HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 06-26-2015, 11:41 PM
  #9436
Carter Flotron's Avatar
Originally Posted by Whomper
Is hobbywing budget brand? or is it up there with Tekin?
In the past most of the Hobbywing stuff was aimed or at least taken as a budget, entry level way into owning brushless systems. With the new V3.1/V10 line and the upcoming XR8 esc and accompanying motors, the brand is looking to be extremely competitive.
Carter Flotron is offline
Old 06-27-2015, 12:14 AM
  #9437
Thumbs up XERUN XR8 PLUS Coming Soon
XERUN XR8 PLUS is another new competition ESC HOBBYWING specially develops on the basis of constant research, technical analysis and performance comparisons, for 1/8th scale professional race cars.
The XERUN series ESCs have always been welcomed by the market, the sales volumes and users’ feedback have already proved this. XR8 PLUS not only continued the outstanding quality & excellent throttle response of XERUN series ESCs but also adopted some cutting-edge technologies in the brushless power system field. With the integration of new technologies into product’s design and manufacture, XR8 PLUS is realizing the breakthrough desired by the high-level racers.
XR8 PLUS featured by the following elements:
1) High reliability & durability;
2) Great power output;
3) Super built-in BEC with the peak output current of up to 15A and switchable output voltage of 6V/7.2V;
4) Advanced electronic switch with the lifespan of over 50000 times of switching on & off;
5) High-efficiency heat-dissipating system;
6) Special dynamic timing control program is available when this ESC runs in full-sensored mode* ;
7) Innovative coasting function;
8) Almost maintenance-free.
*The full-sensored running mode can only be realized when pairing this ESC with the 1/8th scale new sensored brushless motor HOBBYWING is going to release.
TRiN is offline
Old 06-27-2015, 08:24 AM
  #9438
Originally Posted by Carter Flotron
Yes sirs. You simply reconnect the box an esc to the USB software as you would to update it, and instead of clicking the newest software you click the version you were using before.
What speed control is this on?
Hobbywing Xerun SCT Pro Sensored Brushless ESC/Motor Combo w/Program Box (4000kV)
Got it brand new as a combo from Amain about 45 days ago.
Mark
Riflebuilder is offline
Old 06-27-2015, 09:59 AM
  #9439
Mark
I would agree with Paul (SlotMachine) on this one. Try just unplugging the esc from the car completely.
Does your box connect to your computer? If not, it might be a faulty box.
Old 06-27-2015, 10:04 AM
  #9440
Suspended
i just recently got a hobbywing 2200kv and going to run it on a rather large out door track what is a good pinion to start with for an tlr 8ight e 3.0? need help asap heading out tomorrow to test it out
FGomez50 is offline
Old 06-27-2015, 12:56 PM
  #9441
nitro_mt_racer's Avatar
Trader Rating: 241 (100%+)
14, we run 15 on 2050kv & 16 on 1900kv, same chassis
nitro_mt_racer is offline
Old 06-27-2015, 02:02 PM
  #9442
Suspended
Default gearing
thanks for the help
FGomez50 is offline
Old 06-27-2015, 06:30 PM
  #9443
R1Joel's Avatar
Use to run a 14t aswell with the 2200kv motor.
R1Joel is offline
Old 06-27-2015, 07:42 PM
  #9444
Trader Rating: 17 (100%+)
Default Hobbywing SCT pro and PC software
Is this all I am supposed to see when connecting the SCT pro using the PC software? I dont see anything were I can set a throttle curve on the ESC.
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-screen-shot-06-27-15-09.35-pm.jpg
diamonddawg21 is offline
Old 06-27-2015, 07:49 PM
  #9445
Suspended
Default hobbywing 2200kv motor gearing
thanks also i will give a 14tooth a try, what spur did u run
FGomez50 is offline
Old 06-27-2015, 08:13 PM
  #9446
Slotmachine's Avatar
Push the sdvanced button on the left for more adjustments.
Paul Rush HWNA Team Driver
Slotmachine is offline
Old 06-27-2015, 08:23 PM
  #9447
45t steel for us
Old 06-27-2015, 11:54 PM
  #9448
R1Joel's Avatar
Ran a 46 spur gear.
R1Joel is offline
Old 06-28-2015, 01:29 PM
  #9449
The box connects and was able to be updated. Just cannot get the ESC to be recognized on any of my computers.
Old 06-28-2015, 09:21 PM
  #9450
Now remember if you are using the sct pro you plug into the fan port.
