HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree193Likes
Old 01-27-2016, 05:29 PM
  #10171
Trader Rating: 27 (100%+)
Calibration with the Stock SPEC is easy as Kyle mentioned, I tend for mix up the throttle and brake sometimes haha.. Simple recalibration fixes that.
Ronisonce is offline
Old 01-28-2016, 07:20 AM
  #10172
Trader Rating: 44 (100%+)
Does the 2 in 1 LCD program box let you change the drag brake and brake force to a custom % instead of the default %?
Bartman42 is offline
Old 01-28-2016, 11:14 AM
  #10173
Carter Flotron's Avatar
Yes you can change drag brake to a custom percent with the box. For braking force you will need to use a laptop if you want to use a custom %. The box gives some pretty good options for braking force though, and you can fine tune with brake pea/dual rate on your radio.
Carter Flotron is offline
Old 01-28-2016, 11:48 AM
  #10174
Perfect.. Thank you
Old 01-30-2016, 04:53 PM
  #10175
Trader Rating: 60 (100%+)
This has I'm sure been covered a million times in here. That said I can't get the results I'm looking for searching in the thread sorry. I have a 120a v2.1 xerun. I need to run blinky mode for an upcoming race. What firmware do I need to run and where can I find it on hw's site? I have flashed hw esc's years ago but it has been awhile. Thanks in advance.
motobigalow is offline
Old 01-30-2016, 05:05 PM
  #10176
COBRARACING's Avatar
You need to download the usb link from hobbywing.com and load v3 508 zero timing software.
COBRARACING is offline
Old 01-30-2016, 05:09 PM
  #10177
Okay I have the link I think already thank you!
Old 01-31-2016, 02:12 PM
  #10178
Dan.J's Avatar
Trader Rating: 21 (100%+)
Can anyone give me a part # for the fan used on the new XR8 1/8 esc? I know the fan from the SCT pro fits it but is it the right one?
Dan.J is offline
Old 01-31-2016, 02:53 PM
  #10179
Good question.
From my research it looks like part number 86080080 is what you are looking for. Don't hold me too it, but the specs for that one appear to be in line with what the XR8 calls for.
flamingtire is offline
Old 01-31-2016, 03:05 PM
  #10180
FastPete's Avatar
Hi Dan
Yes it uses the SCT Pro fan.
FastPete is offline
Old 01-31-2016, 05:03 PM
  #10181
Dan.J's Avatar
Thanks guys,
Another question, any news on the new 1/8 motors that are supposed to be coming, the ones that were talked about when the XR8 was being marketed? The full sensored deals that can take advantage of the 1/10 type timing fuctions etc with the XR8?
Dan.J is offline
Old 01-31-2016, 08:35 PM
  #10182
watzonee's Avatar
Trader Rating: 28 (100%+)
Any help would be great here. I recently purchased a stock spec v3.1 esc and need to put in blinky mode.. The only way to do that is through the program box right?? I have a program box but every time I plug it in it says "please update software" which would be easy but I have a Mac.. Please help!! ���� and which software is that referring to the box or esc???
watzonee is offline
Old 01-31-2016, 09:14 PM
  #10183
I have the Xerun SCT Pro. It went into lipo cutoff when I was at full throttle on the back straight. Made a noise similar to a stripped gear or heavy cogging. Is it normal for this esc to make the motor emit this sound? thanks
....Edit.... Looking things over I accidently had "punch mode" on "8", the directions said if your battery isn't good enough or a high discharge rate the motor wouldn't run smooth or "tremble". I think this is the noise I heard. Backed it down to "5" and I think all is good.
KyJoe340 is offline
Old 02-01-2016, 10:10 AM
  #10184
Correct. XERUN V3.0 ESC ONLY works with the new version of the USB Link Software: the version no earlier than V3.0_Beta_120401.
Do you already have the newer style program box (link below)? http://www.hobbywingdirect.com/products/lcd-program
I'm not a Mac user, so I can't help you there. I'm sure someone else can give you some info on that.
Old 02-01-2016, 10:16 AM
  #10185
Also make sure the connections on your motor are clean and "away" from each other. The symptoms you are describing can result from stray solder touching between the solder tabs or wire ends.
Double check all of your solder joints and wire connections (motor leads, ESC, Battery cable, etc.) just to make sure. Having a short can cause terminal damage very quickly.
