HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 04-01-2015, 08:08 AM
  #8956
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
so what is a number to get in touch with someone from Hobbywing with tech support questions? Or, is there someone specific on here to contact with those questions?
Cain is offline
Old 04-01-2015, 10:35 AM
  #8957
FastPete's Avatar
Trader Rating: 44 (100%+)
[email protected]
FastPete is offline
Old 04-01-2015, 10:40 AM
  #8958
Tech Legend
Cain's Avatar
Originally Posted by FastPete
thanks Pete! Do you know if they carry a replacement sensor system for the 3656SD motors?
Cain is offline
Old 04-01-2015, 10:52 AM
  #8959
FastPete's Avatar
Im sure they do, I will email and ask. Their not in my pricesheet.
FastPete is offline
Old 04-01-2015, 10:56 AM
  #8960
Tech Legend
Cain's Avatar
good stuff, and the email address was falcon not falkon
shot them a pm.
Cain is offline
Old 04-02-2015, 08:49 AM
  #8961
Hi guys,
I just picked up a Hyper 10SC Pro 4wd SC truck. I have only ever run 2wd, except for my 1/8 scale buggy which came RTR w/ Hobbywing ESC. I have had 0 issues with this Hobbywing so I ordered an EZ-RUN SC8 w/ 4700KV motor.
I'm curious what gearing you all are running, or what gearing would be appropriate for my set up:
42T Spurr
2S Lipo
4700KV
Curiously, I can't find any gearing rollout charts like I have for my 2wd Losi. I have seen some threads talk about 14-16 tooth pinions.
Any help, or thread redirection if necessary would be helpful.
Thanks,
Greasemunkey is offline
Old 04-02-2015, 12:40 PM
  #8962
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I searched the tread and didnt really find any feedback on the bandit line of outlaw motors? Any comparisons to the trinity blue wire, trinity SS or other popular 17.5 motors would be great. What about the motors makes them outlaw? Rotor? Stator?
Wildcat1971 is offline
Old 04-02-2015, 01:10 PM
  #8963
COBRARACING's Avatar
outlaw means none roar approved not spec motors etc .Its all in the stator winding .
COBRARACING is offline
Old 04-02-2015, 02:27 PM
  #8964
Will the V2.1 run a 4wd 1/10 buggy with a 6.5 without over heating. I know it says it will but looking for someone that's doing it.
blue t is offline
Old 04-02-2015, 04:15 PM
  #8965
Default XeRun 4-pole SC motor issue
Need some advice from the group. I have a 4000kv Xerun 4-pole mated to a 150 amp Xerun esc (with external BEC) in a Losi SCTE. The "C" wire has a tendency to unsolder itself from the motor during runs.
Gearing is tame: 15 pinion and 40 spur. Esc settings are low timing ("2" setting), no drag brake, 50% brake and punch at "6". There doesn't appear to be any extra friction in my setup and the motor generally temps at 140F when it comes off the track so I don't think I'm pushing it very hard.
Any thoughts why just the C wire might get so hot as to melt the solder and detach? Just a bad motor? I've run a HW 4700 in other SCTEs and have never had these problems. Any thoughts are appreciated.
Paul
Tampagoalie is offline
Old 04-02-2015, 04:25 PM
  #8966
Slotmachine's Avatar
Paul
I`ve seen lots of this happening. If you have the new motor with the swivel connectors most likely the swivel is loose, if not it`s a bad solder joint. I f you can pick up some silver solder use that because it has a higher melting point.
They are fast! I got one last year and ran it [17.5] and it was only .5 of a second off of the guys running mod. sedan.
Paul
Team Driver Hobbywing
Slotmachine is offline
Old 04-02-2015, 04:50 PM
  #8967
xsracer's Avatar
Originally Posted by Greasemunkey
Hi guys,
42T Spurr
2S Lipo
4700KV
Thanks,
I have that same truck. I'm running a 17 tooth pinion with the XTM 550 3800 kv. and it gets to about 135f after 12 to 14 mnts. Im running a 15t on my Tekno SC with the 4000v Hobby Wing Pro. 14 -16 is a good plce to start.
xsracer is offline
  #8968
[QUOTE=Slotmachine;13940028]I`ve seen lots of this happening. If you have the new motor with the swivel connectors most likely the swivel is loose, if not it`s a bad solder joint. I f you can pick up some silver solder use that because it has a higher melting point.
Thanks for the fast response, Paul. I'll lean towards loose swivel connector 'cause I'm using silver solder and I'm pretty good with my Hakko iron. Do you think I'd be better off removing half of the connector, or soldering the two halves of the connector together? Thanks again.
Paul
Old 04-02-2015, 06:57 PM
  #8969
[QUOTE=Tampagoalie;13940082]
Paul
If you continue to have problems then I would solder directly to the motor tabs, just take the connectors off completely.
Old 04-03-2015, 02:05 AM
  #8970
lewis110's Avatar
I run a 17.5 bandit motor in my buggy. It makes a HUGE amount of torque. (Something the v10 lacks in.. Low end torque) the top end of a bandit isn't as good IMO. You will have to gear up at least 1 tooth. I run on a smaller usually technical Astroturf track where you really need the extra low-mid power.
If you bought one and took it apart the differences are pretty noticeable. The stator winding is different and it uses a mod rotor. I have never had a motor that moves from one phase to the next this hard. The magnetic strength of this motor is amazing IMO I highly recommend you try one out if outlaw motors are legal and you run indoors. Outdoors on a bigger track I believe you will be better off with a standard V10 motor. Also with the bandit I learned to keep the end bell timing pretty low. You don't gain much rpm from raising it like you would a normal roar motor. I can look but I believe I'm right around the stock setting of like 18 or so degrees.
Hope this helps
Roger
lewis110 is offline
