HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 12-03-2015, 11:05 PM
  #10051
mebolson's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Slotmachine
Yes different case and a couple of features you probably wont miss running offroad.
3.1 vs just stock
What features would I be missing?
E
I run a D413 w/5.5
mebolson is offline
Old 12-04-2015, 06:47 AM
  #10052
Slotmachine's Avatar
Originally Posted by mebolson
3.1 vs just stock
E
I run a D413 w/5.5
Slotmachine is offline
Old 12-04-2015, 10:03 AM
  #10053
Justock is a blinky ESC, where as the v3.1 is the top end of Hobbywings 1/10 ESC with a ton of options to fiddle with to get the most out of the way you drive. v3.1 has boost + Turbo modes, variable braking steps, on/off switch is on the esc itself, all aluminum case, also 120A. Justock is a 45a blinky esc with basic tuning options like punch level and braking force.
DLE RC is offline
Old 12-04-2015, 10:20 AM
  #10054
After 1 season of running on a clay / dirt track I finally killed my v3.1. I am out of the warranty range (180 days) so im stuck with a pile of useless electronics. Kinda pissed as this is supposed to be the best of the best from HW. From what I can ascertain the problem is that dust accumulated where the power switch is mounted to the board and over time the dirt caused a short circuit.
This caused the car to shut off during my TQ paced run at my local club race track. When I pulled the car I opened up the lid and a puff smoke and that familiar burnt electronics smell hit my nose. Sadly I knew it was dead. This ESC was installed in my B5m paired with an SMC 5000mAh 2s LiPo and an LRP X12 9.5T motor. This is well within the capabilities of this ESC and I was hoping for years and years of use out of a $190 esc. If you are running on carpet, this is definitely a great ESC, but if you are going to be running in dirt, you can see the result.
Had to downgrade to a Justock so I could get back in the action, but alas I'm clicking off slower laptimes because I don't have boost / turbo to help on the long straights and that nice "blip" of power for clearing jumps. Kinda bummed, but when it worked it was one of the fastest cars on the track. As a matter of fact the first race of the year I nailed a 24.9 second lap time which is 1 second faster than anyone else has achieved this year. Now the best I can crack off is a 25.750.
I'll add this as a positive though, both the v3.1 and the Justock are wicked performers. This doesn't sway my allegiance for the HW brand. I have had great luck with them and will continue to purchase them. I have a v2.1 that should be here tomorrow that is going in my T5m. Crossing my fingers this doesn't happen again!
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-wp_20151106_002.jpg
DLE RC is offline
Old 12-04-2015, 06:42 PM
  #10055
5th wheel's Avatar
Wow. That's nasty looking. Sorry to hear that about your esc hope hw can help you out.
5th wheel is offline
Old 12-05-2015, 06:57 PM
  #10056
larsif's Avatar
Default Soldering wires to Juststock ESC
I have a Juststock ESC and I want to change the motor wire leads that attach to the esc. Can I heat up the solder on these wires and pull out the wires without damaging the esc? Has anyone done this already with success? Thanks.
larsif is offline
Old 12-06-2015, 01:56 AM
  #10057
5tone's Avatar
Default SCT pro loss of power
Originally Posted by MitchCraft
I'm having one of the famous loss of power/cut out issues. Truck will run fine for a few minutes but then cut out. Red LED will remain lit, then after two green flashes and beeps, all is good for 30 seconds, then back to the same cut out again. Temps all good by temp gun and can hold finger anywhere on motor and esc comfortably. Never any loss of steering.
SCT410.3, 4700 motor, currently 14t pinion
Tried:
  • Re-calibrated radio
  • LVC off
  • Multiple different batteries of different brands (high quality, high C and capacity that work fine in other vehicle)
  • Updated firmware
  • Unplugged sensor wire
  • Different radio system (completely different brand)
  • Put radio/steering servo direct to battery
  • Checked all connections
I have noticed several other posts with similar problems that don't seem to be resolved. Anyone have any ideas?
I'm coming to get the same troubles as you (after 2years of good service)
Did you find where the loss of power came from ?
Is buying a new esc the only solution ??
thank's
Phil.
5tone is offline
Old 12-06-2015, 05:17 AM
  #10058
Default Sct pro fan port dead?
Hi,
I have a xerun 120a sct pro. After a couple weeks, the fan port on the esc appears to be dead. I tried plugging in my multifunction program box as well and nothing comes up. Any tips or workarounds? I am on the latest firmware and tried resetting to factory.
Edit: I plugged the fan into the aux port on the receiver and that did the trick
jj12345 is offline
Old 12-06-2015, 02:57 PM
  #10059
Trader Rating: 61 (100%+)
Just installed the V3.1 stock spec and V10 17.5 in my B5M. Not familiar with adjusting boost and turbo settings. So I just set it up in Blinky mode. Testing it out on the street and there is a lag when I give it full throttle. Seems like it is kicking in boost. Tried different profiles and adjusting punch. But no matter what settings that lag is still there. Also once in a while the ESC doesn't respond to throttle inputs. Pull the trigger couples of times. No response. Wait a second or two then it responds. ESC temps are 110F.
mr240 is offline
Old 12-06-2015, 07:48 PM
  #10060
thank's
Phil.
I ended up with a new esc; one of the output fets was burned up. Fortunately for me it was in warranty and hobbywing took care of it.
MitchCraft is offline
Old 12-06-2015, 08:49 PM
  #10061
I apologize I was think of the stock spec speedo..............sorry late nights are a killer.
Old 12-06-2015, 10:38 PM
  #10062
Looking to get a new v3.1. Already have the 120A. Amain is out of the v3.1 120A, so thinking about getting the v3.1 Stock Spec.
Other than plastic vs aluminum case, weight, and 120/760A vs 100/600A. Are those the only differences? Look like programing is the same.
Both will be for 2wd buggies. One will be for 17.5, the other for a mod (6.5).
Anyone who has both noticed any difference in performance. Which one would you use for 17.5 vs 6.5? Since the 17.5 are so demanding, does it make sense to put the 120A on it, or is it better suited for the 6.5?
Thank you.
gagagugu is offline
Old 12-07-2015, 12:53 PM
  #10063
corn_bread's Avatar
SCT pro just keeps shutting off mid run. i have tried everything i have 5 packs through it and it still runs then stops. by the time i get out to it it is running again. temps are below 85 degrees on esc and 91 on motor. this is the sct pro with 4600kv HW motor
help cause i want to like this esc motor
corn_bread is offline
Old 12-07-2015, 12:54 PM
  #10064
Any suggestions. LVC is set to 3.0.
mr240 is offline
Old 12-07-2015, 10:05 PM
  #10065
Thank you.
I would also like to know the answer to these questions.
faron5M is offline
