HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 06-01-2015, 02:06 PM
  #9271
Slotmachine's Avatar
Originally Posted by CallousStarr
I just bought a car in the for sale section.. it has a HW 150a speedo. it also has a BEC wired into it.
When i try to do the initial setup per the manual. The red light flashes but when i hit the button for neutral it should blink green but it just stops flashing red. Tried following manual exactly and ive done this many times for other brands...
Then i tried to hookup the program card. I hit OK and it says connecting.. but never actually connects.
Is the BEC interfering with programing the Speedo??
Sounds like your not getting throttle signal. Make sure you are bound to the receiver. Then make sure you are plugged in correctly, and the battery is charged.
Originally Posted by 68sportcoup
is there anyway to change the way the lvc hits.
when it kicks in my truck moves about another 2 feet and stops completely.
it would be nice if it cut power in half and I could make it back around the track.
mike
No....this is the way they work.
Slotmachine is offline
Old 06-01-2015, 02:13 PM
  #9272
make sure your tx is off
Yup tx is off. This problem ONLY STARTED with the latest software update. While I could revert to the old software, the LVC fix outweighs the new problem. But its still a problem.
Everybody79x is offline
Old 06-01-2015, 08:09 PM
  #9273
rcmania74's Avatar
Trader Rating: 60 (98%+)
Originally Posted by rcmania74
It s v3.1 stock spec it has fixed timing where the 120 amp has more adjustments. .. i wasn't sure if id lose punch because of the amperage. .. im running a teamc tm4 with hobbywing 7.5 motor and Orion 100c shorty
rcmania74 is offline
Old 06-01-2015, 08:10 PM
  #9274
DoogieLee's Avatar
Trader Rating: 42 (100%+)
Originally Posted by jmd3000
Looking to get sct 120a with 4000kv motor wondering how reliable they have been
I have been running mine in an SCTE 2.0 for over 1.5 years... not one ounce of trouble and plenty of speed/power with it.
Originally Posted by Everybody79x
Its half the price of Tekin and haven't seen any fail locally yet. Lots of failed tekins. With that said, it's cheap for a reason. Want reliability? Get Orion in my opinion.
I'm sorry, but Orions arent the be all/end all of electronics...
After I seen their price on the 4.5t 550 can 2 pole SCT motors... they can pound sand if they think they have a motor worth $195
DoogieLee is offline
Old 06-01-2015, 08:11 PM
  #9275
rcmania74's Avatar
Super reliable
Old 06-01-2015, 08:13 PM
  #9276
rcmania74's Avatar
You do realize hw makes orion don't you? ??? You are simply paying for the name..
Old 06-01-2015, 08:47 PM
  #9277
ColbyRichards's Avatar
Is there a certain order to using the usb to programmer? I plug it into my computer to update and my hobbywing program crashes. How do you update your speed controller?
ColbyRichards is offline
Old 06-01-2015, 09:43 PM
  #9278
Any word on adapting the software to be fine tuned via Android/iOS yet so we can leave the laptops at home?
AaronG is offline
Old 06-01-2015, 09:52 PM
  #9279
Super Moderator
Grizzbob's Avatar
Ummm, actually, the Stock Spec v3.1 also has adjustable timing & boost, & everything else the 120A v3.1 does. Only big difference is the all aluminum case on the non-stock spec & slight difference in current rating. I have them both(the Stock Spec in my stock class 2WD buggy, & the all-aluminum one in my mod class 4WD buggy), & aside from the weight & current rating of them, they both work the same(& I LOVE both of them, best value in an ESC I've had yet in my 26+ years of racing, mostly with top of the line Novaks & Tekins up until a year ago when I tried my first HW, now I have 4 of them)....
Grizzbob is offline
Old 06-01-2015, 09:54 PM
  #9280
Super Moderator
Grizzbob's Avatar
I have to admit it would be cool if I had a version of the data link software that would work on my android phone(especially for reading the data logs from the ESC)....
Grizzbob is offline
Old 06-01-2015, 10:38 PM
  #9281
You realize that HW has a ton of software bugs and Orion is typically a higher spec'd hardware with reliable software?
I am cheap and running HW SCT Pro successfully though, but it has bugs, that their support is calling normal.
Old 06-02-2015, 12:18 AM
  #9282
Hellou!
should be fine hobbywing sct pro 120A on 4s in traxxas summit 1/10 with 1800W 1/8buggy size motor? Or go for 150a xerun?
thanks
johny
johnyM128 is offline
Old 06-02-2015, 06:16 AM
  #9283
rcmania74's Avatar
Originally Posted by johnyM128
Hellou!
thanks
johny
It will work..summit is geared low so it isn't drawing so hard
Old 06-02-2015, 06:18 AM
  #9284
rcmania74's Avatar
Ive ran r10 pro back to back with a v3.1 and saw no difference and ive never had any glitches or bugs
Old 06-02-2015, 05:23 PM
  #9285
Try right clicking the program and running as administrator.............
