HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 06-21-2015, 11:50 AM
  #9391
Slotmachine's Avatar
Originally Posted by GluEEE
Hi.
I have bought the 4274 2200kV sensored motor. I have Tekno ET48 KIT too.
I wonder if I can use standard screws to fasten the motor to motor mount.
What's the depth of the holes on the shaft's side?
If I use too long screws, can I damage the coil?
Thanks!
I think the screws you are referring to are metric 3mm screws and you only need them long enough to go through the mount + another 2 to 3mm.
Slotmachine is offline
Old 06-21-2015, 07:23 PM
  #9392
Carter Flotron's Avatar
Originally Posted by Riflebuilder
Here I am spending hours on fathers day trying to ensure my Hobbywing ESC has the correct firmware because of problems with my truck shutting down during the middle of races. I have the USB Link installed and up to date, I have the multi functional programmer updated as well, but it just says "connecting to pc" and with the Device tab on ESC, it shows it is not connected. I followed the manual a dozen times word by word and it will not connect my ESC to the PC by USB link. I'm just getting to the point where I'm about done.
Any ideas before I just put this in a box and install a Tekin RX8 Gen 2???
I always connect the box to the computer first, then to the esc. check out this video I made on the process:
https://www.youtube.com/watch?v=sFX2hFhpSrw
SCT-Pro and V3.1 are programmed through the fan port, all others through the receiver lead.
Carter Flotron is offline
Old 06-22-2015, 05:33 AM
  #9393
Thanks. Can I damage coil if screw are too long?
What is the depth of the mounting holes?
GluEEE is offline
Old 06-22-2015, 08:56 AM
  #9394
I just bought a xerun 150a sd to replace my burnt out tekin. I have it running on two parallel 2s. After about 5 minutes of driving the esc blinks red and green at the same time and I didn't see anything in the manual stating what that means. Could anyone provide me some insight as to what those lights mean?
muskie1999 is offline
Old 06-22-2015, 12:40 PM
  #9395
Mine is currently doing the same thing, according to an E-mail from Jason at Hobbywing, he states that the ESC is going from sensored mode to sensorless mode. I have been running my truck with out the sensor wire in and I only started having problems when I installed the sensor wire.
He told me to try different sensor wires and see if that fixes the problem.
I'm not sure that is the problem, but I will keep checking. My truck shuts off, but my batteries have 3.5 volts per cell still, I believe the auto shutoff is 3.2.
Mark
Riflebuilder is offline
Old 06-22-2015, 01:01 PM
  #9396
MikeGozz's Avatar
Trader Rating: 17 (100%+)
Hi guys, I just started driving my newly assembled OFNA GTP2e over the last weekend. I finished assembling at the beginning of last week! It is running a Xerun 150a w/neewer 2150kv motor.
I have been running it on 4s for the initial shake down runs and it has been running beautifully! I'd have to say I have about 4-5 runs on it.
So today after deciding everything is well and good I took it out for a 6s session. The ambient temperature is in the 70s and it was just a great day for a bashing session! After about 3-4 minutes of running I check the motor temp and it is a respectable 135 degrees f.
I get back into my run and about 3 laps later I see the dreaded black smoke billow out from under the shell! My heart jumped out of my chest!
I ran to the model, popped the body off and unplugged the batteries (2 3s 5000mah nano-techs). The ESC looks like it basically exploded and split in 2 pieces! Here is what it looks like-
I'm very lucky/relieved the entire model didn't go up in smoke but at the same time I am super bummed my brand new build is broken and out of commission.
I found this link while looking for HobbyWing technical support. I really don't know what to do at this point. I'm out a brand new ESC, a 10A BEC, the plastic battery tray, my fans and possibly other parts (I have to check things out after work).
I'm just wondering what my options are at this point? Is the ESC under warranty? I bought it directly from http://www.falconsekido.com/
Thanks,
Mike
MikeGozz is offline
Old 06-22-2015, 01:02 PM
  #9397
nitro_mt_racer's Avatar
Trader Rating: 243 (100%+)
Mark
If your batteries check 3.5v/cell when your truck shuts off then more than likely it's at lvc. Turn your lvc off to test this theory. Amp draw spikes will draw that pack down to lvc & then it'll come back up.
nitro_mt_racer is online now
Old 06-22-2015, 01:10 PM
  #9398
Thanks,
Mike
Just give Falcon Sekido a call, should be under warranty if you just purchased it.
Old 06-22-2015, 01:30 PM
  #9399
Mark
Those lights do mean the esc has switched to sensorless mode.
For the other issue, it is definitley your LVC. Try running it at 2.8v, this will prevent it from shutting off under power spikes. You will also want to make sure you have the latest software on your ESC, as that reduces this issue and allows the ESC to run cooler.
Old 06-22-2015, 05:49 PM
  #9400
Anyone have screw spec for 3.1 fan.
braderb is offline
Old 06-22-2015, 05:50 PM
  #9401
And me to the list of SCT combo shutting down around 6 minutes into a run. No issues for 2 years and it started around March. Software was updated. Had to replace with Orion.
So many people with this issues - IT MUST STILL BE A SOFTWARE ISSUE!
braderb is offline
Old 06-22-2015, 07:24 PM
  #9402
I have been trying the last few days to get the electronic speed control to connect to my computer for an update but it just won't register with the USB link. I've tried all kinds of things and reading the instructions line by line but for some reason it just wont connect.
Mark
Old 06-22-2015, 08:43 PM
  #9403
We have not updated to the latest software release.....don't see any reason to. LVC sensitivity has been an issue with the sct pro for several years now, we turn ours off as we're only racing.
Old 06-22-2015, 11:36 PM
  #9404
Trader Rating: 21 (100%+)
Is it possible to hot wire the switch on the SC8 esc. If so does anyone know how. My switch broke after the 2way tape failed and the switch was drug till it all came part. Heres whats left. I know i can order a switch but funds are low.
NvDesertRat96 is offline
Old 06-23-2015, 06:12 AM
  #9405
On the sct pro you can solder the red & black together to bypass the switch, the white wire then acts as the button for calibration purposes. On yours, you could try holding the brown & orange together to see if it starts up, the white would then act like the button if needed.
