HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 09-02-2012, 09:29 AM
  #901
TCCustoms's Avatar
Originally Posted by lewis110
Angelo goes by the name Cobra Racing on here. You will find him mostly over on the hobbywing thread in the on road forum. He also started most of these hobbywing threads if you wanna pm him.
there ya go...and i would get on it cuz i know there warranty is short so the sooner they know they better off you are...i think my combo said 60 or 90 days and that was from the manufacture date if i remember right...
TCCustoms is offline
Old 09-02-2012, 03:36 PM
  #902
IROC-AR15's Avatar
Trader Rating: 29 (94%+)
Wrong thread
IROC-AR15 is offline
Old 09-02-2012, 05:32 PM
  #903
Trader Rating: 41 (100%+)
Hey guys
Just had this happen today. I have one of the 120A 1s versions (2.1) and it just stopped sending power to the motor. I cased a jump kinda hard but I have the ESC on a foam pad so it has some shock absorbency.
I have ran this ESC for one winter onroad in my 1/12th pan car (1s) and now my 1/10th Scale buggy (associated B4)
Ran it all summer as well with no issues. never really got over 120F.
It is still sending power to the receiver so it's BEC is working.
I can re-program it and it all seems to work that way.
I have tried a few firmware versions but each time I get no motor spin. and when I try and re-calibrate it to the radio I don;t get the normal motor chimes.
Anyone had this and know a solution? or is it time for Angelo to help me out
jdeadman is offline
Old 09-02-2012, 06:10 PM
  #904
elex300's Avatar
Trader Rating: 110 (100%+)
Where can I purchase one of the 4000kv 4 pole motors at?
elex300 is offline
Old 09-02-2012, 06:13 PM
  #905
lewis110's Avatar
www.falconsekido.com or www.teamcrc.com
You can probably find it cheaper at falcon sekido
lewis110 is offline
Old 09-02-2012, 07:20 PM
  #906
rcboy1's Avatar
Originally Posted by Dusttt
got a coupon code?
sorry I didn't get back to you sooner. Thanks to the other posters, yes I would actually say buy your esc from http://www.falconsekido.com/ . I have bought from Hobbypartz before and haven't had any major issues, but as Falcon is the "executive" distributor, they most often have the best prices and actually have a warranty/return policy: http://www.falconsekido.com/pages/return-policy
I am actually going to be receiving one of these exact motors pretty soon, I will most likely post on here about it after I've ran it a bit (this is one of the few HW motors i have not used).
rcboy1 is offline
Old 09-02-2012, 08:57 PM
  #907
clint's Avatar
Trader Rating: 24 (100%+)
has anyone tried the V3 firmware on their xerun 120 esc?
clint is offline
Old 09-03-2012, 01:21 AM
  #908
M7H
M7H's Avatar
That's not possible.
M7H is offline
Old 09-03-2012, 01:23 AM
  #909
M7H
M7H's Avatar
Originally Posted by Overtorqued
I've tried hooking up different electronics, but it made no difference. And the Castle system I've been running works fine with the electronics currently in the car. I'm sure it's some obscure problem nobody else has ever had...that's the kind of thing that always happens to me :P
Maybe, maybe a re-flash of the firmware might do the trick.
M7H is offline
Old 09-04-2012, 03:38 AM
  #910
MOmo's Avatar
Momo you can't have the v3 software on your lcd box. The v3 software will not work with the 2.1 esc. That's why your lcd box isn't working. I believe you need the 111 software on your lcd box.
SO I played around with the BOX and the ESC and I was able to get the ESC into Blinky mode. But I still have V3 installed on the Dig box. I tried locating the older software I need for my ESC. I show 1.11_120331_V3.
The ONLY other version that comes thru. on the Software is 1.08_120504
Anyone know how to find the older software? I want to try and re-install a previous version. I tried looking on HW site, http://www.hobbywing.com/product_show.asp?id=246
How can I find the previous software editions?
MOmo
MOmo is offline
Old 09-04-2012, 10:07 AM
  #911
I'm running an SCT Pro with a 4000kv Tenshock SC411. Sometimes the ESC will be blinking red and green at the same time and it seems to act a little more like a sensorless setup until I unplug everything and let it "cool down." By acting like a sensorless, I mean it cogs a little at low speed from a start.
I did notice when I plug in my programmer, it's on a "MONSTER" profile. I'm not running any timing or boost. It's only occasionally that it will start flashing red/green. How can I get it out of the monster profile? Any other ideas on what could be the problem?
thegame7 is offline
Old 09-04-2012, 10:58 AM
  #912
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
i was getting that issue and i took off the temp setting i forget which one is it you should be safe with just low volt cute off...
BlackStarRacing is offline
Old 09-04-2012, 11:01 AM
  #913
TCCustoms's Avatar
I beleive its the thermal protection one...i also shut this off
Old 09-04-2012, 11:04 AM
  #914
Yeah mines was doing the same thing as the guy described until i turned that to off.... thanks TC.....
Old 09-04-2012, 11:10 AM
  #915
TCCustoms's Avatar
monster is just the profile name, once you change a setting on it, its now your own profile it just is a way to allow you to have more than 1 profile setting w.o changing all the values everytime. Not a big deal or hurting anything on the MONSTER profile, but if you hit the value on the advanced LCD box you should be able to change through the profiles and i think there is 2 or 3 of them...
Hopefully someone will chime in on the blinking lights, mine does this but the only time i notice it is when i pull the truck up to check temps before running a full batt through or at the end of a batt and i kno its not LVC but is kinda frustrating that it comes on and makes you wonder why its on...
