HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 05-09-2015, 08:12 AM
  #9136
Angry
Hello, after I flashed latest software into my Xerun 150A esc it always starts in programming mode, like a "set" button is pressed, but it's not.
ESC doesn't react to anything, the only thing I can do is connect it to older style LED programming box, I tried changing all settings to defaults, but it still boots into programming mode
Do you know a way I can get it to connect to PC to flash older software? It worked fine before I upgraded software.
Thanks in advance.
Bahecuk is offline
Old 05-10-2015, 02:49 AM
  #9137
R1Joel's Avatar
Will this work with my Xerun 150a? I am a bit confused of the different types. Also will my esc run if the sensor cable breaks while running?
http://www.ebay.com.au/itm/Hobbywing...item1c4909a03d
R1Joel is offline
Old 05-10-2015, 06:39 AM
  #9138
FastPete's Avatar
Trader Rating: 44 (100%+)
That will work
FastPete is offline
Old 05-10-2015, 08:47 AM
  #9139
Trader Rating: 25 (100%+)
Programmer Question.
I hooked everything up and it calibrated fine. When I try to plug the programmer in, it won't go past the "connecting to pc" stage. I waited over 10 in and nothing.
Any help on this is appreciated.
TeamOSG is offline
Old 05-10-2015, 09:49 AM
  #9140
JatoTheRipper's Avatar
Does anybody have any discount coupons for Falcon Sekido? I want to place a fairly large order.
JatoTheRipper is offline
Old 05-10-2015, 05:31 PM
  #9141
R1Joel's Avatar
Originally Posted by FastPete
That will work
Awesome. Thankyou
R1Joel is offline
Old 05-10-2015, 07:26 PM
  #9142
Slotmachine's Avatar
If you are trying to hook in with the speedo you need to have a charged battery in the car and has to be turned on.
Slotmachine is offline
Old 05-10-2015, 10:15 PM
  #9143
Carter Flotron's Avatar
SPD1CF125
Won't be a huge discount, but it's something!
Carter Flotron is offline
Old 05-10-2015, 10:36 PM
  #9144
Default Wire Issues
I want to start by saying that I have been very happy with the performance of my Hobbywing speedcontrols. I started with a Xerun v3.1 stock spec and was so pleased with its performance and built in power button that I ordered a Xerun 120A v3.1 for my mod car. Upon receiving my new speed control I was disappointed with a couple of things: the new speed control did not have the built in power button (on/off) switch, and the sensor wire was hard wired into the ESC. I wanted to return the speed control but I had ordered it to prepare my car for a regional event and didn't have enough time to come up with a replacement so I just went with it.
The ESC works great but now I have run into the problem where the sensor wire is not long enough to alter the configuration on my vehicle. Typically I would just purchase a longer sensor wire but that is not an option because the sensor wire is hardwired. The pictures of the 120A show the power button and the disconnectable sensor wire, I'm wondering if I received a different model than I should have. I would really like to be able to use this ESC and am hoping that you may have a resolution to my problem. Do you have any suggestions?
tscamar0 is offline
Old 05-11-2015, 09:18 AM
  #9145
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
You have the waterproof version of the 3.1, click here.
Kraig is offline
Old 05-11-2015, 09:20 AM
  #9146
Super Moderator
Kraig's Avatar
Where are people posting settings for the 3.1 line of speed controls? I am looking to see how people are setting them up for mod 2wd buggy. Thanks in advance!
Kraig is offline
Old 05-11-2015, 01:34 PM
  #9147
Default Xerun sct pro/4700kv combo
I just got combo installed in my xxx sct and completed calibration. After my first squeeze of the trigger, the green and red LEDs flash continuously until I power down. Manual says over current. I'm using a thunder power 5300mah 65c 2s. It works fine in my other vehicles.
HECO is offline
Old 05-11-2015, 02:01 PM
  #9148
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
+1
I have talked to some main racers and they all say if your using a 7.5 or less motor you dont want any turbo or boost - i run mine this way and she flies.... im running the v3.1 stock and hw 7.5 v10 motor love the combo no heat issues as well
BlackStarRacing is offline
Old 05-11-2015, 02:05 PM
  #9149
Hello
When you calibrated did you first set your throttle on your radio to reverse? Make sure all your end points are at maximum before calibration.
Old 05-11-2015, 02:07 PM
  #9150
Yes I did. I've tried the calibration a few times
HECO is offline
