HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 09-10-2012, 04:35 PM
  #961
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Go with the either the v3 or the v2.1, this way you can run boost timing etc if you want to
Blitzrockey is offline
Old 09-10-2012, 04:39 PM
  #962
TCCustoms's Avatar
sct pro is a more rugged built esc but if you go to hobbywings site and click the esc you are comparing you can see the programming options for that esc and if its the 120a V2.1, they look to be same options just have a few more on the sct pro
If this is the esc your talking about and comparing to the sct pro...
120a V2.1
http://www.hobbywing.com/product_show.asp?id=246
SCT Pro
http://www.hobbywing.com/product_show.asp?id=263
TCCustoms is offline
Old 09-10-2012, 04:40 PM
  #963
Kevin_M's Avatar
thx
Kevin_M is offline
Old 09-13-2012, 04:21 AM
  #964
I have same problem with esc going into sensorless under full throttle.I am running a tenshock x812 and I dont have option in LCD Box to turn off Heat protection to see if that helps.
Does anyone know how I can access it or if there is another fix to this annoying problem?
Thx
Josh
gurujosh is offline
Old 09-13-2012, 10:09 AM
  #965
TCCustoms's Avatar
what esc?
Old 09-13-2012, 11:33 AM
  #966
Devigili22's Avatar
Trader Rating: 29 (97%+)
Hey guys. I have a 150A in my 8T. I'm running 2 (low quality, well used) Turnigy 5000mah 20C 2s batteries in series and have noticed I have been hitting LVC with about 3.5v per cell left. My LVC is set at 3.0. Is it the quality of the batteries causing it to cut out so early?
Devigili22 is offline
Old 09-13-2012, 11:41 AM
  #967
Its a xeruun 150a
gurujosh is offline
Old 09-13-2012, 11:42 AM
  #968
rcboy1's Avatar
Possibley. If you could borrow some packs from someone else you could find out. If it turns out not to be, I would turn the LVC setting to 2.8 or 2.7 if you have the program box. I have noticed the hobbywing escs seem to cut off sooner than what you set it at. I believe I run mine at the 2nd to lowest setting to get maximum run time.
rcboy1 is offline
Old 09-13-2012, 11:53 AM
  #969
lewis110's Avatar
They hit the lvc when you punch the throttle and it really drains on the battery. The esc picks this up and shuts down. Once the battery stabilize then it will show the 3.5 or so. I wouldn't advise dropping lower then 3.0 per cell. You could actually drain the battery to much.
lewis110 is offline
Old 09-13-2012, 11:55 AM
  #970
You should really judge it by how the pack feels on the track. If the car is slowing down then the pack is discharged. If you are measuring 3.5v per cell after coming back to the pits, that is pretty close to discharged. Under load the voltage is going to dip into the ~3v range.
I am pretty aggressive with the LVC and my packs seem to rest at around 3.4v - 3.5v when discharged.
kcobra is offline
Old 09-13-2012, 02:05 PM
  #971
Devigili22's Avatar
I understand, but I have my LVC cutoff at 3.0V, and when I can only get 8/9 min of runtime before LVC kicks in and I see that the batteries are still at 3.5 per cell, I get aggravated.
Old 09-13-2012, 07:02 PM
  #972
Turn ur lvc off for racing. Is what I usually recommend. Just helps to not have that happen.
Old 09-13-2012, 08:20 PM
  #973
rcboy1's Avatar
exactly. The LVC is just a safety device that was designed for newer drivers when speed controls first came out with them. When you're car starts to slow down, stop immediately. Simple.
rcboy1 is offline
Old 09-14-2012, 08:11 AM
  #974
Busterlbn's Avatar
Originally Posted by Busterlbn
Hi guys. I bought Xerun 150A v2.1 w/4068SD motor. I plugged in everything together and it works but:
- After a few seconds throttle's green led lights. When I disconnect sensor from engine, led doesn't light.
- Engine has a delay when you go immediately to full throttle from neutral.
Everybody has something like that or it's my problem?
Anyone?
Busterlbn is offline
Old 09-16-2012, 08:16 AM
  #975
thekisscutken1's Avatar
Trader Rating: 46 (100%+)
hey guys i have the xerun 150a in my 1/8th buggy with a castle 2200 motor on 4s. has been working flawlessly since i got it on christmas last year. I'm sure i am out of warranty because of how long ago i got it but was wondering how much it would cost me to have it repaired and where to send it to. Its not giving me any power to the motor and the red light is staying on with throttle on or off. It was an all of a sudden failure where it cogged for a second or two and then just died after giving it full power for a large jump.
thekisscutken1 is offline
