HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 06-05-2015, 01:52 AM
  #9301
lewis110's Avatar
Originally Posted by hacker
Angelo, if your not going to be active in this thread you have created, at least put some information in the first post on an idiots guide to the hobbywings. I wouldn't consider myself an idiot, I have had hobbywings from the start, then ventured off to other manufacturers, but have come across some more HW's and there is just 1 speedy that is giving me probs. I DKWTF is wrong with it......
had to replace it with an orion r10, but I'd like all my rides to be HW'd.
I've updated to the latest software, and now my motor is going backwards, and cannot select reverse motor rotation as it is 'ghosted'!
where can I find an old version of software?
Angelo can send you what you need. Email him at [email protected] or [email protected]
lewis110 is offline
Old 06-05-2015, 10:50 AM
  #9302
Thanks Hacker, I will email Angelo now.
ThirdCoastRC is offline
Old 06-05-2015, 06:18 PM
  #9303
Trader Rating: 17 (100%+)
jmkalt
1 is the lowest setting and more forgiving on loose dusty tracks. We run ours on 1 or 2 and punch on 2 and can squeeze the trigger pretty good out of turns.
IMO Try lower settings first.
CaptCarnage is offline
Old 06-06-2015, 04:22 PM
  #9304
rraden's Avatar
Trader Rating: 259 (100%+)
I've got an older Speed Passion LCD professional program card that looks identical to Hobbywing's. Can this card be used to program the Hobbywing 150a 1/8 speed control?
rraden is offline
Old 06-07-2015, 05:30 AM
  #9305
advpball's Avatar
Trader Rating: 30 (100%+)
I got 4700 combo and motor died just stutters it that just sensor board or need to send in? didn't even get through practice,ran couple times on home track,did ok.
Even changed sensor wire and esc same thing..also good battery, charged.
advpball is offline
Old 06-08-2015, 01:46 PM
  #9306
dmartin's Avatar
Is there a way to get notified when Hobbywing puts out a software update?
dmartin is offline
Old 06-08-2015, 02:56 PM
  #9307
Carter Flotron's Avatar
Ask me
Carter Flotron is offline
Old 06-08-2015, 03:56 PM
  #9308
rcejk's Avatar
Trader Rating: 20 (96%+)
can someone point me into the right direction, i have a hobbywing v3.1 120a esc that will not go into calibration mode. when I attempt to calibrate esc to the radio following per instructions but for me the led flashes red continuously and their is beep sound and slight motor pulse that's continuous and when i press the button, it shuts off.
rcejk is offline
Old 06-08-2015, 05:28 PM
  #9309
It might be able to, do you have a picture?
Are you sure the wires are hooked up the correct phases? having a swapped wire can cause this.
Old 06-08-2015, 05:37 PM
  #9310
Slotmachine's Avatar
Sounds like no radio signal to me. Try to make sure you are bound to the receiver. if you have steering and no throttle reverse the servo with the speed control in your receiver to see if your steering works by the throttle trigger.
Paul
Slotmachine is offline
Old 06-08-2015, 06:18 PM
  #9311
rcejk's Avatar
Paul
The radio works just fine with my other hobby wing v3.1 120a esc.
It wont go into calibration mode at all. does the sensor wire need to be unplugged from the speedo for calibration?
rcejk is offline
Old 06-08-2015, 07:33 PM
  #9312
advpball's Avatar
all wires hooked up correct.. just wondering if anyone else had problem or would it be sensor board after hard crash?barrel rolled several times ...pretty cool though lol
advpball is offline
Old 06-09-2015, 08:30 AM
  #9313
rraden's Avatar
Carter Flotron:
This is the one I've got:
Attached Thumbnails HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD-sp-lcd.jpg
rraden is offline
Old 06-09-2015, 12:50 PM
  #9314
Carter Flotron:
Yes you should be able to. I am not positive if it will connect to the Hobbywing link software however. So you might be stuck with the firmware on the 150A (can still adjust settings though).
Old 06-09-2015, 06:49 PM
  #9315
I have a one month old 150a and 1800 motor in my e buggy. In the last week I plug in the battery and drive a warm up lap or two. I put the car in my start position and when the tone sounds, it won't go. Steering works but no drive. After a second or two, it starts working again and I drive the rest of my qualifier or main without an issue. If I never stop the car for an extended time it doesn't happen. Any ideas?
Matthew Bailey is offline
