HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 08-16-2015, 10:11 AM
  #9706
DirkW's Avatar
Originally Posted by Millsy97
It's just the LCD one with no battery reader, I connected it via the RX cables BTW.
In that case it could be that you need to load a different firmware onto the card.
But I think the SCT Pro needs to be connected via the fan port, not the RX cable, so I would try that first. And even then, the connection will only work if there's a true neutral signal on the RX cable - any other signal will override the connection to the card in the fan port. Some receivers do that without problem, on others, you may have to unplug the RX cable.
DirkW is offline
Old 08-16-2015, 11:52 AM
  #9707
Slotmachine's Avatar
Connect through your fan port.............
Slotmachine is offline
Old 08-16-2015, 02:30 PM
  #9708
Hello to all new to this site I just purchased the same hobbywing SCT pro tried to program it did the same thing had to unhook the RX wire is there a way to fix it so you don't have to every time you want to program
Heavy Chevy is offline
Old 08-16-2015, 07:09 PM
  #9709
Trader Rating: 24 (100%+)
rcuser67898578 is offline
Old 08-16-2015, 11:31 PM
  #9710
rcus3r's Avatar
Originally Posted by Johnny-RC
I cant confirm this but I suspect most of the users that experience this issue are using Spektrum Tx/Rx's with the failsafe feature...
Two trucks, all identical electronics except for motors. Airtronics radio.
One programs normal, the other I have to unplug the ESC wire from the receiver. Same firmware.
rcus3r is offline
Old 08-17-2015, 08:32 AM
  #9711
I am using the Dx4R and 3300t
Old 08-17-2015, 09:43 AM
  #9712
Trader Rating: 18 (100%+)
Hello, I'm having some problems programming with my SCT pro as my hobbywing LCD program card isn't working with it and won't pick the ESC up. I've tried it with it connected to my laptop and without and it still wont work. Is this a known problem or am I using the wrong program card?
Thanks Alex
I had the same issue (in this thread). I unhooked the ESC from the Receiver and it worked. I have a Spektrum rx/tx setup. I was getting 'Connecting to ESC' and it wouldn't go away.
rcnewbie418 is offline
Old 08-17-2015, 12:08 PM
  #9713
SpidarX's Avatar
I have started experiencing a problem with my hobby wing Justock ESC. When I first give throttle input, the motor trembles and doesn't start until the throttle is pulled further. This has just started happening. I use the esc with a 17.5 touring car. I haven't overheated or over geared the esc. So I'm not sure why this problem has appeared. I have checked the following: replaced sensor wire, recalibrated the esc, reset the esc to default, changed motors. Nothing has fixed this cogging at the start of the throttle input.
SpidarX is offline
Old 08-17-2015, 01:36 PM
  #9714
try re updating the speedo on the pc, and then re calibrate it to the radio.
Old 08-17-2015, 02:34 PM
  #9715
SpidarX's Avatar
I don't have a box to update. I was running the factory settings.
SpidarX is offline
Old 08-17-2015, 05:31 PM
  #9716
Have you tried running with no srnsor wire? You could have a bad replacement sensor wire???
Old 08-17-2015, 09:18 PM
  #9717
SpidarX's Avatar
I've tried with two other sensor wires now, yet the esc still has the same problem. I tried it without the sensor wire, it is slightly better, but still studders and won't spin the motor at low throttle.
SpidarX is offline
Old 08-18-2015, 06:40 AM
  #9718
I'm about to start my sct410.3 build when I finish the yeti xl for my wife this week, where is everyone buying these from? I was thinking the xerun pro that everyone seems to be running. I have the new mamba X set up for the yeti but I wanted to give something besides castle a try.
Rob4607 is offline
Old 08-18-2015, 07:47 AM
  #9719
Right here........http://www.falconsekido.com/products...sct-pro-series
Old 08-18-2015, 09:01 AM
  #9720
Originally Posted by tekin112000 View Post
I want to set the temp cutoff on my XERUN stock 3.1 but the lowest looks like 105C/221F
This seems like it would be hot enough to damage the motor.
Is this the lowest setting for temp cutoff or am I doing something wrong?
I have installed the hobbywing software on my laptop so I can connect the ESC to the program board then that connects to my laptop. I think I can see all the options and settings for the ESC
Lowest setting should be 85c. Which I believe is appx 160.
yep you are right. I used the program board and set the temp cut off to 85.
Whats weird is that if I connect the ESC to the program board then connect the program board to my laptop to run the HW set up software I do NOT get the option to set temp cut off to 85 the drop down menu does not show it.
Any ideas?
tekin112000 is offline
