HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 04-21-2016, 06:01 AM
  #10486
I have the hobby wing ezrun 4000kv motor and esc. I run dirt oval on a slick dusty track. This combo is in a new tekno 410.3. Truck is stock and I run a 18 tooth pinion. This motor rocks!!!. I bought this combo last Aug and has put me in the win side many times. Last night the end of the rotor shaft broke off!!! It broke about 1/16" just outside of the end bell. Been racing a lot of yrs and have never seen this happen before. I run value 1 on the timing and punch set at value 3. No brake. I thought maybe a little Rock jammed in the spur but upon examination the spur and pinion look like new yet.
Is something like this a warranty issue or do I have to bite the bullet and buy a new motor?
1Radman is offline
Old 04-25-2016, 05:34 PM
  #10487
Slotmachine's Avatar
I'm not sure if it would be under warranty but since they are such great motors it would be worth contacting them. The only thing I can think would be a rock did get into the mesh.
Paul Rush
Team Driver
Slotmachine is offline
Old 04-26-2016, 11:35 PM
  #10488
Trader Rating: 21 (100%+)
Can someone from HW please send me a RMA so I can send in my HW sct pro esc that's not working. I have sent in the online RMA request nearly 2wks ago and still no reply.
joel45acp is offline
Old 04-27-2016, 05:56 PM
  #10489
Sorry you are having difficulty. .....I would write them again to be sure. It shouldn't take this long.
Old 04-29-2016, 01:13 AM
  #10490
tsair's Avatar
What 2WD buggy servos are you guys using with a $50 Justock ESC? 2A doesn't seem like enough to push a Savox 1257/1258TG, and I wasn't able to run my Hitec 5565mh (2.1A stall current) either. I'd really prefer not to use a glitch buster or external BEC.
tsair is offline
Old 04-29-2016, 04:10 AM
  #10491
I have a Juststock esc combined with my 1258tg installed in my stock class ST. It is a 22T with a Reds VX 17.5 motor. I have never noticed any issues except my driving or lack there of...
freezeframe007 is offline
Old 04-29-2016, 04:49 AM
  #10492
JayBee's Avatar
Trader Rating: 31 (100%+)
JayBee is offline
Old 04-29-2016, 09:44 PM
  #10493
I have had to use a glitch buster in the past with a Justock, but I haven't had to lately.
My 2wd buggy has a Savox 1257 with a Justock. I did add an extra cap direct to the esc, but have had no issues.
My Late Model has a Savox 1251 with a Justock. No glitch buster, no extra cap (stock single cap). No problems.
flamingtire is offline
Old 05-01-2016, 08:20 AM
  #10494
13Maschine's Avatar
Doesn't anyone know when I will be able to buy the WiFi Express? Seems like it's been years since they announced.
13Maschine is offline
Old 05-02-2016, 12:54 AM
  #10495
JAE
Trader Rating: 30 (100%+)
Default V3.1 120amp Brake strength - stock blinky
Recently picked up 2 of these used. Wow, the brakes are strong. Read something in passing about "stock motor braking issues". Anyone know anything about this? Thx
JAE is offline
Old 05-02-2016, 06:41 PM
  #10496
Trader Rating: 357 (100%+)
jmoneym is offline
Old 05-03-2016, 07:43 AM
  #10497
I have a new Xerun SCT Pro Sensored Brushless ESC/Motor Combo (4000kV)
I've been running it without the sensor wire connected, what is the purpose of the sensor wire and should I connect it ?
weedsnager is offline
Old 05-03-2016, 08:15 AM
  #10498
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
I received this reply from HWNA..
"Thank you for your inquiry.
The actual release date is unknown yet but the WiFi module will be available fairly soon. We will keep you posted via our official facebook.com/Hobbywing.NA as soon as we have any news and updates on this item"
DriveItLikeYSIT is offline
Old 05-03-2016, 08:57 AM
  #10499
Google would be your friend on this!!! But in short, provides the ESC with known motor position providing smoother (no cogging) starts. Run it if you can
brew99 is offline
Old 05-03-2016, 09:24 AM
  #10500
DirkW's Avatar
I agree. Run it with sensor cable if possible. Throttle response will be much smoother in low RPM sections.
DirkW is offline
