old 06-15-2016, 06:37 AM
  #10599
I have been racing my xr10 juststock esc for about a 3 weeks and I feel the brakes are very weak. It set at 50% brake and 20% initial and won't lock the tires. It doesn't feel normal coming from my tekin gen2 esc.
Is there updated firmware for the esc to help this problem. Or is it normal ?
cbarros82 is offline
Old 06-15-2016, 06:48 AM
  #10600
My Xerun SCT pro and batteries seems to heating up more recently in my SCTE. Probably a combination of factors including drive train, motor, style, ambient temperature, etc. Wondering if external capacitor bank like this Hobbywing Xerun Super Capacitor Module might help.
Any chance someone who's installed an external capacitor bank could post a picture to show their wiring configuration in their rig?
stelio279 is offline
Old 06-15-2016, 06:47 PM
  #10601
Slotmachine's Avatar
The first thing you should do is turn the brake force up to 100% then the tires will lock up
Slotmachine is offline
Old 06-15-2016, 06:49 PM
  #10602
You just solder it to the + and - poles at the speed control.
Old 06-16-2016, 11:42 AM
  #10603
FYI, Turnigy is not a HobbyWing brand. Turnigy comes from Hobby-King's distribution.
Old 06-16-2016, 11:44 AM
  #10604
I believe I run all my JuStock ESC's at 75% brake. I then adjust accordingly on my radio. On that note, make sure your radio is properly calibrated to your ESC.
Old 06-16-2016, 02:14 PM
  #10605
EJ2civic's Avatar
First of all, whats your gearing? Second, you can add a "Glitch Buster" cap in line at the + and - terminals on your ESC. The cap should be 5000uF or higher.
EJ2civic is offline
