HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 09-09-2012, 10:37 AM
  #946
rcboy1's Avatar
Originally Posted by straycat40
Hi Guys,
Looking for a new ESC possibly. Will the HW V3 work with a 4pole motor in a Asc SC10 4X4 SCT?
Also, will Falcon Sekido warranty or repair ESC's if there is a problem later on?
Yes, it will. Either the V2 120 amp or the V3 will work great in that truck. I personally have the 120 amp V2 and the 4000kv 4 pole in my own Associated SC10 4x4 The truck is very light, so when you use the 4 pole it allows you run it with low gearing and timing, resulting in lower temperatures and greater life.
rcboy1 is offline
Old 09-09-2012, 10:38 AM
  #947
TCCustoms's Avatar
get the sct pro...more rugged design
TCCustoms is offline
Old 09-09-2012, 11:09 AM
  #948
Busterlbn's Avatar
Hi guys. I bought Xerun 150A v2.1 w/4068SD motor. I plugged in everything together and it works but:
- After a few seconds throttle's green led lights. When I disconnect sensor from engine, led doesn't light.
- Engine has a delay when you go immediately to full throttle from neutral.
Everybody has something like that or it's my problem?
Busterlbn is offline
Old 09-09-2012, 06:42 PM
  #949
tony montana's Avatar
Trader Rating: 76 (100%+)
is the exrun 150 amp 1/8 esc good for 4x4 sct? Or should I look at another option? Does it come with the sensor wire? Anything else needed to get it running out the box?
tony montana is offline
Old 09-09-2012, 06:49 PM
  #950
lewis110's Avatar
Get the SCT pro, the 150 amp esc doesn't work right on 2s. I believe the sensor wire comes with the motor not the esc. But I could be wrong I have always bought esc/motor combo's.
lewis110 is offline
Old 09-09-2012, 06:52 PM
  #951
Thanks, What motor should I go with? want something equal to a 4.5 Can you post me a link to the combo
Old 09-09-2012, 06:59 PM
  #952
lewis110's Avatar
I run the SCT pro C2 combo.. It's the SCT pro esc with the 3656sd 4000kv motor. The 4000kv motor will run with any tekin 4600 motor. If you think you want anymore power they have a 4700kv motor also. But I'm pretty sure the 4000 will do fine.
http://www.falconsekido.com/products...sct-pro-series
lewis110 is offline
Old 09-09-2012, 07:02 PM
  #953
TCCustoms's Avatar
4700kv...it flys, WOOT WOOT
Old 09-10-2012, 11:55 AM
  #954
Kevin_M's Avatar
http://www.falconsekido.com/products...sct-pro-series[/QUOTE]
Is there something wrong with falcon site? I tried to log on it and says its no longer there.
Kevin_M is offline
Old 09-10-2012, 12:22 PM
  #955
lewis110's Avatar
Worked yesterday when I copied the link lol. Give it a little bit, I'm sure they will have it back up and running.
lewis110 is offline
Old 09-10-2012, 01:39 PM
  #956
Kevin_M's Avatar
Ive tried restarting puter and waited for it but idk. I did order a combo from Falcon and my program box isnt working now.
Kevin_M is offline
Old 09-10-2012, 02:31 PM
  #957
lewis110's Avatar
Hook just the program box up to the pc and reflash the box.
lewis110 is offline
Old 09-10-2012, 02:40 PM
  #958
Kevin_M's Avatar
How u do that?
Kevin_M is offline
Old 09-10-2012, 02:48 PM
  #959
lewis110's Avatar
Just use your usb adaptor like you were going to hook your esc up. But just hook up your program box. And go to the device tab. Click on lcd box. And just reflash the box.
Just to make sure, this only works with the lcd program box. (xerun)
lewis110 is offline
Old 09-10-2012, 04:22 PM
  #960
Kevin_M's Avatar
Im looking to buy the Losi 22sct and was wondering which ESC should I buy? Another sct pro or a 2.1V2? Do both escs have same programing or different?
Kevin_M is offline
