HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#9001
Hey thanks for the quick reply pete. I turned auto calculate off, set the lvc to none just to see if that was the problem. Tried a different reciever. but the problem still persists. No beeps when I plug the batteries in but I get the green light. Then solid red when I push forward or reverse and no motor response but I get servo movement. Am I just missing something simple here?
Hey guys I have a 150a ezrun problem. went from a single 4cell lipo to two 2 cell lipos, also a new radio. Rebinded the Radio, recalibrated esc, but now I only have steering no motor response. neutral has no light, but reverse and forward both have solid red. Also I get no beeps when I turn esc on. Any ideas guys? Have a race coming up and im really stressed out here. Thanks again.
#9003
Hooking it up reversed could have blown something, go here>http://www.falconsekido.com/pages/rma
and start an RMA Process....................
#9006
The esc/motor was used and came with the truck so I don't have a receipt or proof of purchase. I'm not sure it would be worth the cost of repair & shipping to make it worth while to send it in to be fixed. I was hoping someone might throw a hail mary my way and have me somehow reset the esc and it would work...
#9007
Maybe I'll contact them and see if they would look at it and if they deemed it faulty could send me a replacement/repair it for free. If they needed to charge for repairs or replacement I'd prefer they just toss it?
#9008
Alright, so I just tested it after the changes were made and it does the same thing. After a hard landing, the lipo cutoff kicked in. Turned it off, then on and it ran fine for another 5 minutes until it did it again. Thought maybe the batter was indeed low, but put it on the charger and it was at 7.4 volts. Good thing I have a tekin RSX coming in the mail!!!
#9011
I've got a new radio and receiver on the way, I'll wait to try that out, but I'm more concerned about the esc I've tried 2 receivers and am getting no power to them, the only indication I have power at all to the esc is the blinking led and that it starts to get warm fairly quickly. The cooled fan doesn't run either, I feel like power is going in but not coming out anywhere, I'm going to hook it up to a volt meter tomorrow and see.
#9012
Think I have an ECS problem as well. Bought used Slash Ultimate w/2s Lipo. Runs fine for a few minutes then just stops, but servo still works. Triad charging battery, and same thing. Thought I may have a bad battery as it was used with the truck. Bought new 3s battery ( figured if I was buying might as well go big ) blistering fast for a few minutes but it does the same thing. Just quits running, servo works, now it won't even let me turn the ECS off using it's switch, have to disconnect the battery.. Read over the manual but it doesn't tell me how to change the LVD, only how to turn it on or off. Not sure if that is even my problem at this point.. Stock motor and ECS, both with optional fans. Surely with a 5000 30c 3s Lipo it should run more then 5 minutes correct? and then it doesn't go into slow mode to get it to you it just stops where ever it's at..
#9013
Does Mimi sell much Hobbywing stuff, are they popular with other racers at The Track.
I am going to buy a HobbyWing ESC soon, if Mimi has them I will buy from her and support a local business
#9015
I've loved my hobbywing stuff up until the other day. I've got the super stock esc in my 22sct with an 8.5 and it has worked flawlessly until last night at the races. I can make about 1-2 laps and then the truck goes to half power for about 10 feet and then completely quits until I restart the esc. I have no timing and the punch is turned down. I've tried putting a glitch buster on it to no avail. Any suggestions?
