HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#976
hey guys i have the xerun 150a in my 1/8th buggy with a castle 2200 motor on 4s. has been working flawlessly since i got it on christmas last year. I'm sure i am out of warranty because of how long ago i got it but was wondering how much it would cost me to have it repaired and where to send it to. Its not giving me any power to the motor and the red light is staying on with throttle on or off. It was an all of a sudden failure where it cogged for a second or two and then just died after giving it full power for a large jump.
#978
Got a brand new 120A SCT Pro ESC for sale if anyone needs it!
It is the black one.
http://www.rctech.net/forum/r-c-item...-unopened.html
#979
Anyone know if i can replace the switch on my sct pro? If so a link would b great thx
#980
Can a sctpro pair with a T8 2650kv?Im kidda torn between getting a 150A or a sctpro, love the sctpro esc programming via the fan port and the size but wondering if can push my existing t8 2650kv
#982
take a look at the website...you should always look at the details before ordering becuz someone may speak up and not know for sure so ALWAYS research for tech info...5 sec search and i found this.
The ESC has 2 color options. They have the same performance.
XERUN-SCT-PRO (Blue), PN = 81020260
XERUN-SCT-PRO (Black), PN = 81020262
1 Specification
1.1 Output: Continuous 120A, burst 760A;
1.2 Input: 6-12 cells NiMH/NiCd or 2-4S Lipo;
1.3 BEC: 6V/3A (Switching mode);;
1.4 Resistance: 0.0004 Ohm;
1.5 Motor Supported: Sensored and sensorless brushless motor
1.6 Suitable Motor:
With 6 cells NiMH/NiCd or 2S Lipo: KV≤6000;
With 7-9 cells NiMH/NiCd or 3S Lipo: KV≤4000;
With 10-12 cells NiMH/NiCd or 4S Lipo: KV≤3000;
1.7 Suitable Car: 1/10 and 1/8 scale short course truck / buggy / tuggy;
1.8 Cooling fan: 5-6V; * Note #1
1.9 Size: 53.5mm(L) * 36mm(W) * 36mm(H).
1.10 Weight: 99g;
#983
Ok just installed my HW v2.1 120amp esc.With all the wires hooked up correct the motor is running counter clockwise.So i how do i reverse direction? I know you can switch two wires with a sensorless motor but how do u do it with a sensored motor?
#985
Any feed back on the Hobbywing ezrun SC10 70A ESC/10T motor combo. I got one for my Kyosho Ultima SC. I got tired of all the expensive ESC's going bad on me and I wanted a more reasonable priced ESC for my SCT. Will this ESC withstand a splash of water I know its not waterproof just wondering since we race on a outdoor track that gets watered down.
#986
Anyone got any ideas how to format a 2 in 1 Digi program box? Its not showing up as a device on MY COMPUTER screen.
I was able to get it back to the 1.08 software, but I want to try and format the whole thing and load entirely different software on it.
I have 2 boxes, so will still keep one "stock" just want to play around with different MOD software.
MOmo
MOmo
#987
There is no motor rotation on the box.Theres only running mode,drag brake force,low voltage,start mode,reverse speed,neutral and overheat.Did you check or are you just taking a guess?
#988
A) The programmable items for the CAR ESC are:
3.1 Running Mode
3.2 Drag Brake Force
3.3 Low Voltage Cut-Off Threshold
3.4 Start Mode
3.5 Maximum Brake Force
3.6 Maximum Reverse Force
3.7 Initial Brake Force
3.8 Throttle Neutral Range
3.9 Timing
3.10 Over-Heat Protection
3.11 Motor Rotation
3.12 Lipo Cells
You may need to update the firmware that is installed on your LCD Program box, or alternatively use the computer software.
I will try and check if I have that option and get back to you in around 7 hours.
#989
Just trying to help here, and I believe you, and I have not checked (which I really should...) but from this site the menu option includes:
3.1 Running Mode
3.4 Start Mode
3.9 Timing
3.11 Motor Rotation
3.12 Lipo Cells
3.1 Running Mode
3.4 Start Mode
3.9 Timing
3.11 Motor Rotation
3.12 Lipo Cells
#990
Anyone know the bearing size that is located on the end bell of a HW 4700kv 4 pole motor.
