HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 09-17-2012, 07:11 PM
  #1006
rcboy1's Avatar
Originally Posted by TCCustoms
i would think you would be able to if the ESC has it as a programing option and also uses both motors...they would know when manufacturing it that allowing it to be used with motors that IT WILL BE USED 1 way or the other so it only seems to make sense that they should be able make the motor be able to turn both ways. I just think it has to be an option in the ESC and might be why you pay more for some ESC's as they have more options or programmable features.
Confirmed it a few minutes ago, you can change direction with the program box. I agree, it would be a very stupid idea for them to not have that ability.
Originally Posted by LowBudgetRacer
Has anyone had a issue with the 2150 motors front face plate screws stripping out. I had the motor come apart during a main last month. The motor was only 3 races old. I inspected the motor and replaced the screws with longer ones. I tested out the motor and it lasted about 30 seconds before it locked up. I took it apart and found the magnets had seperated from the pinion shaft and been damaged in the process. Pretty disappointed as the motor was only about a month and a half old. Strong motor till that point, won 2 races with it.
Do you have a link? I'm not familiar with that motor....
rcboy1 is offline
Old 09-17-2012, 08:16 PM
  #1007
LowBudgetRacer's Avatar
Trader Rating: 22 (100%+)
Sorry I mean the XERUN 2250. Hit the wrong key.
LowBudgetRacer is offline
Old 09-18-2012, 08:03 AM
  #1008
I have not dealt with tenshock, is that motor sensored?
Yes they have sensored and sensor less mine is the 4000kv sensored when I get home later I'll throw my hw 4700 in to see if I can eliminate that option
Losi57 is offline
Old 09-18-2012, 08:05 AM
  #1009
I'd love for u to explain how I can change rotation with the USB link because I've been on there for two days lookin for it
Losi57 is offline
Old 09-18-2012, 08:13 AM
  #1010
Originally Posted by Blitzrockey
I belive that you cant reverse the direction of the sensored motors.
It's usually done in the esc.For instance I was running the ten shock with a tellin rx8 and I was able to go onto the hotwire and change motor rotation.It should def be an optiOn within the esc.when iget home later I'll swap motors to eliminate that option.By the way I'm trying to get away from tekIn because I'm sick of sending rx8s in to get repaired at 100 a poP.Ive never had a hw esc shut down for 5 sec when coming down from a hard landing.
Losi57 is offline
Old 09-18-2012, 08:21 AM
  #1011
lewis110's Avatar
You gotta remember the rx8 and HW 120 amp are 2 different esc's. The hobbywing you can run boost/turbo so the esc really relies on the sensors. The rx8 starts off in sensored mode but then goes into unsensored mode. I don't believe the rx8 has a real boost/turbo feature. You might wanna try updating the firmware to 930stock. That's what I ran in my 60amp esc when I had it.
lewis110 is offline
Old 09-18-2012, 11:41 AM
  #1012
rcboy1's Avatar
In that case, no, I've never had the problem. I have tried many motors like the variaty of Castles but the hobbywing is one of the few I've run that did not have the issue with ripping the screws out of the front.
There is a feature called "motor rotation". Options are CW (clock wise) and CCW (counter clockwise). Works for almost all hobbywing esc's except for most if not all ezrun's.
rcboy1 is offline
Old 09-18-2012, 12:22 PM
  #1013
I understand what the feature is but how do I get to it.its not on the program box and it's not on the USB link.its the xerun 120a v2.1
Losi57 is offline
Old 09-18-2012, 04:08 PM
  #1014
Precision1's Avatar
Trader Rating: 51 (100%+)
Yeah, you don't get motor rotation w/ that ESC.
http://www.hobbywing.com/product_show.asp?id=246
Click on "programmable items" tab.
*answered a few pages back as well, sorry.
Precision1 is offline
Old 09-18-2012, 04:16 PM
  #1015
ByteStream's Avatar
For v2.1:
You can't reverse motor direction if your using timing software (stock/mod). There are simply no options in the software to do this (PC or programming card). For those of you saying there is an option, it's clear that you don't have a v2.1 in front of you. Know that the options between ESC's are different.
The only way that I know of to reverse motor direction on a v2.1 is to use a special version of the no-timing software, v1_508_zero_rev. The "rev" stands for reverse. The software won't look any different, but it works in reverse.
ByteStream is offline
Old 09-18-2012, 04:50 PM
  #1016
ByteStream's Avatar
One more thing ... if this is in a Durango DESC410R .. double check the following:
http://www.rctech.net/forum/10710796-post6059.html
Old 09-18-2012, 05:28 PM
  #1017
TCCustoms's Avatar
Originally Posted by ByteStream
For v2.1:
Thank you again for stating what i told me back a few pages ago Precision1...i even posted a pic showing that there is no option in the programming of the ESC to change rotation with that ESC
BUT if ByteStream is right...that is the only option other than buy a new esc that allows you to change rotation! Once again as i said and Bytestream stated above also....PLEASE KNOW THE ESC before stating and why i suggest goin to HW to look up the ESC you have and go from there, dont always rely on what other people say as we see here...
TCCustoms is offline
Old 09-18-2012, 05:41 PM
  #1018
rcboy1's Avatar
you guys dont have that? Weird, mine does....Might be because I'm using a different software.
rcboy1 is offline
Old 09-18-2012, 06:03 PM
  #1019
TCCustoms's Avatar
what esc do you have?
Old 09-18-2012, 06:19 PM
  #1020
rcboy1's Avatar
60 amp v2 and 120 amp v2.
rcboy1 is offline
