HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 04-03-2015, 02:50 AM
  #8971
R1Joel's Avatar
Just wondering. Do I need to re-calibrate throttle end points after updating firmware?
R1Joel is offline
Old 04-03-2015, 09:30 AM
  #8972
Armstrong's Avatar
Trader Rating: 18 (100%+)
Hi, my hobbywing 35A RTR S10 ESC just stopped working all of a sudden. The red and green led turns solid everytime I switch on the ESC and that's pretty much it. No throttle response or anything comes from the ESC although the BEC works as I have steering. The set button does not work either even if I press and hold it while turning on the ESC or just pressing it while ESC is on. Can anyone help me? What does the solid red and green led mean on a sensorless ESC like the HW S10 RTR 35A ESC?
Armstrong is offline
Old 04-03-2015, 03:19 PM
  #8973
lewis110's Avatar
yes, it also doesnt hurt to do it after each adjustment.
lewis110 is offline
Old 04-03-2015, 05:05 PM
  #8974
Stuff Of Legend's Avatar
Questions??
10.5T Bandit ETA?
falconsekido.com *Suggestion* Add an Instock notifacation for out of stock items
dre
Stuff Of Legend is offline
Old 04-03-2015, 05:20 PM
  #8975
R1Joel's Avatar
Alright thanks for the advice
R1Joel is offline
Old 04-04-2015, 02:09 PM
  #8976
1/4milecrazy's Avatar
Quick question, hopefully a quick answer from you guys. Hobbywing, stock spec v3.1, can it handle a 4 pole motor on 2s? I am assuming no, just want to be sure.
1/4milecrazy is offline
Old 04-04-2015, 02:13 PM
  #8977
FastPete's Avatar
Trader Rating: 44 (100%+)
Its best to use the SCT Pro for 4 poles
FastPete is offline
Old 04-04-2015, 09:08 PM
  #8978
BryanAZ's Avatar
Hello! I have the SCT Pro and fairly frequently on really hard landings, like when I case it on a jump, the low-voltage cutoff kicks in and kills the power. If I turn the switch off and then on again, it will run at full power. Anyone else know of this problem, or know how to fix it?
BryanAZ is offline
Old 04-04-2015, 09:09 PM
  #8979
Default xpost
Last time I ran my mini 8ight t I splashed through a puddle on accident, and nothing happened as I would expect from a waterproof esc but I avoided the water anyways after that. I brought the truck back inside and let everything dry out over the next day, and after that I set into tearing it apart to clean it, once I had it back together I plugged everything back in to make sure I put everything together the right way and noticed my fan wasn't spinning so I took it out and ordered a new one. I put the new fan in today and noticed it will twitch once and then nothing and the red light on the esc flashes. When the esc beeps for a cell count on my lipo the motor twitches with the beeps and then I get a constant flashing red light and it seems like no power is passing the esc, it also heats up noticeably as soon as it's turned on which freaks me out so I shut it down when it get warm to the touch. What's going on?
ScumCity1 is offline
Old 04-05-2015, 05:06 AM
  #8980
Dirtburner2.0's Avatar
Hey guys I have a 150a ezrun problem. went from a single 4cell lipo to two 2 cell lipos, also a new radio. Rebinded the Radio, recalibrated esc, but now I only have steering no motor response. neutral has no light, but reverse and forward both have solid red. Also I get no beeps when I turn esc on. Any ideas guys? Have a race coming up and im really stressed out here. Thanks again.
Dirtburner2.0 is offline
Old 04-05-2015, 07:58 AM
  #8981
FastPete's Avatar
Try to take it off auto detect and pick the cell number your using.
FastPete is offline
  #8982
FastPete's Avatar
Did you lower it to 3.0?
FastPete is offline
Old 04-05-2015, 09:17 AM
  #8983
https://youtu.be/yvYXefYeaZc
Old 04-05-2015, 10:09 AM
  #8984
quicrun 30A sensorless brushless esc
today everything ok, but after some time bashing, solid red lights on on esc, motor stopped... after turn off and turn on motor goes on... it happens more than about 4 times...
any ideas?
johnyM128 is offline
Old 04-05-2015, 11:13 AM
  #8985
trutledge83's Avatar
Default Throttle Cut Off
I have a problem with my SCT Pro 120A. I have read on other posts and I dont mean to repost it but I cant find a solution.
my 8th scale truggy after 4 laps my throttle cuts off and I still have steering. After 20 seconds throttle comes back and it good for about a lap then does it again. when it does this the esc temp is 115 and the motor is 135
I have disabled the temp cut off.
I have put voltage cut off to 3.2v a cell
I have set auto calculate to 4s
Im running a 1900kv SMC 4 pole
46/15 gearing
SMC 6500 mah 65C 4s lipos (dose it with my other packs)
trutledge83 is offline
