HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 03-30-2015, 08:53 PM
  #8941
Tanis103's Avatar
Just wanted to say, how much I love that I can turn off my V3.1 ESC with holding the brake for 10 sec. It make life easier and I use it everytime. Now if I could only turn it on that way. Thanks Hobbywing.
Tanis103 is offline
Old 03-31-2015, 06:53 AM
  #8942
Drerc's Avatar
Hey guys,
I have two v3.1's and a 7.5t and 6.5t V10 in two different cars. Now I feel they are very agressive, for the minimum of throttle they give allot of power, wich makes it harder for fine and short cornering.
I drove with a friends v3.1 (exact same settings, also a 6.5t V10) and that felt smooth as hell. I installed the new software, and he too. Same timing settings on motor, just same settings everywhere.
What could that possibely be? Or how can I fix it? I find it very wierd actually.
Drerc is offline
Old 03-31-2015, 07:54 AM
  #8943
Default Motor\ESC choice for 4x4 SCT on 3s
I currently have a Slash 4x4 that weighs 6lbs RTR. 2-3 months from now, I'll be getting the new Tekno SCT410.3. I want to run them both on 3s with a sensored motor in the low 3000kv range. I want 3s for longer run times at the track and so it's not so hard on the electronics. I don't race, just enjoy driving. What would you suggest ? Thanks.
MaX-D is offline
Old 03-31-2015, 08:03 AM
  #8944
Carter Flotron's Avatar
Originally Posted by Drerc
Hey guys,
With the settings being the same on your ESCs, I would think youve got something setup differently on your radio. I'd check to see if you have any positive exponential dialed into your TX!
Carter Flotron is offline
Old 03-31-2015, 09:42 AM
  #8945
FastPete's Avatar
Trader Rating: 44 (100%+)
The 3400 or 4000 will work fine on 3S
FastPete is offline
Old 03-31-2015, 11:10 AM
  #8946
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
are the sensor units on the 3656SD motors replaceable? if so, what is the part # of what to use?
Cain is offline
Old 03-31-2015, 11:24 AM
  #8947
Drerc's Avatar
Also exact same
Drerc is offline
Old 03-31-2015, 03:37 PM
  #8948
xsracer's Avatar
Hi gang a friend gave a xerun 120a v2.1 new version esc with a program box(doesn't say pro.) . It's in mint condition. How do I get it to blinky mode so I can run it in 17.5 stock on road? I also have two just stock speedos in my mini and F1. If I have to update soft ware can I still use the box for both types of esc.? Thanks for your time.
xsracer is offline
Old 03-31-2015, 04:22 PM
  #8949
Default Hobbywing 3656sd sensor board out?
Hey guys, I'm having a problem with my Hobbywing 3656sd motor not starting all the time, and when it does start it coggs at really low speed, after that I seems to run fine through the mid and top rpm. I think maybe I have a hall sensor problem and was hoping that someone that has had one go out may be able to shine some light on what is going on, and how to test for a bad sensor, motor or esc. Yesterday I replaced the sensor wire, no luck. Here is a video that I took this morning with the motor pulled back from the spur gear.
red100076 is offline
Old 03-31-2015, 07:14 PM
  #8950
Slotmachine's Avatar
If your speedo has a sensor-less mode try that for grins. Try another sensor wire also, I have seen new ones that were bad, then get back with us here....
Paul
Slotmachine is offline
Old 03-31-2015, 07:22 PM
  #8951
Also exact same
All the radio settings are the same? Id try recalibrating (remember to set your endpoints before doing this) the ESC first, and make sure your sensor wire is in good condition while you're at it. If this doesn't work, the next thing to try would be flashing the esc with the software you're using again.
Old 03-31-2015, 07:30 PM
  #8952
Paul
Unfortunately the Viper ESC does not have a sensorless mode, that would be nice feature to have. It would sure save me some time that's for sure. I tried a new sensor wire with no luck. Any other suggestions?
Old 03-31-2015, 09:43 PM
  #8953
Well if you have another motor try that. Maybe have a fellow racer try your motor to see if it acks the same.
Old 03-31-2015, 11:56 PM
  #8954
Drerc's Avatar
Yeah. I tried the calibrating. Everything on radio maxed out then calibrating and then setting it up again. When i connect to the PC it says i have the new version. Maybe have to try to reflash but i will eind it wierd if that fixes it..
Drerc is offline
Old 04-01-2015, 04:01 AM
  #8955
Default Punch Rate Switch Point and Punch 1 and 2 Settings
Run a blinky stock buggy on an indoor med bite track. Would like to hear from others regarding their settings for punch switch point and punch 1 and 2 settings. And reasoning behind changing from default values.
Micah123 is offline
