HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 09-20-2015, 07:12 PM
  #9886
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
I've noticed this happened to two of my buggies running the JustStock esc.
When I hit full brake, it stays locked in for a split second then releases. It's like it gets hung up in brake. This really messes you up when racing.
Anyone else run into this?
JEFFs SC10 is offline
Old 09-21-2015, 04:16 AM
  #9887
Originally Posted by boner
It's a bad sensor board (motor or esc) causing the cog. Had similar issues until I clean up my sensor board on the motor and cogging issues is gone.
My sensors are ok. Which version of firmware are you running? Thank you
peterhoekstra is offline
Old 09-21-2015, 06:53 AM
  #9888
boner's Avatar
I had 4.1.22 initially and upgraded to 4.1.25. Both version was causing cogging until I clean the sensor board on Tekin.
Also make sure your ABC wires are soldered correctly. I had A to C and C to A at one time, the system cogs badly initially and runs fine once the car start moving.
boner is offline
Old 09-22-2015, 09:49 AM
  #9889
Trader Rating: 83 (100%+)
Need some help here fellas. I'm trying to switch firmware in my extreme stock esc using the 2 in 1 pro box. When I book up my esc it says device cannot be opened. Also curious is when I book up my program box to the pc it never says connecting to pc. It just says connecting to esc. Even when I select lcd program from the drop down. Do I have a defective box? Tried running as administrator as well in case that was it but nada
dpcardoza is offline
Old 09-22-2015, 11:15 AM
  #9890
Trader Rating: 22 (100%+)
When are the new hobbywing 1/8 motors going to come out?
I expect they're going to be hw versions of the vst2 pro motors (w/o the $200+ price tag).
jonasm48 is offline
Old 09-22-2015, 01:37 PM
  #9891
I want to know the same thing. I can't find any info whatsoever and the only response I got from Hobbywing was "sometime in the future, we will release it on facebook". Thanks, that helps - lol.
KahrsRacing is offline
Old 09-23-2015, 07:36 AM
  #9892
GNS Racing 86's Avatar
Default xr8 coast
just got the XR8, works great except cant get a neutral with the coast feature. it creeps forward unless the coast is set at 0, tried re calibrating many times, no luck . i ran it at 2 races this last weekend, at the default settings. ran flawless smooth great brakes and tons of power, im using the HW 1800 motor w 4cell, very happy just need to get the coast thing figured out.. looks like 2 other people having the same issue on the XR8 thread.. thanks..
GNS Racing 86 is offline
Old 09-23-2015, 11:13 AM
  #9893
hi, anyone with this issue please contact hobbywing north america @ this number (800) 720 2351,i just got off the phone with them and they said they have not heard of this issue and are not allowed to go on this website. only sponsored racers can monitor these type of threads and they have to relay the info back to hobbywing, they want me to get a RMA and return the ESC if we cannot figure it out. so if you have this issue please contact them. i know of 2 others having the same issue, thanks ..
Old 09-25-2015, 01:17 AM
  #9894
Default Email for Tech Support
Same here. Motor runs smooth without sensor cable. With sensor cable it runs very rough, cogs like hell. Tried all possible motor wirings, sensor wirings and timing settings. I suspect there is a bug in the firmware. I am running version XR-4.1.25
Besides you and me, Yodah and boborc also experience the same issue.
I also sent a mail to [email protected] but no response...
I advice other people with the same problem to send a mail to hobbywing and not to use the sensored mode. As running with this commutation problem can destroy your motor.
Does anyone know if it is possible to reset the firmware to factory shipping?
I hope this issue with the XR8 is fixed soon.
Hello,
Perhaps you guys can try another email at [email protected] (found it on their website, sent them an email yesterday and got a reply from Paul to my question today).
Hope it helps.
jshe0819 is offline
Old 09-25-2015, 12:14 PM
  #9895
RCWERKZ's Avatar
I have a Hobbywing 150A ESC and and 120A SC8 WP ESC.
Can I use this Sensored Motor with this/these ESC's?
http://www.nitrorcx.com/96m902-senso...53-kv4000.html
RCWERKZ is offline
Old 09-25-2015, 01:35 PM
  #9896
Slotmachine's Avatar
As far as the 150amp. goes, they dont like to run on 2s very well without an external bec. Im not too sure about the other model. Is your choice based on looking to spend less money? I would still recommend the Hobbywing 3656 4000kv 4 pole. its around $40.00 more but I have never damaged one, and they are very fast!
Slotmachine is offline
Old 09-25-2015, 01:44 PM
  #9897
RCWERKZ's Avatar
I have both. I really want to use the 150A in my Truggy and the 120A SC8 WP in my yeti with that motor.
Looks like I need UBEC-3A, to run 2s.
Just not sure about the 120A
RCWERKZ is offline
Old 09-25-2015, 02:14 PM
  #9898
The 120A will be fine without a UBEC on 2s. Definately run one with the 150A on 2s
brew99 is offline
Old 09-25-2015, 02:18 PM
  #9899
RCWERKZ's Avatar
Even though the ESC meant for Sensorless Brushless Motor? The motor is sensored.
RCWERKZ is offline
Old 09-26-2015, 09:17 AM
  #9900
Trader Rating: 20 (100%+)
Default hobbywing esc v2.1
ok I got this esc yesterday, this is my second one. I soldered everything up, started to calibrate it, and I can not get it to run on throttle in forward on controller, I updated control box and firmware on both, and latest update on computer program, followed instruction even had another racer try to do it and that didnt work. what I have is a d413 with this esc hooked to a smc 7.5t motor, and a futuba 4px, had setting described in instruction. I already sent email to hobbywing, we reset transmitter back to default and everything else, and I swear I had the option on the old v2.1 to put the motor to cw/ccw rotation. I tried different sensor cable. my old one worked with this same setup, and i know everything works, had my buddies v3.1 stock esc in it last weekend and everything worked fine, if anyone has any ideas that would be great, ive got a race this next weekend, but i might have to miss it. thanks
jakeg1973 is offline
