HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 05-03-2016, 11:07 AM
  #10501
mudbug85603's Avatar
Put my spare 1st generation HW Max8 in one of my vehicles today. Checked the setting via program card. The LVC was set to disable, So I put all the settings back to default. Ran the truck, NO LVC kicked in, even though the low voltage alarms on the balance plugs started beeping at 3.5 volts. Put a charge back into the batteries, reset the LVC to HIGH, ran the truck still no LVC kicked in. Tried the other settings and the same thing, no matter what the settings were.
Running 2 SMC 2s 6500mah 60c batteries wired in series and know they are good
What's going on? am I missing something? is this one gonna have to be RMA'd too?
mudbug85603 is offline
Old 05-03-2016, 12:13 PM
  #10502
Trader Rating: 12 (93%+)
I am having a issue with my program box. When i plug it in widows says it does not recognize it. I have tried 2 computers any suggestions ?
Scottysspeedsho is offline
Old 05-03-2016, 07:50 PM
  #10503
Slotmachine's Avatar
Why would you want the LVC so high? I think I would try to set the speed control and ignore the ones on the plug of the battery. We set ours at 3.0 or 3.2 and have never destroyed a battery. Give it a shot, I dont think anything is wrong with the unit.
Paul
Slotmachine is offline
Old 05-04-2016, 01:52 PM
  #10504
Just bought a used V3.1 and got some issues.
I downloaded the USB Link and pluged in the Program Box. I pluged the ESC to it and pressed On, but nothing happened. After that I switched an device "LCD programm Box" and upgraded the latest firmware. After that the LCD of the programming box just shows boxes in the first line of the display. I didnt disconnect anything - what went wrong?
The USB Link shows for the LCD Device a green dot for the LCD program box!
Edit: I think I kinda messed up the Program Box Firmware - any chance for "repair"?
Edit2: I tried to reinstall the old firmware that was shown on first connect, (V1.11_120331_V3). The upgrade goes up till 50% and then the small windows closes. Thats all!
Edit3: Restart PC & Execute as admin and no it works.....DUH
man1ac is offline
Old 05-05-2016, 10:01 AM
  #10505
Same problem I am having
Old 05-05-2016, 10:23 AM
  #10506
Trader Rating: 18 (100%+)
I think I had a similar problem with V3 Stock Spec and SCT Pro (LCD box). I unplugged the ESC from my receiver first. After that everything worked.
rcnewbie418 is offline
Old 05-05-2016, 10:57 PM
  #10507
Question about the Bandit 21.5 G2. I just ordered one to run in my local 21.5 Blinky Outlaw Touring Car class. I want to run the largest rotor possible and I ordered it with the 13.5mm rotor but it doest not fit inside the stator. I thought this motor came with a 13mm rotor to begin with but to my surprise it came with a 12.3mm rotor and by the looks of it I dont think the stator will fit anything larger than a 12.5mm but I want to be sure before I send the rotor back to amain for an exchange or a refund if there isnt an upgraded rotor option for this motor.
nttdemented is offline
Old 05-05-2016, 11:25 PM
  #10508
Hello!
I purchased a new Xerun XR10 Justock ESC a few days ago (April 30, 2016). First ever brushless system for me. It's connected to a Reedy Sonic Mach 2 17.5t motor. I was testing the installation and noticed that when I'm just barely applying throttle the motor/car appears to "stutter" but this disappears once I apply just a little more throttle. Additionally, when I immediately squeeze the throttle (100%) from a stop, the car seems to hesitate for maybe half a second and then appears to accelerate to full throttle. The ESC only does this from a stop, while driving the car at speed, throttling up and down and applying brake/coasting I do not notice the acceleration lag.
I am running the ESC in factory default-- no programming applied. I calibrated the ESC according to the instruction sheet.
Is the stuttering and acceleration lag typical behavior for a sensored brushless power system?
XR10 Justock ESC
Reedy sensor wire connected to motor and ESC
Spektrum Dx2E Tx/SR310 Rx
Thanks for any advice!
i_r_beej is offline
Old 05-06-2016, 01:34 AM
  #10509
Hello, While using my SCT pro ESC it cut off after 5 minutes. On first inspection both the ESC and motor were cool but the RC wouldn't move. I've tried using a different battery and this made no difference and checked all the wiring. When turning the ESC on the lights light up and I'm able to turn the servo, I'm also able to calibrate and program (via box) the ESC. The only differences is that it no longer beeps when It's connected to the controller or when I re-calibrated it. I've looked in the manual and I can't see anything that is related to it no longer beeping. Please could you advise on the best cause of action.
Here's a quick video...
https://www.youtube.com/watch?v=nUyOFj2Juq4
Millsy97 is offline
Old 05-06-2016, 05:19 AM
  #10510
Trader Rating: 36 (100%+)
Originally Posted by i_r_beej
Hello!
XR10 Justock ESC
This kind of behavior is typical of a sensor issue. Are you sure your sensor wire is plugged in all the way? If you have another sensor wire try it too.
nitrousdave is offline
Old 05-06-2016, 06:17 AM
  #10511
DirkW's Avatar
No, actually quite the opposite. That's what a sensorless system typically behaves like. Make sure the sensor cable is properly connected on both ends.
DirkW is online now
Old 05-06-2016, 10:58 AM
  #10512
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
HWNA is accepting pre-orders for the wifi-express module
DriveItLikeYSIT is offline
Old 05-06-2016, 11:04 AM
  #10513
Paul
Well, just updated the firmware in all my Max8's it solved the problem. So obviously there was a glitch in the esc itself.
The reason I was running the LVA is that without the LVC functioning the cell voltage in one battery dropped to 3.1 and still no Low voltage cut off from the esc. So it's not that I want the cut off so high, just functioning as it should. Max8 doesn't have a programmable setting for a specific voltage like many other HW ESC's. With it, you must program cell count (4, or 6) then you have a choice of Disable, High, Intermediate(Auto), Low.
Old 05-06-2016, 12:55 PM
  #10514
@Nitrousdave and @DirkW: I'm using a brand new Reedy sensor wire (purchased at the same time as the Justock ESC). I do believe that it is properly seated, but I will double check that later today.
Also, could my battery be a limiting factor? I was re-reading the Justock's documentation this AM and it mentions that a battery that is unable to deliver sufficient current will cause exactly the symptoms I am seeing.
I am currently using a 4000mAh 20C LiPo.
Supposedly the XR10 Justock is a 60A ESC (is that a continuous draw? and it is able to draw 320A in bursts) and the battery is able to deliver 80A (in theory). According to Reedy/AE the Sonic Mach2 draws 28A (192W). So far it seem that the battery should be able to provide what is needed. Perhaps barely. So perhaps I will start by reducing the "Punch" setting and see if this makes a difference.
Unfortunately my understanding of electrical principles is severely lacking (but I'm working to educate myself) so I'm still unable to properly calculate anything.
i_r_beej is offline
Old 05-07-2016, 06:43 AM
  #10515
I don't have an answer to your question except to try and readjust the settings within the ESC.
Sometimes I've found to get the best advice it's best to contact the tech support people for what ever product it may be, Here's a phone number for Hobbywing NA 1-800-720-2351.
Good luck, I'm sure it's just something simple
